GLC
- Joined
- 21 Nov 2018
- Messages
- 298
I’ve read a lot of threads recently where the topic of the pros and cons of gangways have been discussed, atleast with regards to drivers and guards etc. Units with gangways tend to have cramped cabs for drivers, even if they are built with a partition that can be kept open ala Sprinters. Obviously gangways are typically built to be central on the unit so orientation is irrelevant when coupling together, but that got me thinking…
A lot of modern units have powered gangways which extend to connect to the leading unit. Since this is atleast somewhat battle tested technology (the 380s have been doing this for 10 years now) could a unit be built where the gangway is offset to the right of the unit, and extends diagonally left to meet a reciprocating gangway in the middle of the unit. This would give a driver near 50% frontal area dedicated to the cab, sort of like the new Merseyrail units have(although they are for emergency exit only I understand). Multiple working outwith a units own class does not seems to be a particular concern to TOCs these days so an unusual setup for gangways wouldn’t seem to be an issue there.
I realise this might sound a bit fantastical, and equally anything is possible if you are prepared to spend money, but I was just wondering if this is something that had been tried or developed before by anyone?
