Hello all, as a regular user of the NXEA services on the Southend line and someone who's excited for the arrival of Crossrail, I was wondering if Crossrail could run to Southend Victoria? Say if there's around 10 tph offpeak, 4 of them could run to Southend Victoria which would open up many new direct travel oppurtunities and as the majority of commuters change onto the Central line for onward travel to Central London, this would take the change out of the equation. I would propose running the extended services on a skip/stop pattern from Liverpool Street calling at Stratford, Ilford, Romford and all stations to Southend as this would only add 10 minutes to the journey potentially, with peak services having different calling patterns after Liverpool Street. Off-Peak I would maintain the 3tph fast service to London but fast from Shenfield, or if there wasn't enough demand, cut it to 2tph with the remainder of passengers being catered for by the Crossrail as many of these passengers want to travel to Central London, even off-peak. If the service would be cut back a little, I would use the extra stock to run an hourly off-peak service from Southminster, non-stop from Wickford. I've worked out that the current 20 minutely service could be accomodated on one platform at Southend Victoria, so the additional services could be easily accomodated. Also with Crossrail forming the bulk of Peak services this means only around 4 fast services an hour in the peak would be needed, thus freeing up paths for GEML services, and relieving congestion. Accomodating the Crossrail services after Shenfield would be without complications as all trains apart from the Southminster's call all stations from Billericay and there's no freight. The trains that wouldn't continue to Southend could most likely be turned back at Gidea Park or Shenfield and with a quick turn around of around 5 minutes it wouldn't cause any problems I've thought. The only expenditure needed that I've calculated would be to double the spur from the metro platforms to the Southend line which passes under the GEML. So, what do you think? Obviously, its just my mere musings
so, if it doesn't work or doesn't sound attractive just say so.
