Hardcastle
There is a old Cumberland cc signpost in Keswick showing directions to the station. It was mooted that the Newcastle-Carlisle service be extended to Keswick should it reopen.
The route is very straight, causing few problems for modern stock and is currently in tact between Keswick and Penrith - all the way to the original Station. I believe a large bridge needs to be constructed over the A66
The current platform 3 is the Down Loop, that starts roughly where the Keswick Line used to branch off the WCML at a triangle junction at Redhills.
I believe the local authority short-sightedly allowed a planning application that breached the alignment at the Flusco site close to Newbiggin, not far from Penrith. Although only a small breach, finding an alternative route wouldn't be that easy. It would have been a lot easier for the developer to amend their plan to avoid the alignment but the LA decided against requesting this.
Could it re open? - Yes.
Should it reopen? - Perhaps, IF there was a decent business case and enougth potential traffic year round
Will it reopen - no.
There appears to be space for a fourth track from Penrith station to the north end of the Eamont viaduct, including the bridges over the M6 and A66!(the loop runs over the M6, so that bridge is fine).
We need to accept that these routes were built to be major transport corridors and that whilst it's good that track beds can sometimes be used as paths etc, this should only be seen as a caretaker function in case the line needs to be used for the purpose it was built for.
I think the problem with preserving railway corridors is that the powers that be at the time had convinced themselves that the railway was no longer required. It doesn't do their credibility much good if they then add "but perhaps we should protect it in case it's required in the future". That may be good long term thinking but it's not good politics.
I understand that local authorities until relatively recently had no specific powers to protect former rail alignments for reuse as a railway unless there were detailed proposals already in place and funded for their reopening (clearly not very common from 1960s onwards). On appeal, developments rejected solely for breaching rail routes would then be allowed and councils would risk having to meet appeal and delay costs. By contrast new road corridor protection could be applied regardless of the status of the project presumably because from a motor age perspective once a road project had been conceived it was only a matter of time before it inevitably would be built. So central government at the time could be said to have stacked the odds deliberately in order to prevent any closed route's economic reinstatement. It is no surprise that station and yard plots in town and village centres succumbed first to development, often as small estates of higher value private housing. These subsequently would be both very expensive and difficult politically to remove, and thus would effectively block the only practical rail alignment through a settled area. So even if 90% of a route remained clear elsewhere in the countryside, these small incursions at the most critical points could effectively block any economic reinstatement, possibly for ever.
the south Lakes does have rail connection option and it has alway sstruck me as a shame that this isnt the same for the north?
Surely in sustainability terms if you could connect from the WCML and either save the money from the CCC funded Penrith bus or spend it on improving the bus servcies from Keswick to the local hills, then that would be a better use of funds and provide an alternative to the 1000s of cars on the A66?
That does assume that the railway wouldn't require any subsidy. Besides, killing the bus might not be desirable - I imagine (without any local knowledge) the bus would serve villages that a railway couldn't serve.
But in general your point is a good one. One thing that strikes me every time I go to the Lake District is the extent to which the environment in very beautiful towns and villages is basically being ruined by the numbers of cars. Obviously, you want the tourists to be able to get there, but if you could get more of them there on the train, and then using buses to travel within the Lake District, the region would become much more pleasant to visit.
would it have to be heavy rail? light rail/tram/narrow gauge - could that work?
Yes why couldn't it be metre gauge on the Swiss model? I've been told before that there wouldn't be much difference in costs - but if that is the case why do metre gauge lines exist? Operated to tramway rules surely there would be much less need for segregation and it would be easier to get it round any built on sections?
Of course once shut it becomes a lot harder to reopen. If this line had survived I think it would be pretty successful today.It is no coincidence that the Keswick line closed only two years before the biggest upgrade in the history of the WCML with through trains from London stopping at Penrith every two hours. Why was closure rushed through? Because the BRB didn't want to risk growth that WCML electrification would inevitably bring therefore making it harder to close.
It was the car that transformed the Lake District into a viable tourist destination and mass car ownership is largely responsible for the region's income and wealth. It's also responsible for crowding, but not just because of visitors - virtually every residence now has at least one vehicle, most have multiple and these have to be parked on streets not designed to take them.One thing that strikes me every time I go to the Lake District is the extent to which the environment in very beautiful towns and villages is basically being ruined by the numbers of cars. Obviously, you want the tourists to be able to get there, but if you could get more of them there on the train, and then using buses to travel within the Lake District, the region would become much more pleasant to visit.
Public transport will never be a transport solution for the Lakes, even supposing opportunities for meaningful improvements existed. If the region were to make car based tourism difficult, it would be a turkey voting for Christmas.
You may have seen my post, but you clearly haven't read it or understood it - your response makes no sense at all and I regret you're wrong - or at least a hundred years out of date.Is this a joke? This is the most ill-informed post I've ever seen.
It was the railways in Victorian times that started the tourist industry in the lakes and made it a desirable place to live. Much like the seaside resorts and the Scottish Glens/Highlands.
And also, as someone who used to live there- I assure you that public transport will be the future of the Lake District due to the lack of parking, severe congestion on the A590 (at times heading on to the M6) and cyclists joyriding two abreast on main roads making it impossible to get anywhere.
The place is also becoming more and more unaffordable, so people will increasingly travel there and back in a day rather than stay over or live there.
