- Joined
- 15 Apr 2008
- Messages
- 15,989
Bromsgrove and Cross City South recontrol is meant to be November and the final panel goes and subsequent closure of Saltley PSB.
It look very nice, classic almost with real grass growing in the landscaped areas. What the picture doesn't show is currently there's no connection to and plain track in the new plat 4 (Worcester/ Cheltenham side). Does this come into use with the new signalling once installed?
It's also good to see the mobilisation of the electrification site team. With bridge reconstruction complete the next phase marked by the new compound being put in place up at Vigo is rapidly taking place with OLE piles already being delivered. I wonder if it's planned to start installing these before the resignalling or only after, bearing in mid the GWML disruption? Vibration near old signalling kit has a nasty habit of revealing high resistance electrical connections.
Peter Plisner, Transport Correspondent on Midlands Today posted this picture last week.
https://twitter.com/BBCPeterPlisner/status/720598790835683328
Flickr has a few photos of recent progress, these are looking towards Birmingham with the existing station in the far distance just out of sight.
1) Looking northbound
2) Platforms are 1-4 going left to right
3) As far as I can recall it is just one track on the far side, which will become the freight loop
4) Both platforms are islands
5) Footbridge is at end of platform
It should be noted that upon opening, only platforms 2 (northbound) and 3 (southbound) will be used. Once all the works are complete it will change such that platform 4 caters for southbound trains, and platform 3 for Cross-City terminators.
I expect The Planner to come and correct me now!
Yes, platform 4 will become the down main. However I think a crossover is being (or will be) installed at the northern end of the station to allow the Cross-City trains to leave straight back towards Brum without any fiddling around.Thank you for this info. So platform 4 will become the down main ultimately? And Cross-City trains will have to reverse south of the station to access the trailing crossover?
The design, with 1 and 4 ultimately being the up and down main lines and 2 and 3 being the loops/turn-back facilities is very obviously the sensible one. But does anyone know whether it has been done British-style on the cheap, or whetheer the final main lines have the space to splay out and then come together again north and south of the station with no speed restriction below the ultimate line-limit? Or is the curvature crowded into a short space so that lower limits are or will be required?Yes, platform 4 will become the down main. However I think a crossover is being (or will be) installed at the northern end of the station to allow the Cross-City trains to leave straight back towards Brum without any fiddling around.
Right, dug the plans out to stop the general confusion (including mine) that is going on.
1 to 4 from left to right as said. 1 is the Up Bromsgrove Loop where freight will sit which is 30mph and 40mph on the exit. 2 is the Up Gloucester main line at 90mph. 3 is the Down Bromsgrove Station Loop at 40mph and where Cross City trains will turn back, they get back to the Up line via a crossover at the north end of the platform, also 40mph, which does not conflict with the Down line. 4 is the Down Gloucester at 90mph. Only 2 and 3 are wired. The old station has to close before the lines through 1 and 4 can be completed as they go through the ends of the platforms.
And thanks again.Possibly as it is only freight that is going to use it, though I suspect it is S&C related as it doesn't show as new, the distance from the point work to signal BA7612 at the end of the loop is approx. 800m. It is actually increased from the 15mph it is now.
Why, when nothing is going to use them that needs juice? You can do 1 and 4 when Brum Bristol gets wired.
Yes but that needs another possession for them to be wired.
Strictly speaking it wouldn't be from Birmingham to Bristol, it would be Bromsgrove to Bristol
Is there an opening date now then for the new Bromsgrove station? Looking forward to less of a crawl up the Lickey whenever I have to go to Birmingham!
Is this one of the rare cases where the vertical curvature affects the maximum speed that can be allowed top and bottom?Will the line speed on the Lickey itself change at all?
It's currently 80mph from Bromsgrove up the hill almost to Blackwell where there's a short 75 before going up to 90.
Sounds like it will be 90 at the bottom, but what about the top?
The Fast Lines Kings Norton-Longbridge would also need wiring, plus (probably) the Camp Hill route.
So, yes, it would be Birmingham to Bristol (or, strictly, Grand Jn to Westerleigh Jn, with a couple of gaps)
