It seems very unrealistic. Is this just a plan to justify the additional rolling stock for XC?
There's surely a whole heap of better ideas than this!
Certainly seems that way.More like asking what to do with HSTs that have been PRM modified and have a few years more life in them IMO.
There has to be, this is such a random idea.There's surely a whole heap of better ideas than this!
Restoration of a through express service from Leeds to Glasgow via a relatively direct route is a good idea, and it needs to be run by an inter-city TOC, but using modern inter-city type rolling stock rather than clapped out IC125s.There's surely a whole heap of better ideas than this!
The line speed is currently 60 mph from Skipton Northwards, but I'm informed by sources within Network Rail that the line is fit for 80 mph from Hellifield to Kirkby Thore and 75 mph from there to Carlisle. The 1997 scheme installing AWS and colour light distant signals was designed for these speeds and only fairly minor track and bridge works would be needed to implement the higher speeds.
As the freight flows have dwindled to very little, if there's only relatively minor works needed to increase the line speed then it would make sense to do that work and increase passenger capacity.More seriously, I do think there's merit in at least considering the idea; it's not the daftest proposal ever imagined. And given today's big announcement, anything might be possible!
I always found it rather bleak for my taste.
Traversing it yesterday I found it was impressively bleak, but also with some nice views down valleys.The bleakness is part of the appeal for me... if the weather is stormy it makes the rugged scenery all the more dramatic. No accounting for taste I suppose!![]()
Or maybe its just about giving Leeds a direct connection to Scotlands second largest city without having to go via Edinburgh!
Seems a bit wasteful. Leeds to Scotland isn’t a big market, so serving both the largest cities with one service seems to me to be an efficient use of resources.
They're seems to be a thing with direct services, when Harrogate and Middlesborough recieved a direct London service this was branded to be a 'Game Changer', don't forget Harrogate already has a frequent service to Leeds that already had a half hourly service to London.
Im certainly not saying that it would be a Game Changer in any sense but I think freeing up capacity on existing service via Edinburgh would be a good thing.
Agreed on both respects. Strangely enough l normally use Wolvo quite a lot.... On my way to the Golden Palace that is Molineux....Which Cross Country (or any other TOC) don’t pay.
The new Wolverhampton is better. And besides, the best thing about changing trains at Wolves is the Great Western next door. But beware if you are drinking a pint every 30 mins and have a train every thirty minutes, and get out of sync.
Travelling to Glasgow via Edinburgh from the West Riding is a roundabout route. A direct express service from Leeds to Glasgow Central via Carlisle should be able to cut 30-45 minutes off the journey time, which could be reduced to 3.5 hours with stops just at Skipton, Carlisle and Motherwell.Is going via Edinburgh such an imposition?
I know it's posh, bus it that bad?
There should still be trains from to Edinburgh via Newcastle run from Leeds by TPE, and from Sheffield by XC. Selected ECML trains could extend to Glasgow to provide a regular through service from Peterborough/Doncaster/York and NE England.In return for those 30 minutes, you abandon almost all the intermediate traffic?
Are there going to be enough end to end passengers to fill a HST?
It is if you’re on a Voyager...Is going via Edinburgh such an imposition?
Having done Glasgow-Leeds on just such a contraption for work, it was one of the worst journeys I’ve made by train. Fortunately the following day’s return to London was altogether better on a Mark 4 set.
They already are direct services (or at least are in normal times
Despite enthusiast whinges the reality is that over the years millions of ordinary passengers have made perfectly acceptable journeys on Voyagers. You won't be getting loco hauled stock back (the TPE Mk5 saga reinforces that), and indeed HSTs are no long-term solution - green they aren't, so really need to deal with that.It is if you’re on a Voyager...
I know we have a bit of lies, damn lies and statistics - but the modern diesel's are the worst in terms of carbon emisions.Voyagers aren't green either - if they aren't worse than HSTs they are tucked in just behind. The future for XC has to either be bi-mode or being split up so EMUs and slower, more environmentally friendly DMUs can operate the relevant bits.
The TPE Mk5 saga is not a fault with LHCS, it's a fault with cheap and nasty LHCS that (as an aside) isn't really LHCS anyway, it's more like a single-ended 4-TC* or a Stadler FLIRT with the power module at the end instead of in the middle. With modern-generation units the loss of depot-reformability is a big loss - even 15x were completely independent vehicles.
* Or a 442 with a 73 on the end. Look, I got them in!![]()
I could see a direct train may be useful for Loughborough, Long Eaton, and Chesterfield - Carlisle passengers, but am unsure how popular that is.
Voyagers would be great for a service over the S&C
Currently closed for "refurbishment"..., the best thing about changing trains at Wolves is the Great Western next door.
I knew I liked you pinko xAgreed on both respects. Strangely enough l normally use Wolvo quite a lot.... On my way to the Golden Palace that is Molineux....
CrossCountry have been extremely proactive in recent years about trying to shave sufficient margins off their paths at key strategic points to enable significant overall savings, for example most recently taking approx. 25 mins out of some of their Reading-Newcastle trains, by leaving New St slightly earlier, then beating EMR out of Derby, thereby getting a better path at Sheffield, and ultimately getting ahead of LNER from Doncaster.
The problem with the Bristol/SW England paths is the rail connections through the south west side of Birmingham and unless you’re somehow suggesting that XC should be funding a high speed underground cutoff (as that is what it would take) I don’t know what you expect them to do. The existing infrastructure would permit a 1h15m Bristol-Brum journey time in theory but in practice the quicker you get to the outskirts, the sooner you just catch up the CrossCity stopper. The incremental gains just don’t translate into a big win as the capacity isn’t there.
At Wolverhampton why couldn't you just take the stop out? In reality for most long-distance journeys there is somewhere else a passenger could change and for hops to Birmingham there's already plenty of services
