Cross Country Voyagers - rear set locked out of use?
24 Nov 2019
It doesn't matter if the odd vehicle has an engine out in passenger service. I think Voyagers can almost keep time on 3/5 although it would be taken out of traffic when suitable.
Agreed. Ours (not actually called Voyagers but the same family) can indeed stay in service with three running because they’re so over engined. Keeping time is generally possible with four, but gets a little bit more marginal with three.
There’s still few things more annoying than keying into a cab and finding you’re down an engine or two :(.
fair enough - that is quite impressive
It’s part of the reason they’re so reliable.
dk1
2 Oct 2009
East Anglia
I’ve ridden a few like that. Weirdly quiet in that vehicle but as they cross feed all HVAC and lighting works as normal from what I recall.
I’m surprised that family of trains never had the eco-power treatment like the 185s. Say shutting an engine or two down in areas of less gradient.
E B
30 Oct 2024
Nuneaton
On the topic of staffing and XC Voyagers, does anyone know why they have been appearing on the odd few Leicester services these past few days, instead of the usual 170s? Particularly in the evenings? Is there a shortage of Senior Conductors?
Are Voyagers still running on the odd Brum - Leicester service?
londonmidland
22 Dec 2009
Leicester
There were the odd few diagrams which produced a Voyager last week. I think it’s because there’s a Senior Conductor shortage, so it saves cancelling the service.
They can only go as far as Leicester, however.
Carlisle
26 Aug 2012
One of the reasons until recently might’ve been that Tilt was only possible with a maximum of one engine down
Peter0124
20 Nov 2016
There used to be a time when Glasgow had a regular (1tp2h) service down the East Coast with XC, now its just 2tpd each way in the morning/evening
JamesT
25 Feb 2015
The tilt on XC Super Voyagers was disabled in 2008, if tilt was a constraint on finding a more economical way to run their engines then stopped being an issue a long time ago.
NEDdrv
23 May 2016
Some Voyagers are fitted with IESS, with the rest to be done. Intelligent Engine Shutdown System will shut an engine down if timetable can be maintained. This is a replacement for the DAS system which is being removed.
dk1
2 Oct 2009
East Anglia
That’s very positive news. DAS is only good for the clock ;)
Mag_seven
1 Sep 2014
here to eternity
I think we will draw this discussion to a close now as it looks as if XC are not changing this policy any time soon. If anyone hears of a change in the policy then please contact us and we will look to reopen the thread. :)
In the meantime if you would like to discuss how you would like to see the XC overcrowding situation improve then please use this thread:
