Crossrail 2 on the Tube Map
Ali.Carr
17 Feb 2018
I had a go at putting Crossrail 2 onto the Tube Map. It's split into three sections, which you can see below:
QPH9uX2AXXdHoHSYcMoJiF-dJ0kkZTWcXjDhhsQYIAmp7134Qdv3Zkvc4dlKcQ_V-rj2GyygeIX8NGa5w21lzyRQzJg2pD7xo7nMI0FKv_fm4MJB3zamXO0RPLJyDWFjPTYm-IAJvafbyUiJWLHj71SuFHvNo32es_ITSWujpue21l8JtgU5Ycop9yIVjIg4Rb-zHEZTtusT78ztTSx-nimGrnoiKUy3X-BSTtTpzsp86p9LiBXH8bExxnyeG9CZ2yOTdp9pcWbT5GzgGVMd8rkrlK4lnylBDqg2h3hnwDLodvopedlEud5wLpnVJYAu5YMln9zBafXQ7yh_W3RJbM7Pemu0ep2KY2a6ZzA9qs-GTlOWUQLwYee9Q2jSA6xAeFY3p5iul7inOycTuCAjXyf_I0RKea8Te4I0nSE-yIanbQngIZXhLbOuUFCLiB_VT-4_MzP5sifPjdK_OK1tiptvoUJO2zrY3-dPlXLIPJk7oxMUtd4QfwIUZUAvaJa-3KuQtN1bZUwSc5ey25102TpbHxS98BQLsHe-iho-yPDEwqtNsTTG5ktsKO4T3oUeze51GgtYuY_ATAFovLybAkRNdNLfMx0JkuLd0byaOOdMLF_TgfeetcBz8iefzlKPdlCy-loeQJUA8qVxDM0RJmOv7SOItnYY=w1335-h921-no
GelHNc8vKy6C3lAoT6ipVITWlDr5D__CD4RM_O22uTKBOkjuQ-jmNYPtEue5dQytXmHAHD4XvbzSOav8vUigWsd7TjZStFmJCg68lZQn79_QqjHg7rm3VGcPJclx8GUNO80_XbTIMqfAKMx74QQGf3sP7ijrd9yBckgCgcbQP17RUHRO9UgXiKqR7NPE6i9BPCWeTz7ahrx3rn61_i3wMemI3cV7Tz3wSjEH_BNI2CSNBuwbBs54P5nxrI-YhwLyQZBI0XDY49JS9ccXJocN4TO2yBovqrLp61l01JDI7Cjiin_bSeS8kqrK5hBgHZS43bP6BGv8CoHQ0dUlhRvuMB1YIKZgZZcht5qZR6khH8FUUm_HsBY0M7y7aCYMeyVmuhnKY2dddHxW7xPQoGCdcdJa_Fn-W-KgXw67tkCiIJSlzfhRx9nW0wL0E9nIVNKcw0RLRlxyMGPJItA55rmu5-8M_kOiv3GabrpMAxWMkf06yubD05nkXx9IE6CjpWuhuIk01Waytt8IvRwDFUlxptxo2eNOKjxSR9g4Z-nsNjRoUOVDiZXMVgTj35bKyBBLoTkJq81pw6Xxx-qyy8nnlCzY_MwZddn74Kz0cDU-5mTBPIMCaSxi2pOyGKu3S1y3i1BMBNR2rxeqcteQRjaHnYulIPNBSuMI=w794-h921-no
i0fg5tB1sD4xbWlhFaUFzRaweday8lBy9WL3CUMqigl85KOfetoRirUElBznwQDGodHtgk5kVCZ4GkprVsbCQaMSygpgHVBxa98GmSID__RbFKM2l4tMPH2y2lYfCHW1JX7JmQkGv9nzMWSQNPMOotXT3j37SHZIF5yeW9ditgs7kXzcLA3w-elDcuL69uAeXj3tOJRo650JVSh6wPlNU7cIDuV45TPMoqZXbn7NTHBgizBvF21-3IFXBD75BS57h_bPJW9nCVQp1JnGnjLGYjg4RKUQzrwdeGXKbDkhfreOSCQ5vY3s_kIJ3GhVAdt5KrCjpGyE5_BCikbag8YOOLuo_Efzqqn0ZpNtotXgWk-Wg4vtZD6yc-kWx0LZzQzwgXOd4fV4TMtP1B5ZFZRnSXlyJ4jxs6F3zB1QdNXrpuGdlbhB1Fq7XEKsM9p2wbYjFmqJEPwTr-5XcuvmrWN-3Jc5O5VYhLMz-lDK4z0NS0MOAdv9yyrzMXaFPlQZVnjTctetNopqGum79Qq9JcHbJklkvbdDLIzXkohe48yInanPrGerpUk684AbjmxjEGVEsmWFeRhwWFw0i6UT1v53T6E4Y8JBdL3eWVJXXXXCr6b6nmXOdxmTgMcVnaBJ0q0wF9G8KY8k29sBLIBS8kFTbhyH9YUnzD0X=w736-h921-no
The maps are quite messy (the Overground in NE London is already spaghetti), and there are almost definitely errors. The likelihood of CR2 happening at all is quite low, let alone it having the route from the 2015 consultation. Even if it did, the rest of the Tube map would probably change unrecognisably as well by the time it's open (given how much the Overground has expanded in the last decade).
In spite of all these caveats, I thought it'd be quite cool to see CR2 in context. What do you think?
Edit: Subsequent to all of this, I made a full Tube map with CR2 (and some other stuff) on it, which found its way into the Evening Standard!
Class 170101
1 Mar 2014
Should Blackhorse Road not be a white wheelchair for London Overground as well? I believe its having lifts installed.
Also are we sure that an interchange is being provided at Turnpike Lane? I don't recall one being provided.
Cowley
15 Apr 2016
Devon
That’s excellent Ali. Thanks for posting it and welcome to the forum too.
Ali.Carr
17 Feb 2018
I don't know about the step-free access (I'm sure that that is where most of the errors are).
The interchange at Turnpike lane is based on this factsheet (http://crossrail2.co.uk/wp-content/uploads/2016/10/Wood-Green.pdf) which does refer to a Turnpike Lane interchange. I didn't map the Wood Green option, which looks like it was slightly less favoured after the 2015 consultation.
Class 170101
1 Mar 2014
Something tells me Turnpike Lane has been added tothe route via Alexandra Palace since I looked last year.
Ianno87
3 May 2015
Good map!
Notice you've just labelled "Dalston". That is the indeed the proposed name for the CR2 station (which will have interchange to Junction at one end and Kingsland at the other) - but don't believe there is currently any proposal to rename the existing stations.
The Ham
6 Jul 2012
A good map, Euston/Kings Cross/St. P. Station looks like it could do with being different to improve how it looks. However what that would need to look like I don't know, or even if it is possible.
IainG81
19 Mar 2017
It does pose the question in my mind why not just add on all National Rail stops inside the area. Places like Earlsfield and Hornsey just disappear. By that point when so many stations are included why leave of the few remaining?
Malcolmffc
19 Mar 2017
Bond Street and TCR should just have a blue wheelchair blob. The white blobs are due to the 92 stock not being fully accessible but these will have been replaced by the time CR2 opens.
It’s also clear that TfL is going to have to either drop accessibility information from the main map or introduce a separate Crossrail map - it’s unreadable with both.
jopsuk
13 May 2008
I know this will make it worse, but the 2015 CR2 consultation had the Stratford-Angel Road service (STAR) pencilled in as a 4tph all stations services Tottenham Hale-Broxbourne. I would envisage that that would then be an Overground service.
There's also the possibility that STAR or CR2 will go to Hertford East or Harlow Town
Ali.Carr
17 Feb 2018
Good map!
I assumed that the Overground stations would be renamed - thank you for pointing this out! I've now labelled the two Dalston stations separately. There'd be a case for having Dalston as three blobs, with CR2 going through the middle, but that might be overkill.
Green Park needs a blue wheelchair... :)
Thanks for these! :) I've updated the map.
You're absolutely right that E-KX-StP is a huge mess. I experimented with about fifteen different configurations (in fact this whole project sprung out of me trying to figure out how the E-KX-StP section would look), but I felt that the one above looked best. There could totally have been an optimal configuration I missed, however.
One of the main issues with the current map is the way CR2 and Northern cross over each other before Euston. I tried a lot of times to have Northern above CR2 (so that they'd then cross over again at Angel), but that meant a tight bend for the Northern Line, which was particularly unpleasant given it's the same colour as the connector outlines.
You can see three examples of configurations I tried below - if you reckon there's a configuration that might work better, I can totally give it a try! :)
Ali.Carr
17 Feb 2018
o_O Nightmare!
The Ham
6 Jul 2012
Thank you for those other options, others would probably disagree (as is fairly standard on here) however I would prefer the first of the alternatives.
Ali.Carr
17 Feb 2018
I liked the first option a lot - it avoids CR2 and Northern having to cross until after Angel, when things are less messy, and it saves on a blob at KX-StP.
My own reason for not choosing it was the way that the Northern and Victoria lines bend from diagonal to horizontal underneath a connecting dot (which I don't think has precedent anywhere on the actual Tube map) ... but perhaps it is worth being slightly less elegant in this respect, if it means saving on a crossing and a blob.
The likelihood of CR2 happening at all is quite low...
Ever? Or in the next 5 years? If the latter then I agree, but unless something major happens to change travel patterns into and out of London it's going to be needed at some point in the future.
Shaw S Hunter
21 Apr 2016
Over The Hill
The completion of HS2 phase 2, still targeted for 2033, will very likely mean the need for additional local distribution capacity at Euston becomes unavoidable though there are also concerns at just how the volumes of passengers moving through underground passageways will be managed. Crossrail/Elizabeth Line will have taken 9 years to build following a 2 year detailed planning process. The decision window therefore does indeed lie within the next 5 years.
As to the various "Eustons" I suspect that when the current Euston Square station gets linked directly to Euston (mainline/HS2) it will be renamed though what to I don't know. Perhaps Melton Street for Euston? This would allow the CR2 station to use Euston in its name, say Euston (Road?) Interchange. Early CR2 proposals talk of Euston St Pancras but where does that leave Kings Cross?
Ali.Carr
17 Feb 2018
Won't Euston Square be linked to Euston by this time?
Adding in Euston square makes everything very tricky. At that stage I'd be inclined to try something more radical - maybe remove all the connector lines and put Eustom King's Cross St Pancras in its own "interchange box", like below. I'm not sure if this is any clearer or is just an eye-sore.
