Crossrail 2
Crossrail 2, Metro or Regional
  • Metro option offering a high-frequency, underground service across central London
    Votes: 19 19.0%
  • Regional option connecting central London with areas to the north east and south west
    Votes: 81 81.0%
  • Total voters
    100
LE Greys
6 Mar 2010
Hitchin
But it is likely any resignalling work will set stopping distances to what modern EMU stock is capable of from 100mph.
Which is rather shorter than what modern EMU stock requires to stop from 125mph.
Probably true, but when was the line last resignalled? Also, somewhere with such dense traffic is a likely candidate for moving block operation, where a speed increase might end up reducing headways, but not by much.
As you say, and it's all academic unless they remove freight from the route west of Basingstoke. This was discussed only a few months ago with respect to why XC don't run at a decent speed on the SWML...
And there's this as well. Quadrupling any remaining double-track bits might be the answer here, but that gets a bit awkward through Winchester and Southampton Airport Parkway.
The Ham
6 Jul 2012
TfL has started consultation on Crossrail 2, if you want to have your say go to:
http://www.tfl.gov.uk/corporate/projectsandschemes/27405.aspx
Crossrail 2 would create a new high-frequency, high-capacity rail line running between south west and north east London.
Transport for London (TfL) and Network Rail (NR) are seeking the views of people in London and south east England on Crossrail 2.
Crossrail 2 replaces an earlier scheme known as the Chelsea-Hackney Line. Crossrail 2 would help to relieve congestion on both the national and TfL rail networks, and support economic development in and around London.
We are planning a route that takes account of future transport challenges facing London and south east England. It will include the opportunity to serve Euston as a terminus for High Speed 2.
Preliminary work has identified two possible routes: a Metro option offering a high-frequency, underground service across central London and a Regional option connecting central London with areas to the north east and south west. Both options share a similar route through the centre of London.
anthony263
19 Aug 2008
South Wales
Boris will be quiete pleased if he can get this signed off and the green light given before he leaves office.
Still lookslike it will be a great scheme for London
Chris125
12 Nov 2009
Metro - DLR style operation with 4 coach trains and 120m platforms. Up to 40tph.
Regional - As with Crossrail 1, 10 coach trains and 250m platforms. Up to 30tph.
Chris
Presumably DLR style in that each of the 4 'coaches' is a 30m articulated pair. I think they need to be clearer about this, or there'll be incorrect comparisons with typical tube train lengths of 7 or 8 cars...
I also think they've missed a trick by describing the regional option service as 'similar to National Rail'? If they want to give a more positive impression maybe they should have written 'like Crossrail 1'
Chris
I think the Regional option is probably far superior to the Metro option.... but that's just me.
(If we are going to bore a tonne of new tunnels, we might as well make them big.)
D365
29 Jun 2012
Back in February I recall "Regional" being the preferred option - built to Crossrail 1 standard with capacity for 32tph of 12 cars (x20 = 240m trains) - I reckon this is the better choice.
LE Greys
6 Mar 2010
Hitchin
I agree entirely. However, I'd like more details on the exact route between Dalston Kingsland and Euston, partly since the route looks as though it goes right past Essex Road, making a second possible interchange with the GN&C. Additional stops for (what will be by then) Thameslink services at Ally Pally would be a good idea, taking some of the pressure off Finsbury Park.
Morgsie
3 Jun 2011
Stoke-On-Trent
Why is both proposed routes taking a detour rather going straight from Euston to Ally Pally or Severn Sisters?
LE Greys
6 Mar 2010
Hitchin
Why is both proposed routes taking a detour rather going straight from Euston to Ally Pally?
They're probably trying to provide some 'outer circle' routes between radial lines, in this case the ECML, Piccadilly, Victoria and NLL, which currently only connect at Finsbury Park and Highbury & Islington. If this improves connectivity from the ECML to the north and east of London, I'm all for it. Just a pity we can't bring the Northern Heights Line back as well.
tbtc
16 Dec 2008
Reston City Centre
Probably for the same reasons that it's proposed to go via Tooting Broadway (between Wimbledon and Clapham Junction), its a combination of a box ticking exercise and trying to offer something different (since Crossrail2 would never be able to compete timewise between Ally Pally and St P with Thameslink).
Also a direct route could have obstructions in its path.
Remember the ground below London is probably best described as swiss cheese.
anthony263
19 Aug 2008
South Wales
One reason why I have been surpised they can build so many tunnels under London with all the current tunnels.
There is going to be a point where the ground simply cannot accomodate any more tunneling
philjo
9 Jun 2009
I think it would be useful if the Alexandra Palace Branch was extended further via Muswell Hill (an area which doesn't have a tube station) to either Finchley East or Central (& take over the Mill Hill East Branch?) or then go to Brent Cross/Cricklewood to link both Nothern line branches - maybe even go to Wembley. It would help with some of the east-west travel in north London without having to go via Zone 1/2.
D365
29 Jun 2012
Or any more people, perhaps. Nom, Swiss Cheese :P
Suggested many times as a 'modern Northern Heights' but as was mentioned earlier by jopsuk, there always (will) exists the possibility to extend from the proposed Alexandra Palace underground terminus - albeit, there exists a steep hill to the west, on the way to Muswell Hill. Mmm, TBMs...
A tunnel portal would be a major engineering job compared to a dead end underground station- which could be designed (as with several LU stations) to be relatively easily extended onwards should the opportunity arise.
bicbasher
14 May 2010
Essex Road is not on the proposed line for either option sadly, although I can see why Dalston Junction was chosen for that area with it's connections to the London Overground East London Line.
Why wasn't a tube option given instead of the DLR light rail operation? In that case, the Regional option is the better of the two considering the length of cars and stations served.
transmanche
27 Feb 2011
I think the major problem with that is the local geography. The difference in height between the existing Alexandra Palace NR station and Muswell Hill is about 70m. And they're proposing an underground Crossrail 2 station there - so the difference in height could be as much as 100m. I'm guessing only the DLR-style option would be able to cope with a steepish climb - otherwise any Muswell Hill station would have to be very deep.
In comparison, Hampstead tube station (the deepest below ground level) is about 58m below the surface - and as a result has lifts instead of escalators.
What surprised me is that the 'regional' option doesn't include a proposal to extend from Alexandra Palace along the Hertford loop - to Gordon Hill or beyond. This would seem to be a suitable way of 'dealing with' Hertford loop inner suburban services when Thameslink comes into full operation .
LE Greys
6 Mar 2010
Hitchin
The 'old' Alexandra Palace, which nearly got taken over by the Northern Line, was substantially higher than the current station (called Wood Green at the time) with no possible way to link the two together except via the old route through Highgate to Finsbury Park. In some ways, this is closer to replacing the Palace Gates line, which also went to Seven Sisters, so a missing link is being revived.
The Ham
6 Jul 2012
Regional route because it will relieve pressure at Waterloo
If you look at Chart 3 on the consultion it shows what a marked improvement it would have on Waterloo:
http://www.tfl.gov.uk/assets/downloads/corporate/24698-chart-3-nr-benefits-both-schemes.pdf
And although a few London stations would be a little worse off with the regional route over the metro, overall it is a large improvement on the existing situation and a fairly good improvement on just the metro option.
For the Regional over the metro it changes the proportion of passenger kilometres travelled in very crowded National Rail trains in 2031 for Waterloo drops from over 60% to 10% amd drops Moregate from 45% to 40%.
Liverpool Street goes up from about 25% to 27% and London Bridge looks like it goes up from 28.5% to 29.5%.
ntg
27 Sep 2010
Potters Bar, Herts
East-West rail is still the worst in North London so any improvement there is hugely welcome!
The North really needs a tramlink of its own to fix the gaps though. To travel the 4km from Harrow to East Barnet takes 90min by bus, or 70 minutes by train via central London. God knows why people harp on about improving transport south of the river.
YorkshireBear
23 Jul 2010
That link is very interesting. Not sure how they figure out no overcrowding into Kings Cross.
Also, the regional option looks far superior.
Aictos
28 Apr 2009
I believe the Regional option is better but extend Crossrail 2 to Gordon Hill and cut back the WAML plans to Enfield Town for starters before looking at extending the line further north.
I mean why just terminate Crossrail 2 at Hertford East? Why not also use Hertford North to terminate Crossrail 2 therefore if engineering has to take place on one route you still have the other branch you could use.
si404
28 Dec 2012
The DLR option is the tube option, only with automatic operation and larger trains than the typical tube. It's really not 'light' rail, what with up to 160 2-car units an hour (coupled into 4-car sets that are similar in capacity to 8-car tube trains...). TfL's analogies have been poor - choosing 'National Rail' as a descriptor of the service for the Regional option, rather than Crossrail. Same here with DLR instead of tube.
1)how would you provide GN&C service with no Hertford loop?
2)how would you get a decent interchange at Ally Pally and surface onto the Hertford loop, and serve Turnpike Lane. The plans for Ally Pally would have roughly E-W platforms to stop the curve being too tight.
3)All Hertford service on one route? Why would you want to do that.
If you had to take one branch of the ECML locals for Crossrail, it is surely the Welwyn GC one. However, what purpose would taking either actually serve? And at what cost?
That Moorgate drop is partially due to a small number of people taking the all-stops-to-Tottenham Hale Crossrail 2 service from Hertford East, rather than change at Ally Pally. Only a small percentage of people are that silly!
And what if the core section needs engineering works? Hertford is cut off! Hertford is currently blessed with two lines to London, there's no purpose in removing that. After all if one route has engineering works, you can still take the other route...
TransportUK
14 May 2013
I think the regional option has got to be the way forward. Crossrail2 is looking at about a 2030 completion date. In this time, I think the significant growth in London will take place on the outskirts. As such you need much better systems to bring people in from these areas. The Crossrail2 regional option should help with this.
ntg
27 Sep 2010
Potters Bar, Herts
I cynically winder if this is because TfL would prefer to national option and wish to weight public response in this direction - assuming the public do indeed prefer a full national rail style service as opposed to a DLR style one.
transmanche
27 Feb 2011
Given a fantasy pot of money, extend the DLR from Bank to Moorgate where it takes over the Northern City line to Finsbury Park and then extended onto a rebuilt Alexandra Palace branch via Highgate.
Realistically, the section north of Alexandra Palace would continue to be served by some NR trains (just as the suggested extension to Hertford East). A lot depends on whether TfL wants (part of) the Hertford loop to be incorporated into its network or not - either as Overground (as suggested by others here) or Crossrail 2.
Easily. I think you're reading a lot into a diagrammatic map to infer that the platforms at Ally Pally will be aligned E-W.
