SQRT(0)Just think how much concrete they would have saved as well?
Heavily subsidised bus fares.I don't think Khan's re-election depended on delivering Crossrail. He's 25 points ahead of his nearest rival in the polls.
Hey, remember the May 2019 tube map cover?
It will end up being called the George Line at this rate.
What possible influence could a local politician such as Khan have on a railway project, the critical path of which is getting signalling software to work?Mayoral elections deferred for a year so Khan will have another 12 months to get it sorted
https://www.bbc.co.uk/news/uk-politics-51876269
Although I've made similar statements to that in the past, it has been pointed out to me that the Siemens system in use with Crossrail would have had similar issues even with Siemens rolling stock as it is a new iteration of design that has not yet been used elsewhere.The "Local Politician" who made the decision to purchase Bombardier trains for Crossrail had a massive impact on the projects ability to deliver on time and on cost. Crossrail Ltd had sometime previously decided to buy Siemens signalling systems for the Central Section. The delays incurred by selecting trains with a Bombardier signalling system and then having to interface the two different systems together is the debacle we now have, selecting trains with Siemens signalling would not have presented the same problems. The "Local Politician" was, of course, the Mayor of London. Not Kahn but his predecessor, Johnson.
How would Johnson or any other politician have the faintest idea about what was involved in these issues?
Quite so. Surely it would have been Hendy's job to guide and advise the Mayor. What a politician may have contributed is considering building the trains in Derby instead of Germany.How would Johnson or any other politician have the faintest idea about what was involved in these issues?
It seems impossible, at least at the time of writing, to tell from Realtime Trains what test trains ran in the west today: https://www.realtimetrains.co.uk/search/detailed/PDX/2020-03-15/0000-2359?stp=WVS&show=all&order=wtt
Did any members see testing taking place? Is the test service intended to be as frequent as what's shown on Realtime Trains?
I generally agree but more from the point of view of the trains themselves rather than necessarily the integration. An all-Siemens setup may well have saved a fair bit of time, but I think mostly because software remains something Bombardier have disproportionate difficulty with. The 7-car 345s that do not have any of the complex signalling equipment that they will ultimately need for Crossrail ops, were introduced shortly prior to the 707s at SWR - around 2 months beforehand. The 707s were of course more delayed than the first 345s, but both pale in comparison to subsequent Bombardier fleets like the 12-month late 710s and now 20+ month late 720s. Two years after their introduction the MTIN figure for 707s is reliably above 100,000 despite the short stopping services they operate. In terms of failure rate per days in service, they are probably the most reliable trains the UK has ever seen. The 345s on the other hand are languishing between 5000 and 10,000. Borderline acceptable, but vastly below that of their effective Siemens counterparts - I have chosen the 707s specifically because I'm aware 700s and 717s produce far lower figures but also carry out power mode changes which 345s do not. I will also concede that 707s also are only half the length of what 345s ultimately will be, but that alone would not account for 10-30x the reliability score.
One does wonder - what if the 7-car 345s were as reliable as 707s? What effect would that level of reliability have on the pace of the Crossrail rollout? One can only wonder.
An important point, even though unknowingly at the time, it ultimately didn't matter. It wasn't obvious the Bombardier trains would be delayed by software issues until well into the period when all the other infrastructure issues had already started. The 345s themselves weren't really that late at all.3. Siemens withdrew from the Crossrail rolling stock bidding as they couldn't actually build the rollings stock in the required time frame and had bet everything on the Thameslink requirements and Desiro City design being similar enough to also win Crossrail. The Crossrail requirements had moved on so Siemens would have had to redesign to win the technical criteria. They tried to push Krefeld (late 1890's tram factory) too hard and ran into problems on other stock built there (e.g. Eurostar Velaros)
and if that's the primary reason for the difference it's terrifying. The difference in performance is vast. However, to my knowledge, the 7-car 345s don't yet have ETCS do they?1. 345s, 700s and 717s all have one common feature - ETCS being the core signalling system with other being subservient to it. A big change from what went before.
Of course but if one fleet has software reliability issues the other fleet doesn't have, the only TINs for the other fleet will be serious faults that take time to resolve rather than just rebooting the train. I totally understand your point here but unless the TIN count * DPI figure is similar, which I don't believe to be the case, then I don't think it's all that relevant.2. Have a look at DPI (delay per incident) figure as well as MTIN. Bombardier's average is lower than Siemens. When you combine the 2 and train mileage the picture is interesting. MTIN isn't everything. Low DPI helps reduce reactionary delays.
Crossrail were pretty clueless on systems integration generally and seemed to assume it would happen by magic! The current delay is somewhat putting time that was needed into the programme that they didn't in the first place (see quite a few of the same people on JLE in late 1990s, they ended up fitting manual signalling and letting LU resignal later!).An important point, even though unknowingly at the time, it ultimately didn't matter. It wasn't obvious the Bombardier trains would be delayed by software issues until well into the period when all the other infrastructure issues had already started. The 345s themselves weren't really that late at all.
So why are third rail trains more reliable than 25Kv trains? IIRC modern third rail trains use AC motors rather than DC as the older ex Southern region slammers did.I suspect the reason the 707s do so well, just like their generations of predecessors, is running just on the despised (by many here) third rail, instead of 25Kv.
Thanks for supplying the DPI data - so the Desiro City is almost identical to the Aventra's anyway then. I suspect if you took just the 707s with their much higher MTIN, the DPI figure would look more like that of the Desiro UK instead. Either way, double the DPI does little to counteract 10-20x the MTIN!Crossrail were pretty clueless on systems integration generally and seemed to assume it would happen by magic! The current delay is somewhat putting time that was needed into the programme that they didn't in the first place (see quite a few of the same people on JLE in late 1990s, they ended up fitting manual signalling and letting LU resignal later!).
A few quick numbers:
DPI (decimal mins) - MTIN
Electrostar All - 12.9 - 50k
Electrostar Mk1 - 15.4 - 33k
Electrostar Mk2 - 9.6 - 73k
Aventra 10.7 - 3.5k
Desiro - 22.5 - 54k
Desiro City 11.7 - 33k
The post you're quoting seems to have disappeared but indeed, all Desiro UK classes (except the 360/2) had very high scores, AC or DC. DC is nowt to do with it, simply that 707s aren't incumbered with the various technologies the 700s/717s have.I suspect that’s a causation fallacy
Sadiq Khan is seeking to renegotiate £2bn of existing loans with the government in order to borrow an extra £650m to deal with fresh cost overruns on London’s delayed Crossrail line.
The capital’s mayor told the Financial Times that the city authorities were locked in talks with central government on how to cover the extra financial hit to Transport for London caused by the failure to deliver the project on time.
The budget for the 73-mile, east-west London rail line was originally put at £14.8bn in 2010 but had reached £17.6bn by December 2018 and now stands at £18.25bn.
