NorthKent1989
- Joined
- 13 May 2017
- Messages
- 1,914
which is the frequency Anerley and Penge West had before.
To London Bridge yes, now they have zero trains to Central London.
My point being that the frequency to LBG is the same as before, I agree you have to change at Sydenham which adds 7min.To London Bridge yes, now they have zero trains to Central London.
If what is going to be happening had been proposed for Richmond, Harrow, Ealing or Barnet, let alone Islington, Hackney. or Camden, the Evening Standard would be fulminating and questions would be asked in Parliament. As the Mayor can't get bashed over any of it and is (justifiably) able to say it's out of his jurisdiction and therefore control, it just shows what a fundamentally flawed transport 'system' we have in the capital city.
The only thing I'll say about Woolwich to Lewisham is that I'd be amazed if the route doesn't survive in the offpeak, with the influence of some Blackheath residents and travellers combined with Charlton's rise in the pecking order. The latter must be a far cry from when I used to visit the Valley in the late 1950s and chomped on Percy Dalton's salted peanuts with our whippets in attendance!
The Charing Cross to Maidstone East service is hourly on Saturday. Timetable is not fully in RTT yet.Having a look at the Maidstone East line's Saturday service, there appears to be an hourly AFK-VIC all day, with a few early morning MDE-CHX and then a few late evening CHX-MDE trains to bolster it. I can see this frequency going down badly, considering SE currently deem it worth running 2tph all day on Saturdays, which is more frequent than weekdays.
That makes more sense, thank you for confirming.The Charing Cross to Maidstone East service is hourly on Saturday. Timetable is not fully in RTT yet.
I've been puzzling over this one. If not Charing Cross that leaves Cannon Street and Victoria as destinations. The Former would surely not be much faster than the next Greenwich Train. The latter would introduce another conflicting move at Lewisham and 8 car carriage restrictions at Nunhead, Peckham Rye and Denmark hill (presuming they stopped there). Still would leave both North Kent and Bexleyheath lines with a West End destination, East London Line & Hospital access at Denmark Hill and 4 tph Victoria service at the 3 busy Stations mentioned (in addition to Blackheath & Lewisham).There is another service that will cover Blackheath to Charlton.
I honestly don’t see any Woolwich line trains going to Victoria, but I can’t see why there can’t be a Charing Cross service, they haven’t removed the conflict if there’s still 2tph making that move, 4tph wouldn’t exactly hurt the reliability.
I'm not sure why they didn't change the service to only use the crossover in one direction instead, allowing Charing Cross/Victoria to Bexleyheath/Woolwich (P3/4 at Lewisham) but preventing Cannon Street to Hayes (P1/2 at Lewisham). This would drastically simplify everything while still removing a lot of conflicts.
This allows Victoria to the Bexleyheath line and Charing Cross to the Bexleyheath and Woolwich Lines to continue as now.
Cannon Street to Orpington and the Sidcup Line can run by avoiding Lewisham (and I would have these services skip New Cross and St Johns), and Lewisham connections would remain on Charing Cross services.
The only current service this would prevent is Cannon Street to Hayes.
There are no Cannon Street's off peak from Lewisham Platforms 1 and 2.It’s bizarre that the lines that can literally avoid Lewisham to either Charing Cross or Cannon Street, will still get the option of both terminals, yet the lines that have to go through Lewisham are having their options limited to one, the Hayes line will lose Cannon Street but I’m not seeing any complaints at this as much as those from those who use the Woolwich and Bexleyheath lines at losing Charing Cross off peak.
Personally the Victoria’s should be from with Sidcup, Grove Park or Hayes, with no Cannon Streets from Lewisham P1&2.
Apparently it’s Cannon Street, with the service rumoured to start from Gravesend (presumably to give Gravesend 4tph to the CrossRail connection at Abbey Wood) if this is the case I can’t see it making stops at St. John’s and New Cross, they may run it fast from Lewisham to LB.
IIRC pre all the London Bridge works Charing X took 16tph, the main issue with that timetable was capacity at London Bridge.Is there room at Charing Cross now? the new timetable off peak has 16tph leaving Charing Cross and calling London Bridge whilst the current has 15.
Surely the capacity problem at London Bridge which the changes were meant to solve was the fact that Thameslink couldn't fit in at peak times because of ChX trains using all the 2-track capacity west of London Bridge. Now the extra bridge is in place, and there's 4 tracks west of London Bridge (to allow T/Link to run in parallel with the full ChX service), that problem is solved. The London Bridge works haven't done much to increase the maximum possible ChX services since the bottleneck was the two-track section as much as platforms at London Bridge itself. The doubling of the two-track section still only leaves one pair for ChX services. Maybe if, with the new layout, there weren't so many T/Link trains running that way (eg if lots more went via Elephant instead), then there could be more intense ChX service before the terminus itself became the capacity constraint? But as it is, you wouldn't expect the London Bridge changes to have had much effect on the maximum possible ChX services.
As ever, the capacity constraint is not the two track section, which can and does take 28 trains per hour each way, but platform capacity at Charing Cross and getting 28tph to London Bridge from the ‘country‘ side ie through the Lewisham / Tanners Hill complex.
London Bridge very much is Central London.To London Bridge yes, now they have zero trains to Central London.
I honestly don’t get all the fuss. People change trains all the time. So long as the timetable is reliable enough to support good connections, there shouldn’t be an issue.
London Bridge has been upgraded to support increase interchange traffic. If it removes junction crossings by making them have to change in Zone 1, so be it.
I’ve just been to Vienna, and the main station is 3km from the centre. It’s less than half that for LBG.
Changing trains can add on journey times and can cause delays if a connection is missed.
I’m very aware London Bridge is a central terminal, The point i was making was that Penge West & Anerley are about to lose those trains and become London Overground services only.
Which is why you design the timetable in a robust manner so delays don’t spread!
Service groups should be kept separate. Trains to everywhere only benefit a limited few.
Most parts of the country would love a service with the frequency of the Overground.
Canada Water has the connection to the Jubilee Line. Shoreditch High Street offers many of the same walking distances as London Bridge.Don’t use the “other parts of the country would love this that the other” to justify loss of a direct service to a London terminal, Islington isn’t London Bridge.
They were withdrawn in September, was 2tph all day previously. All dumped on LO who have no extra capacity to provide, the peaks are a mess.There appears at present to be one train per day from Penge West and Anerley to London Bridge at about 0530. Not exactly much of a loss!
And to top it off the “connections” into London Bridge services are as bad as they could possibly be at NXG, in both directions where GTR have decided to run.
Anerley and Penge West have already lost their direct service to London Bridge and to East Croydon other than a few early morning/late night trains. I think most people would rather keep the Southern service and curtail LO at New Cross Gate.I’m very aware London Bridge is a central terminal, The point i was making was that Penge West & Anerley are about to lose those trains and become London Overground services only.
Charlton is going to last and people will exist happily without Charing Cross trains.I’m very aware London Bridge is a central terminal, The point i was making was that Penge West & Anerley are about to lose those trains and become London Overground services only.
Even the most robust timetables there can be room for delays and error, I think the formula of mixed CX/CS trains in South East London has been a massive benefit for the area for generations, so I don’t know how you can say they’re limited to a few, in fact this new timetable benefits a few
