December 2023 Timetable Change
29 Aug 2010
Does XC still make a couple of Crewe calls, or have some returned this week?
It's still one south (6am), one north (8am) in the morning, usually with the same driver, although the northbound was cancelled & ran empty stock this morning due to no New St guard.
Notably, they've been doing an Avanti when the Stoke route is shut for works or disruption, passengers for Macclesfield are forced onto a replacement 90-min bus ride at Stafford with XC refusing to stop at Crewe - a reasonable alternative, with the train pointlessly rolling through the platforms at around 10mph. They could also stop at Wilmslow with no impact on other trains, but again refuse to.
They don't refuse, the amended paths dont always allow it.
Baji
30 Apr 2023
Sutton
On the London Victoria to Dorking/Horsham line, the following trains on Saturday will be increased 10 coaches.
Departing from Carshalton:
08:45
12:15
14:45
18:15
20:45
Departing from Victoria:
07:11 Dorking
09:41
13:11
15:41
19:11
21:41
This is from the information is from this link
I caught the new direct train from Normanton to Manchester Piccadilly yesterday. I was quite impressed at how well used it was, given it avoided Leeds. There were plenty on board, with a handful of people joining at Normanton and a few more than that joining at Wakefield.
Another real benefit of this service is the 21:58 direct train back from Piccadilly to Wakefield Kirkgate. I presume this used to be empty to Crofton from Huddersfield previously, however having this as a service train makes getting back to the Wakefield area a lot easier from the West. There were quite a few people detraining at Wakefield as well.
Bikeman78
26 Apr 2018
Its a bit tight at Wilmslow with the TfW behind it. It clashes with the Edinburgh Euston via Birmingham if it stops at Crewe.
Why run via Crewe if it doesn't stop there? Why not run via Stoke in the standard hourly pattern? As mentioned, it used to provide relief for the TfW train. I think Crewe was taken out during Covid and never put back in.
jfollows
26 Feb 2011
Wilmslow
See my post 953 above, it’s to enable an off-pattern rush hour stopper to run to Macclesfield (and Stoke). A down morning XC service goes via Crewe for a similar reason. The additional stopper (2K50 17:18 Piccadilly to Stoke) calls at Bramhall in the up direction at the time the standard hourly XC would normally be passing.
Bikeman78
26 Apr 2018
Fair enough. Still makes no sense to omit Crewe and dump all the passengers on TfW.
Topological
20 Feb 2023
Swansea
In that regard, do the CrossCountry trains have capacity?
It would be more useful if they could make Wilmslow pick up only heading south on TfW in the evening peak (set down only towards Manchester in the morning peak) and then that would make a bit more space for the Crewe passengers.
As a regular user of the TfW train, it is frustrating how busy the train gets with commuters not actually traveling that far. Would be even worse if I was getting on at Stockport and planning to travel past Crewe.
Bikeman78
26 Apr 2018
On Merseyrail, the Southport line has been retimed. Previously one train arrived four minutes before the previous diagram departed. Now the trains sit at Birkdale for three minutes and then have two minutes added for the journey to Southport, arriving after the other train has departed. Seems odd to slow down the schedules just before the new trains arrive. The old timetable seemed to work okay.
Bikeman78
26 Apr 2018
It can't stop at Crewe as I said, it clashes. It has to get in front of the Avanti.
It has pathing and performance time all the way from Wilmslow but it doesn't appear to be following anything. It passed Crewe several minutes early yesterday.
OneOfThe48
6 Mar 2023
08:45
12:15
14:45
18:15
20:45
07:11 Dorking
09:41
13:11
15:41
19:11
21:41
This seems like 'old news' the MP has just got round to putting on his website
Thomas6187
27 May 2011
Rochdale
It normally following the 17:06 Manchester Piccadilly-Crewe. That service gets looped at Sandbach to let both the XC and TfW pass. Yesterday it was early because the 17:06 running 17 late by Stockport it passed it there instead
It does, but a Crewe stop is 2 minutes minimum. As noted above, it follows 2K51 which it overtakes at Sandbach on headway, so it can't go any earlier there. It has engineering allowance you cannot remove and 3 minutes allowance remaining. As noted, 2 go on the dwell, 1 won't be enough to cover the stop. 9M86 then follows it on headway down to Doxey.
Bikeman78
26 Apr 2018
Why wouldn't one minute be enough to stop and restart, assuming two minutes dwell? The speed through platform 1 is not very fast. Anyway, how did it stop until three years ago? Has the timetable changed significantly?
jfollows
26 Feb 2011
Wilmslow
In the May 2021 timetable, 1O68 17:27 Piccadilly-Reading was 18:05 platform5 18:07 FL at Crewe. It followed 9M86 14:53 Edinburgh-Euston which was 17:59-18:02 platform5. The following booked FL service was 1A60 17:47 Liverpool-Euston at 18:22-18:24 platform5.
Today 1O68 is 18/02 platform 1 passing Crewe with 9M86 18:01.5 - 18:05 platform5 behind it.
The timetable has changed.
It's nothing that couldn't be fixed with a little flexing. But Avanti are very uncooperative about such matters, insisting on maintaining "clockface" departure times even though their "clockface" pattern has all sorts of exceptions when it suits them.
jamesst
4 May 2011
Merseyside
That was the autumn timetable which on Merseyrail is carried over into December, see also the amended pattern on the Chester/ Eport lines.
The normal timetables return from December 27th.
Depends if XC also want the stop, they certainly don't when diverting for a Stoke block.
Bikeman78
26 Apr 2018
How have I got through all of autumn without noticing this? It seems that in reality a lot of trains just depart Birkdale early and make it into Southport before the outbound train departs.
Jamesrob637
12 Aug 2016
Did the Northern train via Derby ever return? I seem to recall that it was a Nottingham to Sheffield service.
Sporty60
5 Aug 2019
I'm a relatively new and passive member of this excellent forum so I'm sorry if this question has been raised before.
At the next timetable change is it possible or indeed desirable to have different threads for each train company?
I realise that there might be some crossover but it would avoid Devon based people such as myself trawling through to find content relevant to their own location.
Or am I just being lazy and selfish!- be honest!
FenMan
13 Oct 2011
Good question! My answer is "no". People focus on their local train service of course, but local changes can have a bigger impact for those making longer journeys.
To provide an example, I'm a Farnborough football fan who lives close to Blackwater station. We play in the same league as the likes of Welling, Dartford, Chelmsford and St Albans and our clashes can be scheduled for Tuesday nights. I used to be able to go to these games on a Tuesday and get home with no issues. But not now.
My journey was comprised of three legs: get back to Waterloo, catch the 2315 to Guildford on South Western, then the 0001 to Blackwater on Great Western.
But, the South Western cutbacks post-COVID means the 2315 no longer runs M-F, even though, in my experience, it was always full to bursting as far as Guildford (due to theatre goers etc). Unfortunately for me, the current 2300 to Guildford is just too early.
I get it this is an edge case, but it is illustrative how small changes to one TOC's schedules have a knock-on effect across the network. So I now drive to midweek away fixtures - maybe that's the plan?
70014IronDuke
13 Jun 2015
ABSOLUTELY AGREE 100%. Mods - please note the post above.
I meant to do a post like this years ago - I forget if I ever did.
I fully understand that eg SWT TT modficiations between Surbiton and Alton (or whatever) affect a lot of people, but I just stop reading the thread, because I have never got to good grips with the myriad of southern routes.
