GC class B1
The confusion may be my fault. A wheelset (2 wheels on one axle) rotates as one entity. The BFCB arrangement operates by pushing the brake blocks against opposite wheels on each bogie. Both wheelsets are braked and a force applied by the brake rigging applied roughly equally on both wheelsets of the bogie.Surely if one wheel on a fixed axle were to stop rotating the opposite wheel would also. Or am I missing something?
RAIB didn’t find any other cause of the initial brake drag than a normal brake application in low adhesion conditions. What I find not credible is that the wheelset with the initial flat didn’t recommence rotating when the brake application was released. I can’t accept that the initial flat prevented the wheelset rotating because of the lower centre of gravity of the wheelset with the flats. The dynamics of the bogie suspension and variations in the track geometry would have reduced the wheel loading sufficiently to allow the wheelset to start rotating again at some time during the long distance during which the flat reached the length found. I find this explanation incredible.The absence of any damage to the other wheelset is strong evidence that there was no brake fault causing the brake to lock. I agree RAIB's suggested sequence of events relies on a certain amount of supposition, but they seem to rule out all other possible causes.
