Derby Telegraph "Plans to convert Monsal Trail back into railway takes 'significant step forward'"
Killingworth
30 May 2018
Sheffield
Maybe so - but the the virbation caused by a couple of hundred pedestrians and dozen cyclists and a couple of horses a day is miniscule compared to a couple of trains a day - and that vibration is the thing which would start to dislodge masonry or damage pointing for example.
To make a compelling business case you'd need to be planning for nearer 20 long trains a day, not 2. That's a lot of vibration and must be well beyond the level the line was originally designed for.
We are talking about structures and earthworks that were never built for 25-tonne axle loads in the first place and have been gradually degrading for over 50 years. Now we are expecting them to support millions of tonnes of limestone and cement per year at fairly high speeds from day one.
Have you seen how many rabbit warrens there are in the embankments?
Your expectations are quite off. An 0.08t load travelling at 2-3mph will impose negligible forces on a bridge compared to a 20t+ axle load travelling at 60mph.
The bridge carrying a footpath will make inspection easier than if it was completely closed, but that's about it.
There are thousands of these structures and earthworks on the national network that are maintained for rail traffic.
An existing structure can surely be brought up to speed.
Bristol
Yes, of course it can. For a cost.
Not necessarily, and even less likely to be a significantly less cost than an old bridge that hadn't had a footbridge.
Well, if we accept these costs for existing lines, perhaps we ought to for reopened ones.
Because it doesn't. Swindon - Kemble was a bottleneck in its own right and prevented increasing services against passenger growth on that line which was being seen.
The schemes you usually peddle are for reinstatements of long dead lines with the "and they offer diversion options" where such options are not realisable for a benefits case and the scheme overall is a basket case.
Swindon - Kemble was fairly cheap in the scheme of things
That was for 12 miles back in 2014 - but it shows the fundamental difference between upgrading an existing line and rebuilding a long defunct line - Swindon - Kemble being about £4m / mile, whereas the Borders Line cost more than double that (£350m / 35 miles = £10m a mile) and I'm pretty sure @Bald Rick will confirm the total cost of Borders was even higher.
This is absolute poppycock.
The schemes I support are primarily for providing new markets, such as mid-Devon (Tavistock and Okehampton) or the Uckfield line (mid-Sussex/Kent to the South coast.
Diversionary capabilities are just the cherry on the cake.
A lot of earthworks would have to be outright dismantled and rebuilt from scratch.
A0
19 Jan 2008
Well, no. Both are long dead lines and you usually cite "diversion" as a benefit, so you'll have to try harder.
As for "new" journey opportunities, I'm not sure Okehampton (popn 6k) and Tavistock (popn 13k) have huge demand for travel between them - the hourly bus more than suffices.
The Uckfield line doesn't really serve anywhere significant en route to Croydon - Crowborough is 20k - Edenbridge & Oxted are large villages. So where this supposed demand for travel south of Uckfield from places between Croydon and Uckfield comes from, I'm not sure.
And to get back to the topic, you've not demonstrated demand for travel between Matlock and Buxton either and certainly not enough to spend a couple of billion on a rail reopening which has yet to demonstrate a viable business case.
Mr. SW
13 Sep 2023
Armchair
Was much infrastructure trouble found when they reinstated the Borders Line? It was closed a little later than Matlock-Buxton.
Some bridges had to be reinstated, but was there any undue problem with the soft infrastructure?
This isn't an attempt at digression, just for comparison.
Killingworth
30 May 2018
Sheffield
Certainly not as many tunnels or bridges/viaducts on the Borders line
daodao
6 Feb 2016
Dunham/Bowdon
I disagree. Along with the re-opening proposal discussed in this thread, these so-called "missing gaps" are the re-opening schemes of least value/benefit, because they are the "watersheds" between geographic economic areas where potential traffic is least. It is far more beneficial and cheaper just to re-open a section of a former through route providing local traffic links into a major conurbation rather than the middle section that is likely to be devoid of significant traffic.
In this case, the line from Buxton to Manchester. an alternative line from Chinley to Manchester, and the line from Matlock to Derby, were never closed, and the Manchester South District line has been re-opened as far as Parrs Wood as a Metrolink line. The case for re-opening from Matlock to Buxton/Chinley is very poor. Similarly, in the case of the former LSWR line from Exeter to Plymouth, Plymouth to Bere Alston was not closed, and there is reasonable potential to re-open as far as Tavistock; Exeter to Yeoford was not closed and the line has now been re-opened to Okehampton. However, the case for re-opening from Tavistock to Okehampton is also very poor.
Killingworth
30 May 2018
Sheffield
I'm not in favour of re-opening a railway over the Monsal Trail however this digression does prompt a thought.
In the era of closures the Woodhead line was closed with the section to Hadfield retained. The Hope Valley route was kept open with an hourly through passenger service. The stopping service was cut in two, to Chinley or New Mills from Sheffield and similar from Manchester but infrequent. By 2010 rail recovery was well under way with 2 fast trains an hour and the stoppers running through almost hourly.
In 2013 the just completed capacity sheme was being promoted to create 4 fast paths plus a stopping and freight paths. By 2015 that was reduced to 3 fasts and now it's complete it still hasn't produced a 3rd fast service.
Two lessons from that.
The improved end to end service has attracted more stopping traffic, the overlap from both ends to Edale and Grindleford at its core. But the stopper is fulfilling much of the role of the missing 3rd fast service. This experience may give support to a reopened Peaks and Dales developing new traffic flows between Derby and Manchester
The current inabilty to feed an extra service into Manchester reminds that limited investment funding needs to be focussed where it's most needed - to assist services that are already running.
daodao
6 Feb 2016
Dunham/Bowdon
The services in the Miller's Dale/New Mills/Chinley area pre-1967 basically comprised:
  • Express services from Manchester Central to London, many of which called at Chinley (historically there were also connections into these trains at Chinley from Liverpool Central via Timperley and from Blackburn via Manchester Victoria) and/or Miller's Dale
  • Local stopping services from Manchester Central to Chinley via Stockport Tiviot Dale
  • Local stopping services from Chinley to Buxton, running to/from Manchester Central via Cheadle Heath at peak hours
  • Local stopping services from Chinley to Matlock and Derby
  • Local stopping services from Buxton to Miller's Dale, of which a few were extended to Derby
  • Local stopping services from Chinley to Sheffield Midland
  • Local stopping services (ex-GCR) from Manchester London Road via Reddish North and New Mills Central to Hayfield
There wasn't a regular through passenger service from Manchester to Sheffield via the Hope Valley line. The services on the remaining lines were completely re-organised with closure of the Midland main line via Didsbury and Peak Forest, the Woodhead line and the Hayfield branch, to all passenger traffic over the period 1967-1970. The creation of a through stopping service from Manchester Piccadilly to Sheffield Midland via the Hope Valley line was an operating convenience to reduce the number of trains terminating at New Mills Central and allow Chinley station to be rationalised completely down to the mere halt that it is today.
jimm
6 Apr 2012
Bit in bold - Moreton in Marsh (about halfway along the Cotswold Line) is 90 miles to London, whereas the full Derby - Manchester distance is only 60 miles (Derby - Matlock is circa 20 miles), so much of the Peak Line less again.
And Manchester is an economic "pull" in the same way London is.
I'm well aware of the distances involved. So what if it's 60 miles. Are people in Derby (or Matlock) suddenly going to start flocking to Manchester all the time should this railway reopen? I don't think so.
Try buying a house near one of the stations along the route. Plenty of full fare and first class tickets I imagine.
I listened to the Transport debates about this and am aware of the influence MP's from Oxfordshire and its environs have on policy.
I still think that there is a relative case for improvements here, short of relaying Bakewell - Peak Forest, and that passenger custom will follow, not preceed service quality.
WAO
Imagine whatever you like. As I said, people in this area aren't all made of money, me included. Like most other places, first class travel on the Cotswold Line has declined, as has peak commuter and business travel using full fare tickets, while off-peak and discounted travel is booming.
So MPs stood up in the Commons and made some noise and wrote letters to ministers. At the end of the day, the only thing that mattered was whether Network Rail could persuade the DfT that the business case stacked up.
The Network Rail analysis of the causes of GWML delays that I mentioned took place in 2007-8, about three years after NR had stated plain as day that it did not see any financial case for redoubling. Ultimately, the change of mind triggered by that analysis was what tipped the balance and made the case for the investment, not speeches by MPs.
A0
19 Jan 2008
You cited "proximity to London" as an explanation for the Cotswold Line usage, I pointed out Manchester is less of a distance, but the important part you overlooked were my previous posts where I'd compared the Cotswold Line usage to *The Hope Valley* line's current usage. If the Hope Valley doesn't achieve similar usage to the Cotswold line running through a similar area to the Peak Valley, despite connecting Manchester and Sheffield, I fail to see why the Peak Valley will attract usage.
furnessvale
14 Jul 2015
Any evidence for that assertion? Sections of the proposed route, built to the same standards as the closed section, have continued in use for heavy freight trains to this day, with no significant expenditure on renewing earthworks etc.
Only a proper survey can confirm or deny that fact.
A0
19 Jan 2008
I'd have thought the Borders Railway - which was abandoned for a similar period of time would give some indication of the extent of works required - which was fairly extensive, certainly more than the reinstatement of the Blyth line for example.
Killingworth
30 May 2018
Sheffield
Each line will have its own characteristics. The Blyth line's level crossings were a nightmare for motorists 50 years ago. The new Newsham flyover must have added fairly extensive work to that project - on a line that was still active.
Railperf
30 Oct 2017
I've just spent a week in the peaks. The poor rail connectivity means a car is essential. and there seem to be plenty of local buses. But vilages such as Bakewell get very busy. From a tourist point of view - the Buxton to Matlock missing link would provide much needed travel options along the Derwent / Wye Valley corridor. It is a shame that places such as Ashbourne are no longer connected by rail. Having travelled aroud some beautiful parts of Switzerland on the metre gauge railways, i wonder if we are missing a trick by not considering reopening some of these lines as a self contained network with the narrower guage and lighter stock. These could be maily single line with passing loops strategically positioned to allow passing movements. Does matlock to Buxton need to be standard guage heavy rail? All this talk of rerouting freight etc along these lines seems to increase the cost. Could reopening these lines as light self contained railways work?
I can only guess this sort of idea will be shot down in flames from many angles, but if we are going to do it at reasonable cost, then could metre guage work, with dual gauge where required from a strategic point of view, as happens in switzerland? That would make extensions more feasible ..such as Rowsley to Grindleford, as the metre guage seems to be easier to work around the contours and gradients of the land.
As much as I love driving the peak roads, i woud definitley have used the railway if these missing connections had existed! And as long as the cyle trails can be retained, it is a win-win!
I think it would be more cost-effective (and possibly more useful, given the distributed destinations people want) if a proper integrated bus service was put in place. There are buses, but the quality is variable and the integration basically nonexistent.
Also Northern need to sort out their staffing so the trains are actually reliable.
Dr Hoo
10 Nov 2015
Hope Valley
Can I ask why @Railperf was unable to use the local buses which are, as he notes, actually quite good for a rural area. Far better than in many others.
Matlock-Bakewell-Buxton and Bakewell-Chesterfield or Sheffield are quite straightforward, at least during the day. Chatsworth and Castleton also have regular buses (but never had stations).
Ashbourne and Leek have sadly always been outliers.
People from outside always moan about supposed ‘poor connections’ but frankly for a tourist hanging around in an interesting town/village for a coffee or pint whilst waiting for a bus is just part of the holiday.
I don’t mind and I live in the Peaks.
Quite. Just like they do in Switzerland!
Or even the Lakes. It's well publicised and well used - and almost entirely commercial!
I think the trouble here is that small operators who do most of it like Hulleys of Baslow and High Peak just aren't very good at that sort of thing - that sort of operator is usually just geared up for "local buses for local people". It would perhaps help if the National Park Authority took a lead on it.
Killingworth
30 May 2018
Sheffield
To be fair there have been significant bus improvements this summer by both those operators plus Stagecoach with their 2 open top routes running hourly based on Chatsworth. Road closures and parked cars can make buses unreliable despite operators best efforts. However local people are here every day all year round so it's hardly surprising local needs tend to be better catered for. Derbyshire County Council have been pro-active on this, among others.
Railwaysceptic
6 Nov 2017
. . . . . People from outside always moan about supposed ‘poor connections’ but frankly for a tourist hanging around in an interesting town/village for a coffee or pint whilst waiting for a bus is just part of the holiday . . . . .
Absolutely, I couldn't agree more.
Railperf
30 Oct 2017
Buses serve a purpose, but in the end the same issues exist, slow roads, very frequent stops, congestion etc. A train journey between Ambergate and Buxton could be faster, more scenic and cleaner than the bus journey. And then it does then add a link between the south east peak areas to the north west. The millions spent building the viaducts tunnels and earthworks are being completely wasted, as this link would provide a real alternative to road travel. The quesion is, are we missing a trick by trying to talk about reinetgrating these lines into the national network rather than looking at a light rail option that would boost tourism and the local economy without clogging up the existing road system? The earthworks are there. It seems to need a more affordable option to kick start it. This probably needs a guiding mind ' waiting for GBR' to decide if this is a future requirement or not, and then the peak district park and local councils to come together to see what could be the most effective option. The area is crying out for an option where walkers and cyclists can turn up on a train - and the base infrastructure is there!
The longer anyone does nothing, the more expensive it becomes to build (looking at the rising costs of materials) and the more it becomes economically unviable. And then the more roads get clogged up - requiring expensive dualling etc.
Nottingham59
10 Dec 2019
... option that would boost tourism and the local economy without clogging up the existing road system? The earthworks are there.
But the viaducts tunnels and earthworks are being used - as a cycleway. That boosts tourism and the local economy.
... The area is crying out for an option where walkers and cyclists can turn up on a train - and the base infrastructure is there!
Would it not be better and much cheaper to extend the Monsal Trail to the railheads at either end, at Buxton and Matlock?
Killingworth
30 May 2018
Sheffield
Yes, much!
Bakewell to Rowsley should be fairly easy. Buxton to Blackwell Mill is rather more dificult. Shared with the freight line it can't be impossible given the long section already shared with Peak Rail from Rowsley into Matlock. Not so attractive though sharing with long aggregate trains.
stevieinselby
6 Jan 2013
Selby
Does not compute.
If there are plenty of local buses, why is a car essential?
If people have to change from a mainline train onto a tram or a narrow gauge line, they might as well change from a mainline train onto a bus.
If you've just obliterated the trail that is the main reason for them coming in the first place by building a railway line over it, they won't want to come any more.
