Differences Between Various Sprinters Acceleration
Railperf
30 Oct 2017
Yes, the 153 i sampled between Norwich and Great Yarmouth -packed like Sardines on a sunny Saturday last May - was dreadfully slow, but it did have fair amount of extra weight to carry that day - having been drafted in to substitute for a missing 755/4.
Railperf
30 Oct 2017
Interested to note that a 2+6 HST formation has the closest power to weight ratio to a Class 222. The HST is apps 10,5hp/t at the rail compared to between 10.56 and 10.8 for a 222. The 222's seem to deliver appx 525 to 540 rail hp per engine.
A 2+5 HST is much higher at 11.6 hp/t and the 2+4's are almost 13.1hp/t.
Still, even a 2+5 HST struggles to keep up with a Voyager in the initial 0-30mph sprint, mainly because of the way that power is more gently applied - also linked to how quickly the HST brakes will release.
The 22x's - being true multiple units (HST's while called multiple units are essentially 2 locos either side of a rake of conventional coaches) seem to release the brakes quicker and the traction system - being far more modern - seems able to deliver power earlier to deliver that faster start. The HST's 1970's traction system seems to require a more gentle application of power - the general feeling that Notch 5 starts are likely to cause them to fail more frequently due to overloading the traction electronics.
It is fascinating to see that improved technology allows the Class 755's to have a power pack that is as potent as an HST power car , but in a more compact space.
hexagon789
2 Sep 2016
Data I have suggested that a 153 was over 30 seconds slower to 60mph than the next poorest member of the Sprinter family
hexagon789
2 Sep 2016
Is it only up to 540hp? I thought the motors were rated at 275kW, even allowing for transmission losses I thought modern traction electronics were more efficient than the old 90% of 90% efficiency.
Railperf
30 Oct 2017
Since between spring and summer 2015 it is understood the engine management chip was remapped to lower power levels. Our recordings of Class 222 performance over the period show a marked reduction on power from appx 560 hp +/- 8 to 10 hp at the rail to a current level of apps 540hp +/- 8 to 10hp. Around Winter 2015/16 this was resulting in approx 20% of sets running with an engine out - down from appx 30%.
If you take the commonly quoted engine rating of 750hp, and relate that to the at rail figure of approx 575hp, that is essentially only 77% of the engine power actually getting to the rail.
Railperf
30 Oct 2017
Starting from Acle eastbound - reasonably level there - 0 to 60mph in 158 seconds!!
hexagon789
2 Sep 2016
I can understand down raring engines to reduce wear and fuel consumption but actively downrating performance of the traction electronics seems counter productive somehow
Railperf
30 Oct 2017
I presume that trials were carried out - to determine if wear and tear could be reduced and reduce fuel consumption at a power setting that would still allow the timetable to be maintained - especially as 125mph running on MML had been introduced by then. And some of those 125mph sections are quite short - so a decent power to weight ratio needed to get to 125mph and maintain it for as long as possible.
hwl
5 Feb 2012
Engine derated in software from 750 to 700hp
750hp -> 560kW
700hp -> 521kW
Around max of 45kW for hotel load and auxiliaries per car so 515/476kW for traction power and losses.
560hp -> 417kW allowing for auxiliaries so 417/476 = ~ 87.6% to traction at wheel from what is available (you'll struggle to get much over 90%).
hexagon789
2 Sep 2016
You would assume they did perform trials, but again given the fact that the increases in permitted speeds on the MML were intended to reduce journey times, given that when the first 125mph timetable came into force it was said at the time they would reduce timings further, it seems more difficult to do that with a downrated fleet of trains.
That's my thoughts anyway.
Railperf
30 Oct 2017
750hp -> 560kW
700hp -> 521kW
That seems to be in line with our findings. But as each set can differ in regards to engine health - the majority of recordings suggest average engine outputs per set in the region of 535 to 545hp - meaning one or more engines might not be pushing out their full bhp. The figures I have for late 2015 suggest very few sets averaging 550hp per engine. Nothing more than that.
irish_rail
30 Oct 2013
Plymouth
A notch 5 departure is more or less impossible these days due to the MDEC computer (on the MTU power cars) doesn't allow instant full power. If driver puts it straight into notch 5 it will still take about 10 seconds or so before you are getting full power.
londonmidland
22 Dec 2009
Leicester
What's the performance difference between a 2+7 HST and a five car Voyager climbing the Lickey Incline both whilst climbing and also at the top, at Barnt Green? What speeds are they travelling at?
Railperf
30 Oct 2017
HST's hitting the bank at Bromsgrove doing 80mph are often doing around 60mph at the top of the 1 in 37.5 at Blackwell. The Voyager logs from around 2012/2013 show speeds of around 70mph being achievable at Blackwell - the days when higher engine outputs were the norm. From Blackwell, the gradient eases to 1 in 291, and Barnt Green is on the other side of the summit on a 1 in 290 downgrade. Speeds approaching 90mph are achievable at Barnt Green with a clear run. But the Cross City Line services frequently cause signal checks!
Occasionally some extraordinary runs have been recorded, especially in the 1980's and 1990's before TPWS, onboard data recorder etc.
One such run from 1985 started the climb at Bromsgrove at a racy 96mph topping the bank at 76mph. In 1997 we have details of a run that went through Bromsgrove at 84mph hitting Blackwell at 74mph. Bart Green was passed at speeds of 87 and 89mph respectively.
For those specifically interested in HST performance over the years, The Railway Performance Society produced a booklet back in 2016 dedicated to 40 years of the HST's - with technical explanations of traction performance and examples of how performance has evolved due to changes in formations and route enhancements - with comparisons to older and more modern stock.
There is an electronic version available for members - £16 per year - and this allows unlimited access for a year to the full archive containing thousands of HST performance logs as well as other traction. UK, Europe and Worldwide.
virgintrain1
29 Jul 2011
I recall Virgin Trains publicity stating 'sports car acceleration' - 0 to 60mph in 60 seconds for 220 and 70 seconds for 221s
Voyager Spec from the VTXC New Dawn CrossCountry: Dream to Reality magazine from May 2001.
hexagon789
2 Sep 2016
That's very interesting because it shows the traction motors as being rated at 235kW, Platform 5 has them at 275kW which I always thought seemed too high
hwl
5 Feb 2012
235 adds up overall when you account for auxiliaries (hotel loads) and losses without any performance impact from derating that happen over decade after that document (which aligns with derating isn't performance impacting), 275 doesn't even before derating...
hexagon789
2 Sep 2016
Exactly, I didn't see how you could hope to get 737.6hp (550kW) out of the two motors per car when the engines are only fractionally more powerful at 750hp (559kW).
37057
3 Jul 2009
Also interesting how they get 750hp from 1800 rpm...
Domh245
6 Apr 2013
nowhere
That's what Cummins rate the engine for...
37057
3 Jul 2009
New ones maybe, old ones not so. 750hp @ 2100rpm on a CM500 HPI type QSK19 and I'm sure the calibration specs are the same for all three customers of Cummins for DMUs (Alstom, Bombardier & Siemens).
3 Jul 2009
Its possible that the engine is rated for 750hp @ 2100rpm but the traction system only demands a maximum throttle speed of 1800rpm due to the fact they're driving alternators rather than a turbos.
If that's the case, they must have an easier life under Voyagers than 180s/185s!
hwl
5 Feb 2012
The specs aren't the same.
Voyagers and meridian are 1800rpm max and are effectively set up as 60Hz genset.
37057
3 Jul 2009
But is it set up like that on the engine ECM or is it the traction control on the unit side that limits max speed?
