Disused or mothballed railway lines with track still in place
route101
16 May 2010
South of Motherwell station , theres a spur off the mainline , think it goes into the former ravenscraig site . Looks still connected but not sure if it gets used. Further down towards carluke theres a line that has recently been disconnected .
DarloRich
Fenny Stratford
The Leamside line, I believe. Ooops, somebody has nicked the rails.
no they haven't. Well not all of them. NR took away the rest and the rest was a LOT
Northampton to Brackmills?
I can think little more mothball line
Little Eaton junction - Denby colliery
Long gone
Does any traffic use the line to High Marnham Power Station?
Most of it is the Rail Innovation & Development Centre but I am not sure about the short section up to the power station
The Horbury curve still has track in places... but you'd not get anything from end to end apart from a JCB!
Come to think of it, Healey Mills yard would qualify, there's miles of abandoned track there...
Most of the track has gone off Horbury Curve and I doubt Healy Mills is long for this world..
East West rail? Don't think that's been mentioned. There's a large chunk from Oxford to Milton Keynes, hence it being reopened (one day, eventually, probably, perhaps).
There is a LARGE missing section in the middle. It has gone walkies.
The Tyne and Wear metro line at South Shields still runs to the docks, I believe. Last time I was there the lines were heavily rusted but in place. I can't imagine freight trains sharing the single line to South Shields as its not part of the rail network.
if you mean Tyne Dock then the line is still in use. It cant be South Shields as there is a hell of a hill down to the riverside and although the line runs a bit beyond the metro station it runs out under a bridge
Harbornite
7 May 2016
Rumour has it it'll still have plenty of movements this autumn as they'll still be running the regular leaf fall trains (water jets/sandite/whatever)
Oh I see, thanks. Ince thatbis over then there won't be much else using it.
Altfish
16 Oct 2014
Altrincham
I'm not sure exactly how far it still goes but the Skelton Junction (Timperley) to Partington line is certainly still in situ and connected at the Timperley end.
Moodster020
18 Dec 2008
The 5mile branchline from Scunthorpe steelworks to the docks at Flixbrough. I ma have been one of the last to traverse a small section of the line in an 08, as i work for HNRC & we recovered the last 2 08s that worked the docks in May2014. I recall it just looked like the 08 was going through a field it was that overgrown..!
Harbornite
7 May 2016
The 5mile branchline from Scunthorpe steelworks to the docks at Flixbrough. I ma have been one of the last to traverse a small section of the line in an 08, as i work for HNRC & we recovered the last 2 08s that worked the docks in May 2014. I recall it just looked like the 08 was going through a field it was that overgrown..!
Cool! I'll add that to the list.
By the way, what happened to the 08s?
Poolie
30 Jan 2010
There's a loop on the up side all the way from Hartlepool to Seaton still connected, but obviously never been used for years, overgrown with bushes and trees, yet it received colour lighting when the coast line was resignalled about 5 years ago.
chappers
5 Mar 2008
There is an awful lot of mothballed track in situ in and around Harwich, Dovercourt and Parkeston.
When we relayed the line through Dovercourt Station a good few years ago, we were able to put Engineering trains on the line between the points at the London end at Dovercourt and Alexandra Road (?) Level Crossing after a bit of de-veging and tie bars fitting. However the section between Parkeston Quay and Dovercourt was beyond help.
The rumour was at the time was that the line had to be left in situ as in the event of war it would still be used for military traffic of some kind (quite what it would be used for I don't know, and apparently the building that sits on the site of the old linkspan is easily "demolishable")
Not sure if it counts and apologies if its been mentioned already
RichmondCommu
23 Feb 2010
Richmond, London
I seem to remember Parkeston Quay seeing trains carrying cars for export or maybe import many years a go.
Did the train ferry from the Netherlands also depart from there? I seem to remember that it did.
DarloRich
Fenny Stratford
Yes I think so. Did it not transfer from Dover?
Parkeston is , of course, in use as a base for the high out put train on Anglia
Callum
25 Jan 2010
What about the Burghead line that joins the Aberdeen to Inverness route at Alves. On Google streetview you can see the line from several road bridges that cross the line. Interesting to see how much vegetation has taken over the line when you look at previous years streetviews. Does anybody know if the branch is still connected to the mainline though? You can't really tell from Google maps.
Sleepy
15 Feb 2009
East Anglia
Leiston and Southminster will see loads more traffic with the new power stations to be opened ?
Dr_Paul
3 Sep 2013
Does the scrapyard near Mitre Bridge Junction at Willesden Junction still have freight services? I've not seen anything there of late whenever I've passed by on the North London Line.
Steveswan10
11 Aug 2016
Herefordshire
Just a quick one, further to my mention of the line into Wiggen's (INCOME ALLOYS) in hereford, these are a couple of pics of a bridge on a path that runs down the side of the factory, one shows the very overgrown cutting looking towards the main line and the other of the yard and you can see the track still in place (or at least part of it)
stuart100100
13 Dec 2009
It's all there, with many trees. We were looking at getting it devegged and fettled for use of engineering trains for a renewal at aintree
There's been a bit of activity at the Aintree end in the last couple of weeks I've noticed. A lot of the trees and bushes are gone and you can see the tracks now
Thebaz
24 Nov 2016
Purley
In that case, then there are the lines to Youghal and Foynes.
You'll also find several places along the old Tralee-Fenit route where the tracks are still in place, including on Fenit pier. The station platforms and footbridge still exist too but IIRC Kerry County Council has built a children's playground on the trackbed.
