Diversions due to line closures in the Bristol area (August 2021)
tel
10 Mar 2010
norwich
Moderator note: Split from
Just received Today's Railways and on page 20 is a small piece regarding the works at Bristol TM. It says (if I read it correctly) that there are plans to divert a Bristol Parkway to Weston-Super-Mare service via the Rhubarb Curve and North Somerset junction-Bristol West Junc through St Phillips Marsh depot on the Sunday 7 August and 9 to 13 August. So, is it happening or not?????????
Tel
25 Oct 2019
Just received Todays Railways and on page 20 is a small piece regarding the works at Bristol TM. It says (if I read it correctly) that there are plans to divert a Bristol Parkway to Weston-Super-Mare service via the Rhubarb Curve and North Somerset junction-Bristol West Junc through St Phillips Marsh depot on the Sunday 7 August and 9 to 13 August. So, is it happening or not?????????
Tel
It should be happening yes. Hopefully an HST will find its way onto one of the services vice DMU...
43 302
25 Oct 2019
XC services Monday 2 August (and probably until Friday inclusive) via Bristol East Depot DGL or North Somerset Jn.
Along with every other day between July 10th and August 6th. August 7th, and 9th-13th via Dr Days and Westbury.
John R
1 Jul 2013
Tel
Are these services shown on RTT (or similar facilities) with this routing? I haven’t been able to find any such services so far.
Mag_seven
1 Sep 2014
here to eternity
I suspect they won't be loaded up until much nearer the date. That said I'm sceptical about passenger services being routed through St Phillips Marsh depot. I suspect we will just have to wait and see on this one.
The exile
31 Mar 2010
Somerset
I highly doubt it.
However unlikely it seems, GWR's own "Bristol" pages has this for 9th - 13th August:
  • Bristol Parkway to Weston-super-Mare – off-peak services will run but won’t call at Bristol Temple Meads
Other than running through the centre roads at Temple Meads, I can't think of any other way stoppers can run from Parkway to Weston with the only "non-calling" station being Temple Meads. OK, it does also say "buses replace trains between Bristol Temple Meads and Parkway - but that appears to be a consistent feature throughout the works (haven't checked all dates). I suppose if they're doing something drastic that involves having all the "domestic" power off at Temple Meads, they might have the entire station closed but with trains still able to run through.... all will no doubt be revealed before long.
43 302
25 Oct 2019
That comment was in reference to it appearing on RTT right now. It is planned to happen.
Annetts key
13 Feb 2021
West is best
There will be NO trains through Bristol Temple Meads on any line during the time that the whole station is closed as (1) all lines will be under a T3 blockade and (2) all the signalling in the area will be unavailable because the interlocking is being taken off-line for the interlocking data to be changed and then the altered signalling will require to be fully tested to ensure the design is safe.
Horizon22
Jobs & Careers
8 Sep 2019
There will be a GWR shuttle service running between Weston Super-Mare <> Bristol Parkway that will go via St Phillips Marsh. It will run on the following dates:
  • 9th - 14th August
  • 31 August - 3rd September
tel
10 Mar 2010
norwich
That's good, I've booked to go to Bristol Parkway on Tues 10 just to see what happens and hopefully get the line via PM. Just checked on RTT and the services are uploaded and there is Parkway to WSM trains via SP.:D
Tel
D6975
26 Nov 2009
Bristol
It's a bit random, most are buses between TM and Parkway. Showing as trains (09 Aug) are:
ex BPW
09:15
11:14
12:15
14:15
15:14
ex WSM
09:29
10:29
12:29
13:29
15:29
PS If you live in Bristol, this FREEDOM TRAVELPASS ticket will get you to/from BPW on the bus and on the train to WSM too (unlimited travel for 1 day in the area)
Zone A B D: Bristol & Weston-super-Mare
1-day
Peak Travelpass (any time, any day)
£13.50
TheLastMinute
Weston-super-Mare
There is, however, a proposal for some GWR to be routed that way at certain times.
Well I never! Those proposed services running via St Philips Marsh for week commencing 9/8/21 have actually appeared in Real Time Trains.
I'm genuinely shocked at the outbreak of common sense on the modern railway. I'm pretty sure there is no way something like this would have happened 10 years ago. If it comes off, I'll be much impressed and will say a hearty well done to all concerned.
I'd imagine that these trains will be busy with people coming from all over to bag very rare track mileage.
https://www.realtimetrains.co.uk/se...09/0200-0159?stp=WVS&show=passenger&order=wtt
Screenshot of Real Time Trains website showing 10 passenger services between Weston-super-Mare and Bristol Parkway passing St Philips Marsh HST Depot on 9th August 2021.
43 302
25 Oct 2019
Interesting that when I looked the other day it showed the Bridgwater Flask path too! Admittedly RAR.
WelshBluebird
14 Jan 2010
Not as exciting but it looks like some of the other diversions have been confirmed too (e.g. Bristol Parkway to Bath services calling at Lawrence Hill and then going via the curve avoiding Temple Meads - I think the route was previously confirmed anyway but nice to see they will be serving Lawrence Hill).
1-day
£13.50
If you are happy to bail out at Nailsea or Yatton, you can save a couple of quid and get the Zone A B one instead (it won't be valid out to Weston as the more expensive one is though).
pdeaves
14 Sep 2014
Gateway to the South West
ex BPW
09:15
11:14
12:15
14:15
ex WSM
09:29
10:29
12:29
13:29
15:29
1-day
£13.50
Also add 15:14 ex BPW.
D6975
26 Nov 2009
Bristol
Thought I must have missed one when I saw the unbalanced workings. I've added it to my o/p.
If it's a nice day when I do it I'll get the ABD travelpass and go for a swim in the newly renovated Marine Lake at Weston.
The exile
31 Mar 2010
Somerset
One thing that is confusing me - back in April there were reports (in the original thread) that Bedminster was being fettled up because it was going to act as a temporary terminus during the works. I admit I haven't searched through all the dates, but I can't find any trace of trains terminating at Bedminster - indeed the SPM diversions don't even stop there, although the BPW - WSM service normally would.
D6975
26 Nov 2009
Bristol
Still too far in the future, they won' t appear until closer to the time when they're going to happen.
D6975
26 Nov 2009
Bristol
Sorry, what won't appear... (etc.)? Not sure what you're replying to!
The post immediately in front of course. Bedminster terminators won't appear for a while, the West end is being done last. SPM and Bath/Westbury diversions only appeared in the system less than a week ago and that's right at the start of the works.
The exile
31 Mar 2010
Somerset
GWR.com has now been updated with more details up to and including the bank holiday weekend - which is when Bedminster gets its few days of glory!
It might. It is possible on the first and last services.
What makes it possible on the first and last service? There is no need for a GWR HST to be north of the blockade whilst it is in place - eg no Cardiff to Bristol element of Taunton services.
