Howardh
- Joined
- 17 May 2011
- Messages
- 8,181
Am I right in thinking the London Underground produces it's own power independent of the national grid?
It used to, as I had an ex co-worker who did his apprenticeship there.Am I right in thinking the London Underground produces it's own power independent of the national grid?
However, I believe that power station is now plush apartments. ( I can't remember it's name but it is/was near the Thames and in the Fulham/Chelsea area). I don't know if TfL has any other power generating plants anywhere else though.
Edit. It was Lots Road https://en.m.wikipedia.org/wiki/Lots_Road_Power_Station
Decommissioned in 2002.
Not really any more. In fact it’s never really been the case that LU relied entirely on its own power generation, albeit that Lots Road did supply power for a substantial part of the system (mainly the central area) until around the start of the new millennium. Parts of the system, especially the suburbs, have always relied on the grid.
Greenwich, which is still operational, is nowadays purely a backup facility and only comes online when required. I’m open to correction but from memory I don’t think it’s capable of supplying traction power.
They might generate their own power, but they will still be tied into the grid. They probably would go down with the grid too. I doubt a couple of generators would be able to react to the peaks and troughs of a railway, without major voltage spikes so the grid will absorb the changes. They only generate their own power as it's cheaper than paying the grid for it all.Wikipedia (I know) suggests that LU are looking at upgrading the generators at Greenwich.
If this sort of situation becomes more prevalent, probably more expedient to do something!
??? Greenwich remains operational, if needed I can't recall the last time it was used as the operating practice for the past almost 20 years has been to supply LUL from the National Grid, on the grounds of cost effectiveness and reliability.... I would guess it would need about 30 mins to power up if needed (it's fed with gas). But most of LUL could be supplied from Greenwich if needed: many early railways had their own power stations and managed to supply reliable power despite 'the peaks and troughs of a railway'. The only real thing that's changed since then is much more widespread of power electronics to control motors and auxilliaries, and these devices are sensitive to frequency and voltage so these variables need to be controlled more precisely.
Yes - Greenwich was inherited from the LCC, having been built to power their tram system. Apparently (many years ago) it was a failure of this (which halted the trams) that was at least part of the inspiration for what became the National Grid, an interconnection of all the various power stations and electricity suppliers.When London Transport did produce much of their own power, years ago, it was I believe used for the trams and trolleybuses too, as well as the Underground
Large LUT generating station at Chiswick Depot (today’s Stamford Brook bus garage)I don't know where the other pre LT tramways got their power from but certainly in some cases there was essentially one undertaking, which had a power station, ran trams, and supplied electricity to consumers (domestic, business and industrial), and LT only took over the tramway element.
I think that's a risk that doesn't really exist.Thanks for the info; I'm actually quite surprised it doesn't - so the LU could be affected by any "strikes" by power workers (as could trains)? He asks remembering the 70's!!
Isn't the newish building overlooking Edgware Rd (H&C) another NG connection point / substation?
You mean like when the LU PCC people went on strike?
No, I mean the National Grid is diversified sources anywayYou mean like when the LU PCC people went on strike?
