hexagon789
Manchester Piccadilly platform 14 appears to have acquired a check rail on the outer rail???
I think they are required on curves of less than 10 chains radius.
The terrible hunting you used to get on Metrolink was similarly caused by such a compromise.
Indeed, but physics and common practice says they need to be on the inner rail. This one is on the outer.I think they are required on curves of less than 10 chains radius.
As soon as you are in a situation of cant deficiency or cant excess, the flange is essential or the wheel will simply drop off the rail. Trains are very often in a cant deficiency/excess situation.just a bit odd that i still get people telling me that the flange does play a large role in curving, im still not sure what to believe though
Not sure about that. The coning also creates a "steering" effect that keeps the wheel close to the optimum path, even if there is a certain amount of lateral force.As soon as you are in a situation of cant deficiency or cant excess, the flange is essential or the wheel will simply drop off the rail. Trains are very often in a cant deficiency/excess situation.
I'll let you try the first train to test that theory.Not sure about that. The coning also creates a "steering" effect that keeps the wheel close to the optimum path, even if there is a certain amount of lateral force.
So all those sidecut rails I transposed or turned were a figment of my imagination.I think edwin_m is right here. I have three arguments.
1) Train propulsion and braking depend on what railway people call adhesion, which is just friction between wheel and rail acting in a longitudinal direction. If this is possible, then friction must also be possible in a lateral direction.
2) For any given curve there is only one speed at which a train can traverse it without cant deficiency or excess. So if furnessvale were right, the only way for a train to avoid flange contact would be to traverse each curve at exactly the correct speed.
3) If furnessvale is right, what was the point of all that research into wheel/rail contact?
I never said that it was always the case. A defect in the vehicle or track can cause flange contact, and hunting is likely still to occur sometimes, so the flange is still essential even on straights or gentle curves. For example the lateral ride on Metrolink has been mentioned many times on here, including observation of sidecut rails even on straight track. I haven't been down that way for a while but someone posted on here that changes to the wheel profile have improved things.So all those sidecut rails I transposed or turned were a figment of my imagination.
One thing that I haven't seen mentioned here yet, which has to be a significant design aspect, is what happens when an axle locks up or slips. When the wheels stop but the train slides onwards you can forget about the conicity; the only thing keeping the train on the tracks is the flanges. If the average traveller knew what percentage of station stops in autumn involve a significant amount of WSP activity (railway term for ABS), they would be a little more appreciative of the job of the driver...
From my priviledged seat in the crumple zone I get a good look at the greasers which (are supposed to) reduce flange/rail wear and squeal. There is always a good coating of mucky grease for a few cm after the greaser on the side of the rail. Then a wider patch about one wheel rotation later, and then one wider still two rotations later, and so on until the different wheel sizes of different stocks results in the grease patches on the side of the rails merging. What i've never understood (but am thankful for) is that the grease doesn't seem to migrate to the top of the railhead where it would make my life very interesting indeed. Can anyone give a good explanation of why?
