Kingspanner
Back to the original video. As a rule, the more exclamation marks there are in a caption (in this case 4) the less remarkable is the piece of video.
The same junction area seen from a different viewpoint:
I would say this picture shows something more interesting than a lack of failure in the interlocking.
Why is this liner directed from its line over the platform line and then back again.
Seems a strange movement.
To allow a parallel move from Platform 3 into Arlington as demonstrated in the video......
Had it stopped (in the platform) for a crew change, perhaps?If you look at the still image in post #11, the freight is already on that inner RH line at the start of the platform, routing it to the outer RH line (as viewed in the image) and then back on to the inner line makes no sense. The same parallel movement could still occur if the freight remained on the inner line.
Knowing the area I would suggest crew change.Had it stopped (in the platform) for a crew change, perhaps?
Slightly OT but where/when has SWR brought in contracted class 47s?
I doubt there's a clearance issue for any regularly used rolling stock in this busy area, and 442s are not exactly unknown in the locale!The only other thing that occurs to me - is there possibly an OPPOS gauging restriction on Mark 3 vehicles through that turnout?
Given the number of restrictions that are currently affecting the 442 fleet and reintroduction I wouldn't be suprised if there was a restriction on their speed. Especially if the air suspension is deflated.and 442s are not exactly unknown in the locale!
Fair enough, but I doubt there would be specifically a clearance issue at Eastleigh. I guess transfer movements like this often have all kinds of special restrictions associated with the stock, which may have faults on or are new/heavily rebuilt and are not yet fully signed off for unrestricted network operation.Given the number of restrictions that are currently affecting the 442 fleet and reintroduction I wouldn't be suprised if there was a restriction on their speed. Especially if the air suspension is deflated.
My two pennorth? The 47 driver suddenly wondered if he was supposed to be heading for the works, or the depot...
Whatever, I’ve watched similar parallel moves there many times over the years. I reckon the video caption suggesting some sort of collision risk is completely unnecessary.
