Door problem
9 Apr 2006
London, UK
Hi,
I have a problem with my Ongar route, the doors keeps opening and shutting upon departure. Doyou see anything wrong with this code?
.sta North Weald;16.3300;16.3320;0;-1;0;0;Ongar BVE4\birds.wav;10;10;,
as I dont.
fbracal
3 Sep 2006
I'm not sure,
because you have only posted the code about the station and not also the relative command .Stop;
but a common mistake for a BVE developer is assign the comand .Sta and .Stop at the same distance. Due to a probable BVE bug, if the train is stop before the .Sta distance (even if in the admissible tolerance range) the doors will be open,but at the time of departure will not be close, so the train cannot move.
I hope this help you.
Cheers
Gavelex
9 Sep 2006
london
I have had this problem too. But it was wierd it worked the first few times i drove the route but then as soon as the doors closed they reopened again and i never got to move
LondonBVE
22 Dec 2005
Lost!
Thanks for asking this topic. I remember when I am still testing his route during Alpha Stage the doors cannot close. So I have to close it myself by pressing the F6. Now it is solved, not just his routes even the Taiwan Rapid Transit route as the same thing too at some stations.
