Doors
ChrisA
9 Nov 2005
Poole, Dorset
I've asked Seth this already (cheers Seth!) but was wandering if anyone else could give me a defiante answer. Can you disable the doors on trains so you open them manually?
3 Nov 2005
I maybe wrong but i don't think this is possible. I know that you can shut the doors manually in BVE by using the Route Randomiser although am not sure you can open the doors manually
T
Tom
Guest
You can disable the doors on trains - remove the .sta command from the .csv file, however - if you do this you lose automatic announcements such as the "This station is ..." announcements in the Northern Line.
It also removes the possibility to say how late you are, etc. :)
T
Tom
Guest
Sorry forgot to mention, this is possible in BVE4 only, you can only close doors in BVE2.
Guinness
13 Jun 2005
And the Jump to Station command.
When at a station (If you don't pass it at Speed of Course) use a .announce command next to the station stop marker? If it sounds you've stopped at the right place. :)
ChrisA
9 Nov 2005
Poole, Dorset
Where do i find the .sta command? I've looked throught the routes .csv file, but can't find it.
Cheers
T
Tom
Guest
An announce can run at any point. It does not have to run when stopped IIRC.
Guinness
13 Jun 2005
I know - Go 2 mph, once you hear the sound slam on the brakes. ;)
Tom B
27 Jul 2005
Remember you will need to retain the last station otherwise you won't be able to go anywhere!
