What's this "assistive signalling"? This is the second time I've seen it mentioned on this forum, but I've never come across it on the railway. I think that this is something that someone on here has just thought up.
Sticking a red at the end of every platform just to remind the driver to stop is impractical and unsafe. For one thing, a large number of signals are automatic and, provided the signal section ahead is not occupied, will show a "proceed" aspect no matter what. Where there are controlled signals it is possible to hold it at red, but this is not done without cause.
From a driver's perspective, holding the platform starter signal at red to remind the driver to make a booked stop is a big no-no. For one thing it would be a SPAD trap. We have a number of stations where the stop board is right up on the peg. Slide past even just a bit and you'd be compounding a station overrun with a SPAD. There have also been a number of SPAD's where the traincrew have allowed themselves to become distracted by their station duties and set off through the platform starter when it was being held at danger.
The other effect it would have would be to shoot the timetable to pieces. I might hit a platform at 30-35mph and stop on the board without problem, but I'd be going a damn sight slower if the signal at the end was a red. Imagine what that would do to an Enfield Town trip with 14 stops spaced an average of 2 minutes apart. You'd be creeping around on single yellows and reds the entire way.
Sorry, but "assistive signalling" just doesn't happen. Every driver has a schedule book or card showing the stopping pattern of the train together with the altered workings which shows any amendments. It's down to the driver to check the pattern and remember to stop where booked. However, we're only human so mistakes do happen, and none of us are above making them.
With regard to early-running trains, the signaller can regulate the progress of trains, for example to ensure that the running order across junctions is preserved. Quite simply, if you get there ahead of your time, you wait at the junction signal until it's your turn. Likewise, it's common for the signaller to use controlled crossings to regulate early-running trains. Again, you'd get held at the last signal before the crossing until he/she's ready for you.
As for drivers having SPAD's, you'd be taken off the road, medscreened and be scheduled for tea and biscuits with your manager. Every SPAD is investigated to find out what the cause was and what can be learned, which may result in changes to in-cab procedures or alterations to the infrastructure.
O L Leigh
