Drivers bag/rucksack
luke_oliver
8 Aug 2012
I have noticed that on some drivers bags / rucksacks there is a red tab that appears can be pulled. Does anybody know its function? Thanks.
GB
16 Nov 2008
Somewhere
Its a quick release. If you get tangled up and the train starts moving pull the tab and the should straps come free.
deltic1989
21 Sep 2010
Is this the same reason why some of the hi-vis waistcoats I see staff wearing have poppers on the shoulder?
A-driver
9 May 2011
Yes-all railway standard hi vis-es will rip off completely with either poppers or Velcro
Southern313
29 Mar 2011
The "rip cords" on the bags also give moments of amusement as you sneak up on unsuspecting newbies!
table38
Stalybridge
Clothes being completely ripped off with poppers sounds like a normal Saturday night down Canal Street :)
wintonian
15 Jan 2010
Hampshire
At least they stay on longer there than they do in Brighton. :p
Back on topic, roughtly when did such things become a H&S requirement?
D2022
9 Aug 2012
Blunsdon
Not strictly true, LUL or whatever they are called use non rip ones sometimes, as do some contractors such as Thales.
Plus coats and waistcoat style ones don't tend to rip.
tsr
15 Nov 2011
Between the parallel lines
Indeed - my fully-compliant orange hi-vis waterproof jacket has no poppers or velcro to help it separate, but I am led to believe it will disintegrate if it gets caught in a train or some other moving object.
Fortunately, I have not had cause to see if this is the case!
ralphchadkirk
20 Oct 2008
Essex
Only my heritage hivis has poppers. None of my work hivi's have poppers or rip sections, despite the potential to be working on a railway (trains usually stopped though!).
Sent from my iPhone 4 using Tapatalk
Nym
2 Mar 2007
Somewhere, not in London
Heh, clothes on Canal St?
Really? Says in a manual that it must be 'breakaway' type.
DavyCrocket
27 Oct 2006
LU hi viz vests have Velcro to tear apart in to two front and one back portion rather than having poppers. LU train operators' rucksacks don't have anything out of the ordinary!
D2022
9 Aug 2012
Blunsdon
Yes my regulations book also says that they must be breakaway type HVV but honestly, I've seen a friend with LUL HVV and it's not breakaway, neither was mine when I got given given one by a friend in preservation, I can only assume they were obsolete versions no longer in circulation.
That said I often see Thales engineers with non rip ones, don't know why they are issued them. They may not have PTS or something?
