East-West Rail (EWR) countdown to entry into service
Sun Chariot
16 Mar 2009
thanks - that what you get for going on holiday - it is Tuesday today isn't it ;)
Wednesday 5-Feb's 0Z45 path is also on RTT - although I don't know if it'll get used.
Good spot about Friday's WCRC path.
fishwomp
5 Jan 2020
milton keynes
Looks like a track bash - Paddington to South Marston terminal, to Milton Keynes, then Euston and reverse to Paddington.
DavidGrain
29 Dec 2017
Looks like the Route Learning could be starting Monday 17th February. Also it looks like this will done on the class 196s as the starting point is Bletchley Depot. Of course it is possible that not all the trains shown will run from that date.
DarloRich
Fenny Stratford
Was this first time an HST operated between Oxford and Bletchley, or was it a common diversion or ECS in the 70s, 80s, or even early 90s?
no idea. It is certainly the first time since i moved here 15 years ago ;)
( i haven't seen many pictures of HST on that line)
Sun Chariot
16 Mar 2009
The line was mothballed in 1993 and I certainly don't recall an HST on the line prior to then.
The Whatley-Wolverton ARC stone was mostly with 56s. On one occasion, I saw a 59/1 on that working.
I had a pair of 108/115 power twins, on an NSE Christmas shopper special, Aylesbury-Claydon-Milton Keynes & back.
12LDA28C
14 Oct 2022
The back of beyond
Route learning has been ongoing for weeks. Why do you think 165s have been traversing the line recently?
196 traction training has already started at Tyseley too.
fishwomp
5 Jan 2020
milton keynes
How much training is expected?- I see every Milton Keynes to Oxford through until start of August is headcode class 5 on realtimetrains. Has a date other than "2025" been hinted at?
It was always going to be some point during the summer.
DarloRich
Fenny Stratford
it is down as a private charter. Suspect it will be some kind of VIP jolly/ high level strategic discussion about important things!
Training is already underway. It COULD be a 196 but no sign of any down here yet ( although I did recently see an electric unit on the depot sidings beyond the shed for the first time in ages so work must be progressing on the deport renovations)
It is running so hopefully i will get to see it this evening
I note that there seems to be a DOO dispute brewing before the line has even opened. Have any guards been recruited? If not, and I don't think they have, DOO must presumably be the plan, unless they're going to taxi in existing Chiltern guards. I've certainly seen murmurs about it on X.
Presumably the drivers will be trained DOO regardless so they can work other bits of Chiltern.
Bristol
It's possible it's changed since the 2021 consultation but in the technical appendix for that, it says the stock must be suitable for Driver Controlled operation:
5.12. Rolling stock characteristics
5.12.4. The trains shall be fitted with ETCS, Automatic Selective Door Opening and in cab Driver Controlled Operation through body side cameras and in cab CCTV.
Stock being compatible doesn't mean it'd necessarily be that mode of operation, of course.
DavidGrain
29 Dec 2017
I don't think this was an HST, I think it was 2 43s back to back which is the Colas Rail route learning set.
I assumed that the 165s were existing Chiltern drivers as the newly recruited drivers probably would not have been trained on these trains. As you say 196 training is being done at Tyseley which is logical.
12LDA28C
14 Oct 2022
The back of beyond
Those Class 5 trains are running to the future passenger timetable so it would be easy enough to convert them to Class 1 at some point if necessary. That said, I believe late summer is most likely for services to start. All Bletchley drivers will need to sign the route as well as BY depot itself and the shunt to Fenny Stratford.
The method of operation has not yet been determined. So no, no guards have been recruited. There certainly aren’t enough existing guards to be ‘taxied in’ to cover the work.
Newly recruited drivers have been taught existing Chiltern traction as they need to accumulate their driving hours under instruction prior to qualifying. Hard to do that on 196s with none available for use on the route yet!
Cowley
15 Apr 2016
Devon
Before we end up down a DOO or railtour dead end, just a gentle reminder that this thread is to discuss driver training on route.
Thanks ;)
BlueLeanie
21 Jul 2023
Haddenham
Why would Chiltern drivers be on an HST power car? As mentioned above, Chiltern drivers have been learning the route using mainly 165s.
ScotRail drivers switch back and forth between an HST and a 170.
Isn't this about route learning rather than traction?
12LDA28C
14 Oct 2022
The back of beyond
Scotrail drivers sign HSTs and 170s. Chiltern don’t operate HST power cars. TOCs use their own trains for route learning their own routes.
