KingDaveRa
Is that a rail-connected depot for Greatmoor? I'd assume that'd have to mean rubbish arriving from London again?
AIUI HS2 are required to move the waste transfer sidings and handling equipment to the other side of what will be their new tracks. That suggests it has planned future use?Is that a rail-connected depot for Greatmoor? I'd assume that'd have to mean rubbish arriving from London again?
East West Rail 'Site Visit'
Opportunity to travel from Aylesbury to Bicester, via Claydon.
top+tail 20's and a set of mk1's would suffice though.nothing quite like the wind in your hair and smell of fresh country air mixed with diesel.
London Transport said:Vehicles & coaches used; South end Class 20 diesel locomotive 20227, Class 20 diesel locomotive 20142, 4TC coaches (for customers, with LTM Shop set up in Coach C), Class 33 locomotive 33012
Sadly not going to happen, as the "Aylesbury Heritage Fleet" is no longer with Chiltern.would be lovely if they'd let the old bubble-car loose on this!
It seems like a bit of a mess, as it'll be an assortment of sidings for rail to be unloaded onto road, so it can be trundled over a bridge to the EfW plant. That seems needlessly energy intensive, unless they plan to use electric vehicles. Then again, the old waste transfer had a similar arrangement I suppose. It's quite a big development, whatever happens, especially considering the main depot just up the line.
Not sure why, it moves them well away from all the housing at Calvert.If the locals thought having the EfW plant built was bad, they're going to HATE all these sidings.
There seems to be little enthusiasm for HS2 in that part of Buckinghamshire anyway. There are several posters on windows declaring opposition to the project.
They can't build a station in Aylesbury as it will tunnel underneath.
Such a proposal was made by the residents of Steeple Claydon. It's not gained traction with either project, but who knows what will happen in the future!If there was ever a station, it'd surely be at where HS2 and EWR intersect - a major interchange and railhead/park & ride - with potential for housing and a new town development.
The great unknowable is would you get sufficient volumes of people changing between the two to make it worth the penalty of slowing down the high speed trains for a stop and adding additional infrastructure to allow the non-stoppers to go past. Personally I think it's unlikely. There are already two lines nearby which will cater for the local traffic going North-South roughly (WCML and Chiltern Line) with potential on WCML at least for increased frequency when HS2 opens.Such a proposal was made by the residents of Steeple Claydon. It's not gained traction with either project, but who knows what will happen in the future!
The tunnels end at Great Missenden. It's embankments and cuttings through the Vale of Aylesbury. From what I recall of the plans there's no tunnels for quite a ways after Missenden.
But yeah, I know all the reasons why they aren't building a station in Aylesbury. They could make it work, but Aylesbury is too well served by Chiltern to need it, so it's not worth doing. However, it seems like a missed opportunity given Aylesbury is a market town, will be on the East-West Rail corridor, AND could be served by the new main road from Oxford to Cambridge (if the council get their way). Throw in HS2, possibly connected with EWR and the possibilities for transport would be amazing. But then because all the aforementioned is happening (the road is pretty certain as it has government funding, just depends on the route), I suppose HS2 is a bit surplus to requirement.
Thanks for pointing out on the lack of tunnel issue - brain fade on my side...The tunnels end at Great Missenden. It's embankments and cuttings through the Vale of Aylesbury. From what I recall of the plans there's no tunnels for quite a ways after Missenden.
Agreed. The major settlements on that part of the Oxford-Cambridge corridor are Oxford, Bicester and MK, all of which have frequent trains to both London and Birmingham. Even though the classic lines are slower, they are probably still quicker than travelling off at right angles and changing trains at Calvert.The great unknowable is would you get sufficient volumes of people changing between the two to make it worth the penalty of slowing down the high speed trains for a stop and adding additional infrastructure to allow the non-stoppers to go past. Personally I think it's unlikely. There are already two lines nearby which will cater for the local traffic going North-South roughly (WCML and Chiltern Line) with potential on WCML at least for increased frequency when HS2 opens.
Was it the April 1st issue?
It just doesn't seem practical or cost effective
that's the whole point!. they are well served in north-south directions only!
what about people who live in bedford and work in cambridge/MK?...1 hour by bus,1hr+ by car...by train in theory should be 30 minutes tops.
bedford-bletchley-mk is (1hr -`1hr 10m presently)..should be 35-40 minutes direct
you have to connect the main hubs for commerce+transport...bletchley is not,MK is.
cambridge to oxford about 2 hrs though london,will be about 50% improved by E/W rail.that is a significant saving for those going even further east to norwich/east anglia, or further west to wales/bristol.
The May Modern Railways has an interview with Rob Brighouse where he raises the question of a new MK-Bedford route again, suggesting it might diverge from the WCML north of MK and join the MML north of Bedford so through trains can call at both existing stations. He said it would depend on WCML capacity issues and also the direction of development of MK (if it started spreading southwards Bletchley might be a better bet).I’ve attended several EWR talks recently, a new route between MKC and Bedford Midland was never a serious proposal. From what I remember the idea was to scope it out briefly but discount it as uneconomical, in case a minister-type person intends to challenge their preferred plans.
Indeed, I was commenting on the (lack of) need for a station on HS2. I agree that EWR has a lot of merits for east-west travel.The post you're replying to is concerned with the diversion as to whether E/W rail and HS2 should have an interchange. We're agreeing that these locations are suitably served N/S so a HS2 station wouldn't be necessary. We're not really commenting on whether E/W rail as it stands is necessary or not.
That has its merits and is certainly preferable to trying to smash through the MK built-up area, but I still can't see it being viable when there's an alternative route that does almost the same thing.
The more likely development is on the south side from Bletchley towards the M1 - coincidentally the route of the existing Marston Vale line.
Isn't Bletchley essentially 'MK South Parkway, for East / West purposes? Given a decent frequent shuttle bus to central and other parts of MK, would that not do for MK?
Where would this new southern E/W non stop line to Bedford go, exactly, crayons invited? Do either of you have a feeling for that?
