- Joined
- 14 Jul 2011
- Messages
- 16,739
Well I'm sure this has been done to death but I checked the first several pages of the forum and can't find anything so here I go.
East Coast currently operates 13/14 HST sets over a variety of routes, serving destinations like Lincoln, Aberdeen, Inverness and Hull. They also run diagrams on various all wired routes (personal experience indicating Leeds as one such destination) but never mind.
These destinations are for the most part operated over considerable stretches of wired railway and as such could be considered to constitute a waste of infrastructure that has been procured at significant expense.
I would propose that a ten vehicle Class 222 derivative be built with 8 diesel engine powered vehicles and two trailers containing a pantograph and transformer equipment.
Such a combination would operate with the two trailers in the middle and supplying the 4 powered vehicles on each end via a traction bus, this combination allows one pantograph to supply both transformer vehicles without running a 25kV bus through the train, this also means that the low voltage bus is as short as possible.
You could also make the two transformer vehicles the quiet coaches for the train and put the restaurant vehicle next to them to reach the load on the length of the traction bus when operating under electric traction.
I chose a Class 222 because of the increased cabin room due to the rearrangement of the internals and the apparently more advanced control system installed combined with the fact that the East Coast Main Line has no need for tilting trains.
Operationally the train would have 6000hp under diesel and electric power and if we assume the transformer-trailers are similar weight to the diesel powered ones, would weigh in at approximately ~460t. This translates to a power to weight ratio of roughly 13hp/t.
13hp/t is approaching that of a Class 390 and as such the train could probably easily exceed 125mph and might be able to reach 140mph in the future, albeit with inferior acceleration characteristics.
It should easily be able to thrash HST timings on lower speed routes like the lines to Aberdeen and Inverness, and its lower axle loadings should permit higher speeds on those routes.
So, I assume there is some blindingly obvious reason why this hasn't or isn't being done rather than waiting for the IEP which is apparently going to be a while and deliver ED sets of questionable usefulness.
EDIT: It would also be a politically wise move in the current climate with the furore over the Derby works, especially if they took the opportunity to displace the MML, XC and GWML sets as well with the impending electrifications.
