Empty stock taking the long route?
MikeWh
15 Jun 2010
Crayford
Just been checking trains through Crayford and noticed 5O15 passing. This is an empty run from Cannon Street to Grove Park depot. Why does it have to go round via Slade Green and the Lee Spur? Surely that's just a waste of energy? It's not even ending up the other way round.
pdeaves
14 Sep 2014
Gateway to the South West
Pathing through Lewisham? Doubles as a route knowledge retainer?
Edit: Is this the usual route? If not, was there some sort of block or disruption that it needed to avoid?
PHILIPE
14 Nov 2011
Caerphilly
It could be for maintenance of diversionary route knowledge and is a commonplace type of event.
Ianno87
3 May 2015
May also be use to get the unit in a particular orientation, e.g. when it is split within the depot and the units each end do different things.
But most likely pathing considerations.
tpjm
25 Jan 2019
The North
We send a fair number of our ECS moves via 'alternative' routes - allows drivers to retain their route knowledge.
MikeWh
15 Jun 2010
Crayford
Many thanks for the explanations. I guess in the grand scheme of things the extra energy is minimal, but it still feels like a waste.
Just responding to the reversing comment, the train doesn't change direction it just takes an extra 45 minutes or so to get where it's going.
30907
ECS using longer routes is common. One close to home for me is the Wimbledon depot down workings via East Putney.
Specific reason there - it gets the train to the depot without blocking the main line. ECS to Clapham Yard likewise uses the Windsor Lines, and I am sure there are others.
BTW, 5O15 must have gone direct today - 10 late start, disappears from RTT, 35 early arrival!
Specific reason there - it gets the train to the depot without blocking the main line. ECS to Clapham Yard likewise uses the Windsor Lines, and I am sure there are others...
I suspect that’s been the normal operating plan for depot access since the flyover was built, about 80 odd years ago? It’s never struck me as being done on a whim...
IamTrainsYT
8 Dec 2018
Glossop
might be to delay it into its platform so its not taking it up for 45 minutes
30907
Correct - and probably since the depot was built, as the Local lines were both on the wrong side. The East Putney route had stopping trains when the LSWR electified it BTW.
Deepgreen
12 Jun 2013
Betchworth, Surrey
Absolutely - I understand the reason, but was answering the point about longer ECS routes.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Depending on the type of stock, diversions or empty stock moves like this can also be used to turn stock around - FGW used to make use of the New North Mainline & triangle as Ealing to turn their HST sets around, while some have also used the "chiltern" / oxford parkway route to arrive at Reading to turn the Night Riviera sets around.
Although I can't see that being a reason for South Eastern though - do they pay any attention to which way around the FC compartments are?
