EMR Class 170 updates
ChrisC
7 Oct 2018
Nottinghamshire
I expect EMR will need traincrew establishments to return to pre covid levels before the service is reintroduced.
I expect the same could be said regarding the pre covid timetable on the Robin Hood Line being reintroduced in December.
If the 2tph timetable was brought back between Nottingham and Mansfield Woodhouse, would 2 carriage trains then be sufficient capacity on the line to allow the 3 carriage 170's, currently being used, to be redeployed elsewhere where more capacity is needed? Certainly 3 carriages are not needed north of Mansfield.
bunnahabhain
8 Jun 2005
Does the arrival of these extra 170s mean we will get the Matlock to Nottingham services back and so actually have trains calling at Spondon again?
Targeted services coming back in December, I suspect a handful of peak time trains and maybe first and last but have no firm intel.
RailWonderer
25 Jul 2018
All around the network
This may have been covered before but does EMR use pairs of 2 car 170s? I know XC do all the time. I just get irritated by seeing 2 car 156s still doing the Norwich Liverpool and think that route needs more capacity and better seating already. It's the flagship EMR regional route yet they see it as an afterthought.
Also I know 4 of those 2 car 170s EMR have are from TfW in GA livery but are the other 4 2 car ones ex-LNR?
Andy Pacer
11 Jul 2017
Leicestershire
They have 170530/1/2/4 from West Mids Railway, still with the green seats.
TheBigD
19 Nov 2008
Currently on 1 of the 4 from TfW is currently with EMR, 170273. The other 2 car 170s are all former WMR units, and the 3 car 170s are ex Scotrail.
An additional 3 car (170638) is on hire for the summer from XC.
45076
4 Feb 2021
Midway, South Derbyshire
The two cars are thus:
1 ex TFW 170273
6 ex WMR 170511, 170515, 170530, 170531,170532, 170535 (may be with WMR)
this list is only as accurate as the data on https://www.ukraillog.co.uk/165-172
TheBigD
19 Nov 2008
For completeness the EMR 170 fleet will eventually be 44 units, unless thongs change again...
2 car units (27)
170270- 273
170501-517, 530-535
3 car units (17)
170201-208
170416-424 (I think*)
There is an increase of 6 x 3 car and a reduction of 6 x 2 car from what was originally proposed for the EMR franchise, a gain of 6 centre cars.
* 4 went to Southern and got renumbered/reforned/converted to 171s but will be back as 170s with EMR at some point.
45076
4 Feb 2021
2 car units (27)
170270- 273
170501-517, 530-535
3 car units (17)
170201-208
BigD that's my understanding of the mess too
Andy Pacer
11 Jul 2017
Leicestershire
And these latecomers are a piece of the jigsaw which is causing the retention of class 156's and services not being back to full timetables.
LowLevel
26 Oct 2013
There aren't really enough trains to run them around in multi regularly, but it does happen. There's a 5 car set on a Skegness diagram today due to overcrowding on other 2 car services - 2 Worksop round trips cancelled to provide the 3 car set.
Currently present are:
170273
170503, 511, 515, 530, 531, 532, 534
170416, 417, 418, 419, 420
170638 (on hire)
Next to arrive are 421 - 424 from GTR within the next month or so.
43102EMR
28 Mar 2021
170273
170638 (on hire)
Will the 171s be in straight away for conversion back to 3 car 170s, or will they enter service as soon as they’re transferred?
LowLevel
26 Oct 2013
They need their conversion work doing, they're not much good with Dellner couplers!
Chiltern006
3 Oct 2018
i still think Norwich to Liverpool should be a meridian considering it’s longer than most (all?) IC services. however would be a problem as 222s don’t like stop-start afaik
Class172
Quizmaster
20 Mar 2011
West Country
There’s also the matter that the seating density of a 222 does not match that of a 158 nor 170. I can’t remember the specifics but you need to use more carriages to form the equivalent capacity for a service.
class26
4 May 2011
Been discussed to death. 222`s cannot use higher speeds east of Peterborough which would see very low speeds applied and time lost. Others will know what speeds would apply
Andy Pacer
11 Jul 2017
Leicestershire
Many threads available on 222s (and others) on Liverpool Norwich including this one. As the previous poster rightly says its been discussed to death!
Doomotron
25 Jun 2018
Kent
Despite their length the capacity is too low to realistically run the service.
Mollman
21 Sep 2016
I think the issue on Liverpool - Nottingham / Norwich is the need for corridor access between sets.
RailWonderer
25 Jul 2018
That thread is closed but I was thinking EMR could remove first class from some of its Meridians but then they are too heavy to use sprinter speeds, the same reason why 170s were used on parts of the Transpennine over 185s for a while.
Failed Unit
26 Jan 2009
Central Belt
Maybe one for a different thread, but considering the overcrowding now, will the following ever happen?
1. The pre-covid timetable restored (ie hourly Lincoln - Leicester, Nottingham - Matlock, Nottingham - Mansfield Woodhouse etc)
2. The proposed December 2022 timetable (Hourly Grimsby - Leicester, better frequency on Joint line etc)
I really think the current timetable is constraining growth.
I know various press releases have stated that Nottingham - Liverpool will go to 5 car 158s once the stock is available. (The 170s to free the 158s from the rest of the regional routes) - Hopefully 3 car 170s will help on some of the busier Leicester - Lincoln - Grimsby trains if the increased frequency never happens.
Rick1984
23 Aug 2012
5 car Nottingham to Liverpool is great but what about Nottingham to Norwich? That been overcrowded the whole 20 years I've been travelling it. 2 carriages is nowhere near enough
43102EMR
28 Mar 2021
Was never an issue back in the Central Trains days - not to mention 5 carriages (i.e. a 158 and a 3 car 170) are better than 4.
Andy Pacer
11 Jul 2017
Leicestershire
Could always send the 3 car to Norwich rather than 2 car once the 5 car splits at Notts.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
It’d require hybrid 158s to be made then, I assume.
TT-ONR-NRN
30 Dec 2016
That had been discussed somewhere but there are so many threads discussing Liverpool/Norwich it's hard to say where!
Fair enough. As there’s no further information on it, probably best not to speculate then. I just assumed from the publication as other than using Northern’s 158(75x) fleet there’s no other way to utilise three carriage 158s.
