Engine fire on Chiltern 68013
Dinoman
27 Dec 2019
Devon
Just seen some news of an engine fire on 68013, currently sat on the down Dorridge at Budbrooke Junction. Driver has reported an explosion and fire in the engine room.
The source of this information was from SE Facebook gen group.
Speed43125
20 Jul 2019
Dunblane
On balance, probably good this happened with such low passenger numbers.
How long can onboard batteries in mk.5a keep hotel power running?
1 Feb 2018
Struggling to see how this is relevant, do you mean mk3? It depends, dont know what generator the DVT has, so it might not be entirely dependent on the 68 in this case
Peter C
13 Oct 2018
GWR land
I've seen chatter that 68015 was sent to rescue but that has failed too. Might be Chinese whispers however...
A friend has sent me a screenshot of www.railcam.uk which appears to show 68013, 66779, and 68015 all under the allocations heading. All listed there by different people. It also says 68015 has failed.
-Peter
800002
19 Jun 2019
Believe 5Z99 due to be underway shortly back to Wembley LMD after further checks made.
Must have confidence as 1R39 has just been released past Banbury, so failed unit shouldn't be there much longer.
43095john
16 Jan 2009
-Peter
Seems the info surrounding 66779 was wibble. It was never sent to rescue as 68015 hadn't failed.
68015 now taking the whole consist to Wembley left Warwick at 1557
Peter C
13 Oct 2018
GWR land
That's what I've heard. Why 66779 came up, therefore, is a mystery to me!
-Peter
Peter C
13 Oct 2018
GWR land
Odd as its showing as being at Longport!
Ha!
It's 66 789 confirmed as hauling 68 013, 68 015 and the carriages to Wembley.
Ooh - the plot thickens. I was under the impression that it was just the 68s?
-Peter
EDIT: RealTime Trains is currently showing 66789 as being on https://www.realtimetrains.co.uk/train/H08452/2021-02-03/detailed (6M59 1402 Scunthorpe Roxby Gullet Gb to Collyhurst Street Gbrf), so not sure what's happening there. I understand RTT may be wrong.
trainmania100
8 Nov 2015
Newhaven
Chap called Alan and Chris, but if somebody has seen it pass railcam as tnt with no 66, then obviously it is now confirmed as having no 66, unless they somehow missed the 66 on the cam,
Maybe the 66 is invisible
221129
21 Mar 2011
Sunny Scotland
And not told Network Rail.
warwickshire
6 Feb 2020
leamingtonspa
Live rail record under 5z99 1600 Warwick to Wembley under members sightings correctly shows 68015 and 68013. No mention of 66. 66 is most likely up north on its booked job. Just a wind up in my opinion. Rumour mill.
trainmania100
8 Nov 2015
Newhaven
Slightly off topic and im not sure what the actual restrictions are around the depot, but according to this recent Facebook post, 66s are barred from wembley LMD anyway,
(Although the 56s doing the recent wembley to Bristol are co-co so maybe it's just inside the LMD sheds they can't go )
DB
Guest
18 Nov 2009
60s and 50008 have done that run as well fairly recently.
The Chiltern DVTs do have an ETS generator, but don't know whether they are used any more - they were put in to avoid having the 67s idling and annoying neighbours, but the noise from a 68 is less intrusive as it's lower pitched.
rustbucket
3 Jan 2016
Stood next to a DVT at Leamington 18 months ago or so and the DVT gen set certainly sounded like it was still being used
Speed43125
20 Jul 2019
Dunblane
Yeah, sorry, I must have been completely of my rocker when I said that.... DVTs have a generator on Chiltern.... I already know that.
Sorry mate.
Crossover
4 Jun 2009
The 68’s are still not exactly ‘refined’ when it comes to noise output, particularly when providing ETS!
StaffsPM1
7 Oct 2017
Almost none of the DVT ETS gen sets work for various reasons. I think only one now works!!
