Had a loss of power but was able to restart and get going.Does anyone know what was the issue
With 67010 this morning please
Thanks
It also had issues with a cab door which is why it was heading to Crewe for repair in the first place.
Thanks
ThanksHad a loss of power but was able to restart and get going.
Appears that decision was made very late on and the set made it to Canton by 01:30.Thanks
1V31 is a pair or 197s not a 67 & Set
67008 & Set 5 ran empty back to Canton 5Z50 from Crewe last night
Should work 1W55 this morning
Yes, HD01 was out on a test run.Surprised to see a Mk4 set reverse back to Crewe at Shrewsbury today at 1625.
Seemingly an ECS/test move?
RTT says it was HD01 with 67 017.
2-car 197s today on Holyhead and Manchester services, full and standing. Not nice.
67017 Had a fuel leak. Not 015.State on play at Crewe depot today (4/9/24):
*67010 (coolent leak) on HD04
67015 (fuel leak)
HD07 with no loco
67017 HD01 arrived back from Test on 5Z02 from Shrewsbury.
Not a good day for 67s on Crewe depot.
*DB Cargo came and had a look at 67010 but couldn't find where the coolent leak was coming from.
Believe the Marches had some problems earlier today, believed to be a tree falling, resulting in HD05 losing around 30 minutes between Abergavenny and Newport, unsure about the other sets and how they're doing.Have noticed that with the bad weather today(Thurs 5th Sept) that the MK4 sets seem to be running few mins late, where as 197’s seem generally be more on time. Seem to be long station dwell times etc, so do the 67’s and MK4’s struggle in the wet with brakes and doors etc?.
Yes Not any planned Mk4s for the weekends of the Marches blocks.Looking around at RTT for Saturday and Sunday, since the Marches is closed I'm assuming no MK4s are expecting to run. Can anyone confirm this?
Bad weather? Do you mean warm weather ?bad weather today(Thurs 5th Sept)
Been there for months. Just being kept out of the way, AFAIK.I’ve just been past Bristol Barton Hill depot, and there ex Virgin etc MK4 set there(Fri 6th Sept), so what is it doing there?. Was heading Cardiff-Taunton after Cardiff-Holyhead return trip on the MK4’s.
I think it’s some of the coaches to the potential ‘HD08’I’ve just been past Bristol Barton Hill depot, and there ex Virgin etc MK4 set there(Fri 6th Sept), so what is it doing there?. Was heading Cardiff-Taunton after Cardiff-Holyhead return trip on the MK4’s.
Extra MK4s as part of the set, HD08, which is to be looked at to see if it's serviceable.I’ve just been past Bristol Barton Hill depot, and there ex Virgin etc MK4 set there(Fri 6th Sept), so what is it doing there?. Was heading Cardiff-Taunton after Cardiff-Holyhead return trip on the MK4’s.
12434 isn’t in HD07.In terms of current formations can someone confirm / clarify if 12434 is now part of HD07 and whether 12461 is included in HD06?
Also, i understand that 82204 is the spare but where is it kept please?
Understood.12434 isn’t in HD07.
12461 is in HD06.
Not sure on 82204 unfortunately.
That post says it would be going in HD04! The sets were always planned to be reformed with the original TO inserted which they were.Understood.
Post #4238 from @sd0733 suggested that 12434 would be in HD07 but couldn’t recall if it had been confirmed, still yet to happen or not happening at all!
No worries.Apologies, I must have misread it.
Thanks for the clarification!!
AFAIK it's still "paused". Nor heard ant other dates, never aay never bit wouldn't be surprised If it ends up at the December timetable change.Any updates on the 5th diagram? Still can't see advance first class tickets, but still showing as such avaliable. I'm unsure, since if it does go as it says First Class avaliable, next Monday.
The first date I can see on RTT is the 9th of September, since the first week of September shows the North services as standard only and South bound as Standard and First, so I'm unsure about it. But the one with all First and Standard seating is the 9th. So potentially then. Might be wrong though..
Pushed back as it was changed to a non-MK4 following the postThe 18:30 from Manchester to Cardiff isn't MK4 today
