Hi all, after some advice please. I recently sat an interview for Depot Driver with a TOC and today received a letter informing me that I had been unsuccessful in my application. I passed the all then psychometric tests on a separate date however. Just wondered if this counts as one of my life's lost so to speak? I am aware this forms part of the assessment process but wondered the process is split, so basically if you fail the psychometric tests that's one life gone, and if you fail it a second time that's it for you, but if you fail the psychometric tests once, resit and pass them, then fail the interview, whether that's still the end of the line, or because they're two very different tests, you get at this?
My other question is that I was told I haven't been successful, but not that I failed the interview. I guess only the TOC can answer this, but does that necessarily mean I failed the interview, or that there was another more suitable candidate, and I still passed?
Reason for these questions is that back in 2011 I failed the psychometric tests (in the old style), then this time round I passed but apparently failed the interview and it seems a bit unfair to have two goes at the most, regardless of which part you failed.
Thanks!
Thanks!
