To which oneMight be a poor man's 170, but calling it a modern-day Pacer is a bit harsh, no?![]()
Why are the 195s hated so much? They are a poor man's 172 but are still pretty good trains.Might be a poor man's 170, but calling it a modern-day Pacer is a bit harsh, no?![]()
They could be really excellent if they hadn't been built to a botched specificationWhy are the 195s hated so much? They are a poor man's 172 but are still pretty good trains.
For shorter self-contained branches I would like to see battery MUs with rapid chargers at both ends. Ordering still more small DMUs, however cheap would seem like a bad idea.
I think in many ways the 195s may end up being the pacer replacements - 2 car non-gangwayed DMUs will end up being cascaded to minor branch lines that don't have the economic case for electrification, as they are replaced by EMUs on metro and inter-urban type routes.
That's an issue that can be partly solved with a battery buffer in the terminal charger, that trickle charges it all day, but I agree it won't work everywhere. Personally I hope that the gas network is switched off and we move to electric for domestic heating and cooking rather than go down the H2 route - I can't see how they would get it to work, and H2 in that sort of quantity isn't very environmentally friendly even if they did.This is making the assumption that small branch terminii will have the infrastructure to support fast charging a pretty large vehicle. Having had half my flat rewired recently & chatted to the ( pretty well connected ) electrician a lot, that does not seem like something you can assume. Having a lightweight unit with bus-based power eggs/rafts/whatever you want to call them you can change later on without reconstructing half the unit does seem like something to aim for ( this is not limited to lightweight DMU replacements, ofc ).
One thing that came up during my chatting was plans to replace natural gas with hydrogen in the gas network. I personally think that sounds like a somewhat unworkable nightmare of leaks ( h2 molecules are so much smaller than hydrocarbons ) but if that issue can be solved then that is also a power distribution network, whether you have fuel cells at substations ( which would still need battery piles to enable fast charging anyway ) or on vehicles.
