The tender says:
Does that coincide with the Turbo fleet refub?Quote:
Duration of the contract or time limit for completion
Starting 9.12.2014 Completion 31.7.2016
anthony263 said:I wouldnt be too surprised if 150921 and 150927 do move to Reading since 150001 and 150002 are already there, perhaps one unit can be used on one of the Thames Valley branches.
And why wouldn't you be too surprised? The place in the Thames Valley where ever more capacity is needed is the main line, not the branches, nor the self-contained diagrams the 150/0-worked Reading-Basingstoke line represents, so another pair of 75mph units would be little use in a context of 90mph timings, have far too many seats for the branches and are rather useful around Bristol...
If you put a 150 on a branch though you free up a Turbo for the mainline, which is what happened with the Reading-Basingstoke services. I'm not sure what other services you'd convert to 150s mind so I doubt it's going to happen.
Yes, but the deadline for the 15x fleet to be modified would be 2020 would it not? Bearing in mind that there will be an influx on Turbos at some point in the future they could potentially go away to be modified then as well. The introduction of LHCS could simply be to provide some much needed extra capacity.
...However, is there any particular reason stopping FGW from using a 150 on the Thames Valley Branches? I.E Windsor, Henley or Marlow and basing it out of Reading?
I know drivers and gaurds would need to be trained up for this, but what about FGW sending down their 2 car 158 to cover for the Greenfords?
The contract may say this:
Starting 9.12.2014
With FGW having to use 150s on some West of England services where 158s would be better suited you could hardly waste one on the Greenford Branch. In anycase using anything else bar Turbos and 150001/2 would be far to remote from their Maintenance bases, PM or EXI say no chance of that happening especially if FGW are planning to increase the Cardiff - Portsmouth Hbr srvices to 4 carriage operation
How many 158 diagrams do FirstGW have at the moment? Where are they used other than Cardiff - Portsmouth and Brighton - Bristol (and is there still 1 3-car 158 on Cardiff - Taunton)?FGW would have 20 2-car 158s if they split them back down, plus 3-car 158798. Portsmouth-Cardiff needs 8 diagrams, so 16 units for 4-car operation. It would definitely be possible, but would lead a shortfall of units elsewhere that the LHCS would have to cover.
Which is the planned start date for Manchester - Liverpool electrification - which might just leave some 150s free for redeployment.
Be made DDA compliant?I very much doubt it. What would FGWs 150s do.
8 on PMH-CDF
2 for the 2 Brighton diagrams
1 on TAU-CDF
So 11 diagrams for 14 units.
14 units?
I thought there were 13 3 coach units-
158950-961 (12) and 158798 (makes 13).
