Flexity Strip track circuits
Vindaloo 42
4 Mar 2021
Oxford
Do lines relaid with Continuous Welded Rail (CWR) still require flexity strips between the track circuit gaps?
GB
16 Nov 2008
Somewhere
I assume they are talking about the continuity bonds found across fishplate joints on jointed track?
civ-eng-jim
16 Jul 2011
Derby
Ah.
I know for renewals on points the track panels bond holes are drilled at the rail ends but believe that's just for temporary phase where the track is clamped together before welding up the following week.
MarkyT
20 May 2012
Torbay
Aimed at the Minor Railways Section, this IRSE document covers the traditional methods of track circuit bonding.
Where track circuits are used, some sort of bonding is always required along with insulated rail joints in turnouts and crossings, even where otherwise completely welded construction is employed. On plain line, welds are considered electrically perfect, requiring no bonding around them, although the extremities of track circuits will still need to be connected to the rails by cabling, even where 'jointless' products such as the TI.21 are used. Axle counters change this, however, as will other future train detection methods.
mcmad
11 Mar 2015
As Jim says other than the temporary pre weld situation there are no bonds across welds in S&C. There are 'pigtails' between the switch and stock and sometimes at the crossings if fab'd crossings.
MarkyT
20 May 2012
Torbay
Examples of S&C bonding from the IRSE document I linked to earlier. The coiled bonds shown in the first example are the 'pigtails' referred to.
MadMac
13 Jun 2008
Moorpark, CA
I spent 40 years as an S&T Engineer but have been out of it a few years now. I haven't a clue either :lol: Must be some new fangled thing, or.......?
42 years and counting here, and it’s not a term I’ve ever heard. Suspect it’s some sort of bond.
themiller
4 Dec 2011
Cumbria, UK
Could it be a symptom of autocorrect putting flexity when Vindall 42 actually typed flexible? In typing this, I was corrected to flexitime!
Annetts key
13 Feb 2021
West is best
Steel galvanised bond wires are still required across joints until (if) the rails are welded together.
And between different switch and crossing components as described by MarkyT in post #8.
At rail expansion joints (to allow for rail expansion and contraction), although steel galvanised bond wires are sometimes used, normally 2.5mm² flexible rubber single core cable is used.
And with conventional track circuits (not audio frequency jointless types), the same cable is used for parallel bonding (to prevent any dead sections in the event of a broken rail or broken bonds) and for the feed end cables and the relay end cables.
seagull
28 Feb 2011
To turn the initial question around, how are track circuits separated in Continuous Welded Rail areas? Does the rail have to be cut and an insulating piece put in?
alxndr
3 Apr 2015
No, they use audio frequency track circuits instead, most commonly now EBItrack200 (formerly known as TI21). In these the rail is continuous and voltages of different frequencies are used to divide it into sections. The separation is done entirely electronically.
Is it something to do with the old ASTER Track circuits?
20 years on Track Renewals and never heard of Flexity strips either.
Not something I've come across with Asters either. I'm also of the opinion it's probably a typo/autocorrect error.
Annetts key
13 Feb 2021
West is best
Depends on if conventional track circuits are used, in which case insulated rail joints (IRJ or IBJ) are used. Or instead as said above, audio frequency track circuits are used. These use filter units and different frequencies to separate the different track circuit sections. No need for a IRJ or a break in the rail. Hence the railway preference for this type of track circuit on long sections of CWR.
MarkyT
20 May 2012
Torbay
Indeed, jointless track circuits have been available since the 1960s, when continuously welded rail really started to become popular worldwide. The Aster 'U type' (universal) and the earlier '1 watt' (self-explanatory!) were early types employed in UK. ISTR the Aster TC was a French product originally. By the 1980s when I started on BR, Aster had given way to the more sophisticated TI21 (EBItrack200) as the standard jointless TC product for new schemes. That had the advantage of being compatible with DC and AC electrification, subject to certain configuration constraints. Of course there were still plenty of Asters out there in existing installations for decades to follow. I suspect Asters have become rather thin on the ground out in the field by now though if any still survive.
An interesting paper about the tech here: https://dickthesignals.co.uk/onewebmedia/aster book.pdf
Annetts key
13 Feb 2021
West is best
ML engineering (Plymouth) made the ASTER units under licence from the French company. But went on to develop their own version that was compatible. Hence some units had ASTER written on them, but later units did not mention that name...
ASTER ‘U’ type were in use on Western up until about five years ago. The main reason that they were phased out was due to the lack of spare tuning units and ACT track side units. Most were converted to TI21/EBI types, which is a more modern equivalent.
MarkyT
20 May 2012
Torbay
Thanks. So it follows the TI21 has a direct lineage from the Aster products.
MarkyT
20 May 2012
Torbay
The TI21 equipment had the same style of housings as the Aster gear. It was essentially an AC-immune version of the Aster.
Makes sense. The TI was simpler in application too, with only two trackside tuning units per TC boundary rather than requiring a third unit, known as the track transformer, between them for the Aster.
alxndr
3 Apr 2015
There were still some in use on the western up until last year, and I’m almost certain that they’re still there now. The spares are indeed becoming hard to come by now though. Some have been turned into hybrids, with TI21 equipment one end and Aster U the other. The frequencies used as close enough that they work.
So are we any clearer on what a “flexity strip”, (as the OP described it), actually is, because if not aren’t a few replies going off into unnecessary detail? Noting that the first two replies weren’t already aware of the terminology?
Annetts key
13 Feb 2021
West is best
Do you have any idea where?
No. I don’t know what he means.
If you go back to the past, to earlier than 1987, there were alternates to Steel galvanised bond wires. But I don’t think they were called “flexity strip”.
