tsr
You won't find many 'breakaway windows' on trains nowadays. They were all replaced with toughened glass on the basis that retention of passengers within the vehicles is a greater concern in an accident than escape. Have a look next time you're travelling and you'll notice all the hammers have gone. Automatic supression is limited to the fire bottles beneath the solebar on DMUs, saloons get manual fire extinguishers. Struggling to think of any other 'flavours' of fire protection, aside from the use of retardant materials.
Window hammers still exist on numerous trains, including modern stock such as most Electrostars and Turbostars (and they do work, too). They may not be visible but they are most definitely in the equipment cupboards and cabs, the former being accessible for passengers by means of an emergency handle. Obviously it is rather hoped that on power-door stock there will be at least one external door leaf or one gangway door to provide an exit in an emergency and convenient emergency services access, which I suppose is partly why hammers are less visible. On slamdoor stock, as an example, ideally windows need to be exit routes as you would struggle to unlock and push open a heavy manual door on a train which has [partially] overturned, but in such an event you also have to weigh up the ejection risk and the possibility that the gangway connections may be severed and provide added escape routes.
As for automatic fire systems, not only do many trains have fire bottles under the solebar, but some stock also has automatic suppression in non-driving cabs and you also have newer systems to extract smoke automatically, such as is found on Desiro Cities. Then you get little-known innovations such as gangway doors preventing access to coaches where smoke alarms have activated, which has been present on 377s since their introduction. These also act to suppress fires by not allowing movement in close proximity to open the doors automatically, thereby sucking in oxygen from the rest of the train, whilst still maintaining an exit-only route if anyone is trapped. Etc. etc.!
