Flooding: 26th October - Stafford - Stoke and the North West of England
Deafdoggie
29 Sep 2016
A fair bit of rain over the last 24 hours but hardly apocolyptic. It shouldn't cause that much chaos.
The slightest bit of extreme weather these days (heavy rainfall, minus temperatures, snow, heat) and the rail system grinds to a halt.
There really has been a lot of rain in Staffordshire. Many roads were closed. A lot still are. Including a stretch of the M6. If an area floods, an area floods. What do you want them to do?
Ambulances were stuck getting to emergencies. If a route (road or rail) is flooded, it's flooded.
There's really little else that can be done except wait for flood water to subside An embankment on the M6 suffered a mud slide. It's not just a rail problem.
InOban
12 Mar 2017
These intense rainfall events are always focussed on a narrow line along the front. Unless you were underneath it, I don't think you can appreciate what 100mm of rain is like. It is a prediction of global warming that these extreme events will become more common. We had one which washed out the WHL only a few weeks ago.
rdeez
7 Apr 2013
Looks like the bi-directional signalling installed when Stafford was re-signaled is coming in useful tonight...quite the queue building up there at the moment.
I have family there and the flooding is really quite bad in the area at the moment from what they've told me. Quite a few roads impassable as well.
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
Virgin have ended up in CSL2 Black tonight due to the weather and subsequent flooding.
Bad couple of days, yesterday there was an incident at Wembley which meant that services to London were suspended for a good few hours and now today with flooding.
Sam
Higginsafcb
27 Sep 2018
Had a fun trip north on 18:10 Euston_Chester. Held at Nuneaton, and eventually terminated at Stafford where the Virgin Staff had utter chaos to deal with several train loads of passengers. Eventually a few services slowly forwarded to Crewe. Then an expensive taxi ride to north wales as no coaches could be sourced from Crewe.
Furryanimal
4 Jun 2018
Cwmbran
The line between Newport and Hereford is closed for about a week due to an embankment being damaged at Pontrilas.Hope someone eventually decides that they can run trains up to Abergavenny but TFWs journey checker suggests they won’t be.
30907
Open following link and scroll down to Section 4. http://www.ttweb.co.uk/rulebmods/m/m3.pdf
To save others the trouble:
(4.1. is the instruction to drivers)
4.2 Train running
When you receive a report of flood water, you must tell Operations
Control immediately.
You must find out if the flood water:
• is up to the bottom of the rail head
• is up to the top of the rail head
• is above the top of the rail head
• is moving and likely to dislodge the ballast
• has dislodged the ballast.
As long as the flood water is not moving and likely to dislodge the
ballast or the ballast has not been dislodged, you may allow trains
to:
• continue normally if the water is up to the bottom of the rail
head
• run at a maximum speed of 5 mph (10 km/h) if the water is no
deeper than the top of the rail head.
If the water is deeper than the top of the rail head, you must:
• suspend the normal running of trains
• tell Operations Control and wait for further instructions
jfollows
26 Feb 2011
Wilmslow
Does anyone have any idea about Rail Replacement Buses tomorrow from Stoke to Stafford?
Fortunately, it appears that the line has reopened in time for services on Sunday.
"Yesterday, flooding in the Stafford area resulted in major disruption between Stafford and Crewe and also between Stafford and Stoke-on-Trent via Stone.
Inspections took place overnight and all lines have now been reopened.
Some morning services may be disrupted due to displacement of trains and staff."
Residual problems indicated around Sandbach which, if they are resolved today should not have major impact on services.
  • Sandbach Sunday morning 27 October 2019.pdf
PHILIPE
14 Nov 2011
Caerphilly
See Posts #27 and #28
PHILIPE
14 Nov 2011
Caerphilly
There is a track washout at Pontrilas so the Hereford-Cardiff line is expected to be closed for 2 days according to Network Rail
Not going to help TFWs stock having 2 fleets separated for a while. Most of the ones trapped in the North seem to be 150s aswell!
Use Heart of Wales line which is due to re-open later today following it's own flooding problems
mpthomson
18 Feb 2016
Except they aren’t becoming more common statistically.
43055
8 Mar 2018
I got a Rail Replacement Bus from Stoke to Stafford this afternoon. It left Stoke at 1630 and took 25 mins. to reach Stafford.
I needed to get back to Derby and the only way was bus to Stafford then LNW to Tamworth and XC from there to Derby.
EMR hadn't arranged any buses from Stoke to Derby via Uttoxeter.
Not sure why no buses were arranged. Maybe EMR didn't want to risk the buses getting stuck? From Facebook posts it sounded quite bad just west of Uttoxeter with one village being cut off by flooding. Around Tutbury and Hatton the fields alongside one road turned into lakes in just 3 hours while I was out yesterday.
craigybagel
25 Oct 2012
Abergavenny doesn’t really have space to be a terminus for replacement buses unless you shut the car park off (which brings its own issues). I would have thought Cwmbran more likely.
The logistics of turning trains around at Cwmbran are very awkward. The signalling isn't ideal for it, but more awkwardly then that is trying to find units and crews when their availability will already be compromised by the issues across the network. For the minimal gain you're better off running the buses from Newport instead, which is what TfW are doing.
Robertj21a
22 Sep 2013
Were buses, and drivers, available at short notice om a Saturday ?
It's probably more likely that EMR tried but the coach companies didn't want to risk their coaches getting stuck. They're often small family firms and wouldn't be covered by insurance for something wilful like that - and lose their coach and they've lost their company.
Robertj21a
22 Sep 2013
Very likely there were few drivers with enough driving hours left, coupled with a reluctance to work on a 'sports' and/or family day.
Trainfan2019
9 Aug 2019
I was affected yesterday on EMR. Roads were very bad round parts of Kidsgrove and risky to replacement coaches.
This deluge (not large by tropical standards) was exacerbated by being delivered by a long waving front travelling in a line SW to NE which was firing at the same area of the UK for an extended time.
The same front travelling NW to SE would have been unremarkable, with heavy rain lasting for a few hours only.
Llanigraham
23 Mar 2013
Powys
Photos in here of the problem at Pontrilas:
https://www.bbc.co.uk/news/uk-england-50199254
Roads and rail routes remain blocked as the effects of heavy rain continue to cause problems across the Midlands.
In Herefordshire, part of the railway was washed away at Pontrilas, halting services to Abergavenny.
Network Rail said engineers would assess the track on Sunday and it was unclear how long it would take to fix.
Rail lines out of Shrewsbury to Welshpool, Wrexham and Crewe were out of action on Sunday morning.
Dozens of roads in Shropshire, Herefordshire, Staffordshire, Warwickshire and Worcestershire have been closed due to floods, including many rural routes.
CHAPS2034
13 Mar 2018
Spot on. Someone once described being under a waving front as being "under a conveyor belt of rain" and that's what happened on Friday and Saturday. The rainfall rate wasn't particularly high, but was constant for many, many hours.
When the front eventually started to move off to the SE it went quite quickly, so areas further south would have had a few hours rain at most. In fact this one then started to break up, so the rain would have been lighter and patchier.
There are still some issues in Wales - Fishguard Harbour to Clarbeston Rd will be closed until 15/11 and of course the Marches line is out of action. Flooding is still affecting some trains in Yorkshire and Virgin have a lot of knock on effects still after last night.
31 Aug 2019
IW
Crewe-Chester is also affected, and other places nearby.
There's a notorious stretch on the line just east of Calveley which suffers from field runoff whenever there is heavy rain.
After 26 hours of heavy rain around here it has eased off now, but there is still a lot of landwater to get rid off.
It will take a day or so for the rivers to peak.
It's also not that uncommon on the west side of the country.
Is the PWay cabin still at Calverley?
It use to be right next to a smashin little pub on the Nantwich road
Meerkat
14 Jul 2018
Fishguard to Clarbeston Rd- how can it take over two weeks to deal with “unsafe trees”?
CHAPS2034
13 Mar 2018
Depends where they are - may be high up in a deep cutting?
Possibly the slopes where the trees are has become unstable in the wet conditions and that needs strengthening?
May be other reasons too?
I'm sure the engineers know what they are up against and roughly how long it will take to make the situation safe for trains to pass.
