Hi all,
Not sure if this has already been mentioned but tonight (Friday 22nd April) between 2100 and 2200 on ITV there is a documentary about the Flying Scotsman.
Kind regards.
Not the greatest piece of TV. Has already described a loco under restoration as "rusting away", whilst Flying Scotsman is, apparently an A1![]()
It was indeed.Wasn't the locomotive that was derailed in this incident call Merry Hampton?
Were there not some factual errors regarding the story of a train being derailed near Cramlington, Northumberland by striking miners in 1926? The script gave the impression that it was the locomotive Flying Scotsman that was derailed rather than the passenger service train of that name. Robson did say it was the train Flying Scotsman that was derailed, then adding that it took two years for Sir Nigel Gresley to restore it, seemingly referring to the locomotive.
Robson Green described Flying Scotsman being built as the new A1 class. This is factually correct. Flying Scotsman was built as an A1 with a 180lb boiler and short valve travel. When the GWR had demonstrated to Gresley the advantages of long valve travel and higher boiler pressure as used on their Castle class which outperformed the A1s on the loco exchanges in both hauling power and coal economy the A1s were modified by fitting long travel valve gear and upping the boiler pressure to 250lb and were re-classified A3. The remaining A1s were reclassified A10 before modification.
It was nice seeing Peter Townend. Some years ago I met him and he was kind enough to autograph my copy of his book, "Top shed" for me. Like a fool I loaned it to a colleague who, some weeks later denied all knowledge of me lending it to him.
I thought the A3s were 225lb, with the A4s being 250lb, hence the trouble FS had in preservation after being fitted with the higher pressure A4 boiler.
Could someone explain how the higher boiler pressure than that originally designed for causes issues on a loco? I am guessing its along the lines of those who 'chip' their cars or boost turbo pressures and wonder why the clutch, gearbox or worse subsequently fail.
Once again a programme on railways thats obsessed with steam - I was brought up with diesels and electrics and we never seem get any programmes about them.
There was also the usual claim of the first 100mph run. That statement really should include the word "verified" as it's highly likely that City of Truro managed that feat many years earlier but without verification. And I speak as someone who has always thought a copper-topped chimney to be a ridiculous ornamentation.http://www.railforums.co.uk/images/smilies/icon_wink.gif
Ironic when Robson Green called Flying Scotsman a train early in the programme and was admonished by whoever he was talking to saying it was actually a locomotive. At that point I felt in need of something more believable and switched to the Blues Brothers on Dave.
If you put a new boiler, eg a 220 psi boiler on a locomotive designed for 180 psi, you get (when the boiler pressure is at its maxium) a (approx - in my head) 22% increase in the force on the piston
(from 220-180/180 = 40/180 = 0.22)
So, just imagine, all your motion, the rods and the bearings designed to take a maximum force created by 180 psi suddenly finds itself straining with forces 1/5 as big again.
Then there is the question of the frames that have to provide the opposite forces, trying to keep the wheels and cylinders in their right places.
. . . reduce the size of the cylinder bore, so as to reduce the area exposed to the higher pressure, and so bring the total forced on the motion down to what it was with the original lower boiler pressure.
Again a standard presenters trick to sensationalise the story.
When A1s became A3s and gave up their original 180 lb/in2 boilers .......
Or perhaps it was just the standard trick used by presenters to "learn" something for the benefit of the audience. Not everyone within the target audience group will be an expert like you are.
We had a discussion on this a few months ago. try searching for, hmmm, I forget the title. Maybe it was A4 boiler or some such. HTH
My point was that Flying Scotsman is a train as well as a locomotive
and they got that wrong later in the programme when talking about the train (not hauled by that locomotive) being derailed during the General Strike.
True but the NRM, Rileys et al have definitely been engaged in restoring a locomotive, not a set of coaches or a daily steam hauled train service of the same name, unless I'm terribly mistaken and there's a regular open access operation using teak coaches being planned behind the scenes as I write! Inspired by the fact the loco was named by the LNER after their crack train as a publicity exercise for the 1920s Wembley Exhibition, I suspect the NRM are wilfully allowing the identities of loco and train service to once again become mixed and confused a little, all in the name of publicity. No harm in that really if it garners more attention from the media. Anyone with any deeper knowledge understands the distinction anyway.
That was a more serious factual mistake in my view as there was a very clear implication the particular named locomotive was involved and required extensive repairs, which it clearly wasn't and didn't.
