frodsham to London Terminals
a22book
8 Aug 2008
Hi Forum,
I have an off-peak single ticket for sunday Jan 13th for frodsham to london terminals any permitted route. I was wondering if I can travel to manchester piccadilly first, then get a train from manchester to london. Is this a valid route?
Many Thanks
Chris
LexyBoy
23 Jan 2009
North of the rivers
Appropriate routeing points for Frodsham are Chester and Runcorn.
Using Runcorn, you can use map CS to travel via Manchester - but this only allows silly routes to Manchester, and only from Manchester to London via Banbury.
Using Chester there don't seem to be any usable routes via Manchester.
I may well have missed something though. One option if you need to visit Manchester would be to buy a return from Warrington to Manchester (£8.80/7.90 Anytime Day/Off Peak Day).
BTW is the ticket a "Saver Half" bought in conjunction with an Advance ticket? The full-price Off Peak Single is very poor value at £76.30 compared to the return at £77.30 - I'd always advise buying the return.
soil
28 May 2012
Appropriate routeing points are Chester, Runcorn and Hooton.
An SVS is an appropriate fare for a fares check, and while the SOS from Hooton costs £2.50 more than from Frodsham, the SVS is 10p cheaper.
Hooton doesn't help though.
TCBC says:
From FRODSHAM to LONDON EUSTON via MANCHESTER PIC
Permitted by map GM+MA
25.09m over min distance
But GM+MA doesn't appear to be a valid set of maps for this journey, so don't know why....
LexyBoy
23 Jan 2009
North of the rivers
edit: checked the RG and seems I was wrong about that, sorry!
The fares check is not dependent on the ticket type being used for the journey. The SOS should be used wherever possible, followed by the SDS.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
I couldn't work out what was going on here, initially, until I looked at some depth. It's highlighted a really interesting issue with the routeing guide.
FRODSHAM is associated with these routeing points: CHESTER, HOOTON, Runcorn Group.
HOWEVER it seems that Runcorn East is NOT a member of the Runcorn routeing group, at least in the version of the guide I used to create the routeing system. Therefore on a journey via Manchester, the first routeing point reached is Warrington, from which map combination GM+MA is valid.
However, Warrington isn't a routeing point for Frodsham, so I'm guessing it's not actually Permitted.
This is the first time I've come across an instance where a station has services that don't go through an associated routeing point. It's got to be a mistake in the routeing guide.
a22book
8 Aug 2008
Hi,
Many Thanks for your replies, I'm still a bit confused to say the least?
The main reason i wanted to go from manchester is there are no trains from frodsham on sunday just rail replacement buses, which then leaves nearly an hour wait in warrington, ( if the bus turns up ). I can get a lift to manchester so thought I'd go from there instead. Don't think I'll take the risk.
As to the fare, it was booked through my work, I've often argued I could buy a cheaper ticket and often first class. O well !!
SickyNicky
8 Sep 2010
Ledbury
Sorry about that. I think the consensus is that the ticket is NOT valid via Manchester and then on to Euston. Sorry.
The problem has been that the Routeing guide that we use to check validity appears to have an error in it around Runcorn, which makes it hard to be sure. This same error appears to have confounded the online booking engines as well - they will offer the journey in one direction but not in the other.
Bidstonboy
21 Aug 2012
Yet again the routeing system baffles me. Frodsham is based on fares to/from Warrington(in the good old days of the fares manual), yet you say it is not valid via Warrington? Anybody travelling via Runcorn would have to wait for the once a week Summer Saturday only service!! Most TOCs websites give routeing via Warrington on journey planners too. In this case, a lift to Runcorn if offered could be an option as it's the same price, and would avoid a bus. Thankfully 99% of guards have the routeing guide at the bottom of their lockers under a thick layer of dust.
SickyNicky
8 Sep 2010
Ledbury
And me! Clearly this is a error in the routeing guide.
calc7
8 Aug 2011
And, rather perversely, the ticket allows Frodsham - HOOTON - Liverpool Group - Hunts Cross Group - Runcorn Group - CREWE - ...
soil
28 May 2012
Looks like the following changes needed to:
http://www.atoc.org/clientfiles/File/routeing_point_identifier.pdf
RUNCORN Runcorn Group Routeing Point Member
to:
RUNCORN Routeing Point
Plus:
Ellesemere Port:
Frodsham:
Helsby:
Ince & Elton:
Little Sutton:
Overpool:
Stanlow & Thornton:
Chester Hooton Runcorn Group
to:
Ellesemere Port:
Frodsham:
Helsby:
Ince & Elton:
Little Sutton:
Overpool:
Stanlow & Thornton:
Chester Hooton Warrington Group
and
Acton Bridge:
Hartford:
Winsford:
Crewe Runcorn Group Warrington Group
to
Acton Bridge:
Hartford:
Winsford:
Crewe Runcorn Warrington Group
Since Runcorn Group has already been deleted here:
http://www.atoc.org/clientfiles/File/group_stations.pdf
I think it would be reasonable to say that since Runcorn Group doesn't exist, or is in a state of limbo, and the appropriate routeing point Runcorn East, is not in fact a routeing point, but is itself associated with Warrington, so Warrington (which passes the fares check) is a valid routeing point, and hence the ticket is valid via Manchester.
SickyNicky
8 Sep 2010
Ledbury
And that's what TCBC is assuming. However, if you take the routeing guide literally, as it stands at the moment Warrington can never be an appropriate routeing point. Which means Manchester isn't Permitted that way.
kieron
22 Mar 2012
Connah's Quay
There are, you know. Chester-Manchester is valid on BC+TV. BC allows Chester-Wrexham-Shrewsbury-Crewe, and TV allows Crewe-Wilmslow-Manchester-Stoke-Stafford-Rugby-London. Chris would have to make sure he catches a train through Stoke, though.
While this would make sense (personally, I wonder whether anything would be lost if Runcorn Group was abolished, and the stations associated with it moved to Hunts Cross), I think there's too much invested in the idea of making a new route validator for the list to be updated again.
34D
9 Feb 2011
What would be the way to get this resolved?
Can one of us go to ATOC or does it have to be a TOC who refers the issue? If so, I suggest it be referred to a TOC who stands to gain (under orcats) rather than one who may see their share of this flow diluted.
I realise of course that routeing validity and orcats distribution are separate.
calc7
8 Aug 2011
Also, if travelling the full length of the route, the train from Crewe to Manchester would have to avoid Stockport (and so go via Styal [and, optionally, Manchester Airport]) - only a few all-stops trains per day permit this, in addition to the 1940 EUS-MAN which goes from Wilmslow to Manchester via the Styal Line.
Of course if starting short at Manchester; this logistical issue merely becomes a theoretical one in order to explain how you are not illegally doubling back from Stockport to Manchester.
