anthony263
I wouldnt mind one of the trains from the east west rail link to run to Swindon & Bristol if paths can be found.
By December 2017 they envisage the following services:
- EMU : Paddington Reading Oxford Bletchley Milton Keynes
I think it was also demand. It was unreliable as it was often cancelled, and people knew it wasn't guaranteed forever so didn't trust it in some respects. This would be quite different.
I'm not sure about Paddington - MK via Oxford frankly. I would have thought Reading/Oxford would be enough.
Services up the MML are a good idea though. Corby a decent enough place to terminate (and serve Wellingborough and Kettering a bit better) but serving Leicester and Nottingham would surely be better.
Wasn't the lack of paths the reason why the Bristol - Oxford service was scrapped a few years ago? (and with it the prospect of reopening Corsham?)
A Bristol - Swindon - Oxford - Bletchley - Bedford - Derby - Nottingham service I think would be brilliant and could allow a Bristol - London service to be sped up by running non stop through Swindon.
I think that the idea is that by running one train end to end you don't need two services one running Oxford to London and one running Reading to MK, whilst having the added bonus that it's possible to get between places such as Winslow and Maidenhead without going through London.
- DMU (fast): Oxford Bletchley Bedford
- DMU: Marylebone Princes Risborough Aylesbury Bletchley Milton Keynes
- DMU (local): Bletchley Bedford
- Freight (diesel)
I notice that the document does not state if it is a fast or local service. I have a suspicion that it might be an extension of a post-crossrail Paddington-Reading semi-fast service (5 intermediate stops) that would then run as an all stations service between Reading and Milton Keynes (taking the place of a current Paddington-Oxford stopper).
JamesRowden said:I notice that the document does not state if it is a fast or local service. I have a suspicion that it might be an extension of a post-crossrail Paddington-Reading semi-fast service (5 intermediate stops) that would then run as an all stations service between Reading and Milton Keynes (taking the place of a current Paddington-Oxford stopper).
Are you suggesting Crossrail will run to MK via Reading?!
Why would the "DMU (fast): Oxford – Bletchley – Bedford" service be operated by a DMU when the whole route is wired?
With Didcot power station non requiring as many coal trains as before perhaps some paths could be found for a service which will hopefully be more reliable than the Bristol - Oxford service operated by Thames Trains
For information Didcot A power station will close tomorrow - its generation limit having been reached. The last coal train has already run. Should free up some paths to the west.
The complexity all parties are tackling at present is the progressive opening of services and route electrification, fitting in with the wider national electrification programme (Oxford 2016) and the delivery of Chilterns Evergreen 3 (opening between Easter and May 2015).
- Freight (diesel)
By December 2019 the range of services could become
- EMU: Paddington Reading Oxford Bletchley Milton Keynes
- EMU (fast): Paddington - Oxford Bletchley Bedford (could extend northwards, e.g. to Corby, if there is demand and MML paths can be found, and from 2021 when a new link is built it could possibly go via Heathrow)
- EMU: Bletchley Bedford local
- Possible Southampton Reading Oxford Bletchley Milton Keynes Manchester
- Other passenger services may also possible for example Luton Borough Council would like to see Luton-MK direct trains and has been looking at three locations for a curve from the MML to the Marston Vale line
- Freight (electric and diesel)
The debate is whether extending the Paddington Oxford EMUs in 2017 and 2019 is worthwhile or if a smaller train formation is required on EWR from the outset whilst traffic develops. The Southampton Manchester is one way of gaining the 30 min long distance journey time reduction but the XC service might take a variety of forms. It could be a Reading starter if thats a better path. Mr Sexton is trying to encourage all parties to be realistic about traffic prospects as experience shows it take several years for new train services to build up demand, especially where it is expected to act as a catalyst for housing and job growth.
The extension of the Paddington - Oxford EMU's could be worthwhile, as it may be possible for the train split/join at Oxford with a short form train then running beyond Oxford whilst still enabling maximum length trains to run where they are needed. The only problem comes if the EMU's are needed to run faster than 110mph when there would not be the option to use corridor connecting stock and the problems that then causes.
This would make sense, provided it doesn't leave trains unused at Oxford for too long. What would be the problem with using non-corridor stock? Trains would operate DOO to Oxford and a guard could board for the run north from there (assuming they will be needed).
Because according to some people, coupling up trains without corridor connections through the end cabs is just about the worst possible thing that could ever happen on railways, despite which operators here and all over Europe and beyond will persist in doing it...
In the case of East-West rail, the electric trains being talked about would most likely be the new build of GW outer-suburban emus, ie 110mph limited, unless someone is going to order more IEPs, which seems highly unlikely, as most custom either side of Oxford or through it will be short-distance. This proposal looks more like a way to cut out lots of empty stock shunt moves around Oxford station in the future by linking up the two services.
This has been vaguely talked about by MK Council too but with no definite 'lines on maps.'
The green route requires less building than the yellow one (which has partly been developed upon east of Sandy) and is the one more likely to happen.
...aside from the fact the MML's full. The only way the green line's viable is if they start terminating a lot more services at St Albans, as that then frees up paths. Even terminating at Luton's not good enough, it has to be St. Albans.
If these issues can be sorted the green line is much better than the yellow one in my view. It Luton and its airport onto EWR, also meaning that some EWR trains could make MML connections here instead of reversing at Bedford. East Coast connections are also possible at Stevenage, whereas the yellow line misses all the large towns.
