randyrippley
- Joined
- 21 Feb 2016
- Messages
- 5,383
something to think about is that those Mirrlees engines probably have more value if sold for re-use than the entire locomotive's book value
I will take that with a pinch of salt. Is there any articles of this? I would love to read what the results are for the maximum speed that they did as they would not exceed 60mph without a tuneup as a minimum. But seriously though, the speed limiter would have to be disabled to make the Class 60 capable of exceeding 60mph on the mainline and also tuning and some extra gears would have to be added to make a higher speed viable without smoking the traction motors. I tried to run a 12 volt model train on a 22 volt DC supply and it went "pop"Except it didn't barbecue anything. North Wales Railday or whatever it was, Brush man with laptop in attendance and the pair of 60s went well above 60mph...
Here we go again .......![]()
A Class 60 doing 100mph!. That's new to me because they are limited to 60mph max regardless of what they can haul. I think without some serious modifications to the traction motors, that would result in a serious traction motor barbecue moment!
I am staying well clear of the Class 442 debate because there is enough froth floating about on here as it is mate. As for the mods side of things. I was just having a bit of banter
Don't get me wrong though, the Class 442's were good in their day and as much as I like them. The future for the 442's is either preservation at heritage railway sites like the MNR, NNR, NVR, ELR, SVR, GCR etc and perhaps Booth's for the really rough units that would cost too much to preserve. As times have changed and the travelling public want the latest trains. We are just rail enthusiasts.
However most of the Class 60's that are stored at Toton have a lot more reuse value. I did read a while ago that a Class 37 that was stored over 10 years was reinstated back into traffic (It could have been 37501? But honestly speaking I cannot remember its fleetnumber for the life of me). But that shows that its not necessary the end of the road for the Class 60's as that has been proved with the "Super Tug" program that started in 2011 under DB Schenker that would have never happened under EWS. The downside for the Class 60's was that every single one went to EWS as had Freightliner inherited some of them and perhaps GBRF at the end of the 1990's when BR was totally privatised. I reckon that ones under Freightliner would have been used and ugly Class 70's would have not been required for heavy haul. Same with GBRF as the Class 60's are very good locomotives and they had very advanced CPU's that were ahead of their time in the 1980s/1990s when they first entered service under BR.
You would be forgiven that I am speaking here from an enthusiast point of view and yes I will admit that the Class 60 is my favourite freight locomotive that is on the mainline. But for an FTOC that wants a powerful locomotive that is cheaper than buying a new locomotive. The obsolete Class 60's that DBC don't need/require is a good choice as demonstrated by Colas and I hope that Freightliner and GB Railfreight/Europorte will consider buying some. As then, all those 142/143/144 Pacers when displaced by proper trains can take the place of those stored Class 60's!. Also putting more freight by rail would be a good start as it would take some lorries off the road as well
From what i've been reading over the past couple of years on here on the UK rail forum is that the specification of the class 60 is exactly why 66% of the class are sitting at Toton.
Whilst they have their merits, they are specialist in heavy haulage which we have a limited amount of. The top speed is 60mph which is too slow for other traffic and they have no heating for passenger traffic of which there is next to no carriages for anyway.
Which begs the question, what work existed in 1989 that warranted a 100 loco build in the first place and where did that work go? (if existed).
I do like the fact that when you often see a 60 it has a huge rake of wagons behind it. Which is more than can be said for all the other British diesel traction on the network.
For starters I think there was still a fair quantity of coal and steel traffic around at that time, also don't forget that the class 58s which ofcourse were BRs earlier purpose designed heavy hauler locomotive were not exactly living up to their promised expectations, and as well as the class 60 BR also had plans for a class 65 higher powered version (4000hp) with a higher max speed making it suitable for Freightliner/intermodal type traffic, looming privatisation at the time probably killed this one though.
If the class 65 were built, the class 60's would all have gone by now.
But to me it does seem like 100 was overkill on the order. Especially since in that era you still had 56's and 58's that were working at that time. To have a further order of 65's makes me wonder why they didn't start with the class 65 specification to begin with.
In contrast, the 59 fleet that the 60 was competing with only built a handful (not sure how many). The 59 class has an impeccable record over the years and some of them look newer than their 66 cousins.
Interesting, thanks for that, after the super sixty refurbishments is the Mirrlees power unit still regarded as the weak link in the design or have modifications been made to improve its performance?
Whereas Crewe is a depot with a scrapyard hidden inside it!![]()
This is probably just an afterthought. Does the core of the problems with the Class 60's lie with the Mirrlees units? Or are the CPU's the cause of the breakdowns/failures of these locomotives? If its the former and from my understanding of the Class 60's. The whole Class 60 is built like an aircraft using a monocoque (spelling?) frame rather than chassis/bodyshell like on the Class 59/66. So if the Mirrlees units are getting past it to put it nicely. Perhaps something similar like a Caterpillar V12 like those on the Class 68's or an MTU V4000 like those used on the HST's would be compact enough to fit. However if the problem is mainly down to the CPU hardware. Perhaps a more modern reliable CPU system could be implemented and replace the older CPU.
The only Class 60's I am aware of that has had major PU failures is 60006 and 60081 (thrown a rod), 60008 (turbocharger explosion), 60064, 60070 and 60098 (unknown failures) which makes six of them on the SU (stored non-servicable/major work needed repairs) list as a minimum.
That aside though. I think once the core of the problem is solved. Perhaps DB Schenker could lease a few Class 60's to other FTOC companies like DB Railfreight/Europorte, Freightliner and Direct Rail Services if the latter wish to enter the heavy haul market. However the problem is that the freight by rail although it is growing steadily. Road transport and the aftermath of Baldylocks Beeching closing off many of the lines back in the 1960's/1970's makes the freight by rail market more difficult. So more rail freight can be a viable option if more lines are built and/or reopened to traffic.
Are the 60s the first class of loco or unit to have had some sort of electronics/computer managing aspects of the engine in the UK?
The class 50s as built were full of electronics.
Were most of those taken out during the refurbishment at Doncaster?
I'm no expert, but I think you are correct, wasn't this after they were all transferred to the Western Region? They also lost their 'Hoover' sound after this if I remember correct.
What I've often wondered about the class 60 is, who was the brave person who chose a Mirrlees engine design when the Ruston RK270 series were on offer. Given the problems of the class 30s, and the Blackstone equipped batch of 08 shunters, the risks should have been glaringly obvious
There are currently 24 Class 60s in the 'active' pool allocations - ten with Colas and fourteen with DBC. The remaining 76 Class 60s in store are all DBC locomotives. I suppose that isn't too bad considering the economic climate and the surplus of 66s at present.
The decision to build the Class 60 as it is was ultimately down to politics. It was far too unpalatable to build the common sense decision and gone with the proven GEC / General Motors Electro Motive option. They offered a state-of-the-art Class 59, to have been built in the UK (at Crewe?). Had it been selected, maybe EWS wouldn't have felt the need to have leased 250 Class 66s and all of the enlarged fleet of 59s would have remained in revenue earning service. Hindsight is so wonderful .....![]()
Very good read that. I am pleased that its not completely game over for these locomotives. I would say that more Class 60's could return to service if GB Railfreight/Europorte buy any for their fleet. Colas has a few of them with a positive outcome.
On the talk of Class 60 with passenger trains, if the Class 60's were ever modified to work on passenger trains. They would firstly need to have a HEP output to power the carriages or a generator coach (converted Mk3 DVT with generator fitted for HEP/ETH?) in the consist as a minimum. Also secondly the locomotives would need a serious rework with uprated traction motors to deliver a top speed of about 80/90mph to comply for mainline operations.
Depending on the rolling stock used. The Class 60's would fit perfectly with a rake of Mk3's and a Mk3 DVT as I run one of my Hornby Class 60's with a Mk3 rake and DVT and it looks somewhat uniform!. If a new power unit would be required. You could always used the Caterpillar V12 as used on the Class 68 locomotives. Or shove some secondhand EMD710T-3i's in them for some awesome thrash. The video below will show how they might sound with that setup.
https://www.youtube.com/watch?v=1U4T85H4G-k
Why should DBC do that? I was surprised when they performed the Super 60 refurbs on the locos that Colas were allowed to purchase, but DBC must have had their reasons (notably financial). I daresay they charged a healthy premium to Colas for that work.
Again, we can thank politics for how Wisconsin Central acquired their fleet of locos. Unlike passenger locos that generally passed into the hands of the ROSCOs at the time of privatisation, EWS hoovered up the existing loco fleet along with the businesses they purchased. This has now manifested itself as a fleet of 58s in Spain with no likelihood of return, dozens of 60s rotting at Toton and even 90s parked up with no work, all under the auspices of one FOC. If only the 58s, 60s, 90s and 92s had passed to the ROSCOs ..... again, fantasy thoughts with the benefit of hindsight!
Many of them would still be parked up - If there is no work there is no work. Many of those classes were built to haul coal trains. We have few coal train these days.
Since those 60's have been left to rot we have had -
Lots of 57's, 68's, 88's and 70's ordered. People are rebuilding 56's.. and lets not forget that until recently 66's were arriving on our shores.
at least some of those locos are pulling 45mph, 50mph and 60mph trains.
Under a differing political system many more of the 60's could be running those trains. It is understood about the coal though, that was their primary function.
