Gets yours right you mean!!!
You start in shunt, notch 1. This puts all the resistance into the circuit and lets you start away upto between 10 and 15mph {varies between units}. Full resistance remains in during shunt.
Next up, you goto Notch 2, Series. You accelerate through 8 steps of series using the current limit relay {CLR from here on}. This brings you upto around 35mph. At full series, you have no resistance in the circuit
Now you change the motor configuration for Parrallel. Instead of having 4 motors in series, you now get 2 lots of 2 motors in series, giving you series parrallel. This reduces torque to allow for a higher speed with less energy. To do this you open the series parrallel contactor
You then put all the resistance back into the circuit and work through the 8 steps of series parrallel {known as parrallel}, again controlled by the CLR. By now you should be reaching 45 - 50mph. At full parrallel, you have no resistance left in the circuit
Now you move into weak field, notch 4. You once again put all the resistance back into the circuit and the series parrallel contactor remains open. Now you close the weak field contactor, to divert around half the magnetic field of the motors, reducing torque even more. You then work through the resistance bank for the final time, switching out all resistance until about 65mph when you are in full weak field and it's down to the condition of the motors to bring you upto the full speed of 90mph
Greyhound units have an additional step, not referenced on the driver's power controller, known as field divert. These are addittional contactors to divert even more of the magnetic field to allow higher speeds.
Originally Greyhound units had a higher rate of acceleration by retaining higher ampage for longer during clr sequencing, but i believe a mod late in the life of the units reduce them to the same acceleration performance levels as a non greyhounded unit, but they still retained the capability of reaching 100mph {minimum
In case you are wondering, selecting notch 4 from a stand just lets the unit change up when the CLR dictates {like an automatic gear box}. Hand notching is rumored to provide quicker acceleration aswell as being more energy efficent
