Group Stations file
wintonian
15 Jan 2010
Hampshire
Has anyone got a copy of the group stations file? I ask as it seems the link on ATOC's website currently seems goes to the easements file which isn't all that useful when you want to see the members of a group.
I'm particularly interested in Portsmouth group ATM.
sonic2009
19 Jan 2010
Crewe
Try this link here.
Portsmouth Group stations are :
Bedhampton
Cosham
Fareham
Fratton
Hilsea
Portchester
Portsmouth Harbour
Portsmouth & Southsea
wintonian
15 Jan 2010
Hampshire
Try this link here.
Bedhampton
Cosham
Fareham
Fratton
Hilsea
Portchester
Portsmouth Harbour
Cheers, I forgot about Bedhampton.
If Portsmouth as a routing point (RP) fails the fares check does that then prevent you from passing through the group or just the RP, i.e. can you still take the direct Southern service between Cosham and Bedhampton?
hairyhandedfool
14 Apr 2008
The fares check rule is used to identify the appropriate Routeing Points for a place, it does not prevent you from travelling via that place (despite what one of the examples in Section F says) if it is on a permitted route to and from an appropriate Routeing Point.
A Routeing Point Group is treated the same as a Routeing Point.
wintonian
15 Jan 2010
Hampshire
Ah ok, I thought if a RP failed the fares check then you werent allowed to pass through it even after passing through an appropriate RP, obviously I'm wrong and you can.
hairyhandedfool
14 Apr 2008
It should also be noted that through trains and the shortest route are always following a permitted route.
wintonian
15 Jan 2010
Hampshire
Yes but only the shortest/ through trains from origin - destination
I was looking at a flow with a very wide range of mapped routes and a faild fares check on one of the 4 RP's. involved ;)
You are travelling from station X to sation Y, station X is associated with RP A, Station Y is a RP.
The fare from X- Y is any permitted
However the fare from A - Y is either route reading, route not London or route London
Only the route Reading fare passes the fares check
Does that then mean that valid routes from X - Y must go through Reading and avoid London?
