Guided buses on the Underground / Stadtbahn?
MotCO
25 Aug 2014
They could have modified the London bendy buses to run on the Northern Line :lol:
Gordon
11 Feb 2011
Pretty certain neither of these systems still exist.
The Seattle one absolutely still exists. It was built as a bus tunnel at first, but then they 'saw the light' and put in proper light rail instead - or in this case as well as.
This is the same kerb-guided system as used in Dunstable, Cambridgeshire etc. However the tram lines are metre gauge and I don't think it would be possible to do the same with standard gauge. Pretty sure a flat-sided tram to the normal width of 2.65m would foul the lateral guides.
Note that the trolleybuses buses needed doors on both sides, and that their overhead was displaced off to one side presumably to clear the pantographs of trams.
If I recall correctly the Seattle one is unguided (for buses).
gsnedders
6 Sep 2015
It was always designed for dual usage (hence its height!), but it was uncertain whether any light rail would get built when the tunnel was build hence it wasn't originally fitted out for it.
Originally was fitted with a overhead wire for trolley buses, that went when the rail went in, but now operated by hybrid buses that run on battery only when in the tunnel.
Indeed it is; they even have a small parking area down there.
WatcherZero
25 Feb 2010
The planks of wood thrown down for bus track is hilarious. Can you imagine trying to get that past a British tunnel fire safety case.
Bayum
21 Mar 2008
It irritated me how slow those buses were through the tunnel.
duesselmartin
18 Jan 2014
Duisburg, Germany
They were part of the problem. Mind you, Germans never understood the wooden escalators at Kings X.
From a durability point, the planks seemed silly, as the owner of that video clip suggests.
