GWR 802s to Plymouth - Where do they switch from Electric to Diesel?
irish_rail
30 Oct 2013
Plymouth
Under normal running, at what point is Notch 5 usually applied? Say if accelerating to 100mph from rest.
Yes, although in theory a service towards Oxford calling at Didcot Parkway (for instance on Sundays) can perform the power changeover while stopped in Didcot Parkway platform. There is little benefit in doing so, however.
It varies from driver to driver , im not sure on what the official guidance is, I normally hit notch 5 about 20mph ( if I do actually risk using it). Trouble is they were not designed to run with such a lightweight load and to my knowledge this hasn't been addressed yet.
hexagon789
2 Sep 2016
One option for that would be to downrate the engines to say 2,000hp or even slightly less.
Or lock out Notch 5, that would leave the maximum nominal power output at ~1,790hp in Notch 4.
43096
23 Nov 2015
And if you have one power car fail, you then don't have notch 5 available to compensate in the good one.
83A
16 Jan 2020
Cambridge
Interesting thread.
I’m curious (if anyone knows) how it’s electrically changed over.
At some point (say approaching NBY on the down line) it will have the panto up and the engines started, therefore you have two sources of power to the traction motors.
Is that changeover automatically managed or does the driver have to throw over a relay (metaphorically speaking) I appreciate it’s more advanced than that ;)
hexagon789
2 Sep 2016
It was just a suggestion. Perhaps derating the power car engines would be better in that respect then
