GWR Class 165/166 Turbo Diagrams
JN114
28 Jun 2005
Other than passing through to or from Wolverton it is unusual these days to see a 166 at Reading, but it looks like 166207 is working this evening Bourne End diagram.
2B42 1714 Maidenhead to Bourne End
I guess it worked up from Westbury earlier?
5R60 1115 Westbury to Reading Traincare Depot
Not a scheduled fleet changeover; will probably be undone again over the weekend, but 166207 needed to come out of service this lunchtime for fuel etc; and there was nothing available in the “West” Turbo fleet to replace it at Bristol; meanwhile Reading had a unit spare and a driver to take it to/from Westbury; so best use of resources available has resulted in the temporary swap. 165120 is the “East” unit that has gone West.
Looks as though with 166207 available for evening service, Reading have sent it out on a diagram that doesn’t see it go too far afield.
30 Jul 2015
Thank you for the explanation. I guess it did not fit in with driver availability for 166207 to replace 165124 on the 2v3 Basingstoke diagram, and send 165124 to Bourne End which is booked a 2-car. Still, a 2-car Basingstoke is better than the 0-car that is the third Basingstoke diagram this evening.
nctd2306
2 Jan 2024
Berkshire
About that...
166207 is showing as on Reading to Gatwick services today, so they clearly don't see an issue sending it further afield today!
HamworthyGoods
15 Jan 2019
About that...
It’s still captive and gets back to Reading, doesn’t start wandering to Oxford.
LUYMun
15 Jul 2018
Cancelled
I've a bash on 166207 earlier today, and I must say it's well suited to the North Downs, especially with the additional luggage rucks that came handy for Gatwick passengers.
JN114
28 Jun 2005
Also visits Reading regularly so that it could be swapped out to head back home if a driver became available to drive it and a unit available to replace it.
30 Jul 2015
It looks like a plan is in place to swap over 165120 and 166207 on the 1708 Pompey - Cardiff at Westbury this afternoon
5Z30 1735 Reading Traincare Depot to Westbury
1F30 1708 Portsmouth Harbour to Cardiff Central
5F30 1910 Westbury to Reading Traincare Depot
LUYMun
15 Jul 2018
Cancelled
Are there any changes on the Thames Valley Turbo mainline diagrams post June 2024? Looking at RTT the 03:54 Reading - London Paddington as well as the extension to/from Greenford seem to be the only ones, which is the same as current.
JN114
28 Jun 2005
Correct, no change
800301
29 Dec 2022
Essex
30 Jul 2015
Reading seem to be down a few units this morning with 165114 off 2J12 0739 Basingstoke - Reading being used to work 1O61 0823 Reading - Gatwick. The following Basingstoke has been cancelled
08:23 Reading to Basingstoke due 08:52 will be cancelled.
This is due to a broken down train.
As you may expect, the return 2J20 0919 Basingstoke - Reading was also shown cancelled, but that cancellation has now been deleted from journeycheck.
2J20 still shows as cancelled on RTT, but not on darwin. Even though RTT shows it cancelled, it also shows an allocation - 158885
JN114
28 Jun 2005
Difficult to get right into downstream systems, which aren’t well setup for such adhoc cross-TOC cooperation, but the inference is correct.
2J19 is Cancelled
2J20 runs with SWR Unit and Crew
800301
29 Dec 2022
Essex
Currently 3 car 165108 is on 1C70 from Taunton and showing as running the full way to Pad on 1A81 although I have a feeling it will come off at Exeter
henryb
27 Nov 2021
Newton Abbot
Don’t believe it will - it’s done the whole route before. Although not a good sign of IET availability
125Spotter
7 Aug 2022
South West
Assuming the online data is right, and various data sources certainly seem to corroborate it, I was stunned to see a 165 has been subbed in for an 80x to operate 1A81 Paignton to Paddington today! The cause appears to be a unit fault with the originally booked 80x from Paddington (0703 ex Pad) but quite a difference for a 3 car 165 to arrive in place of a 9 car IET – is this a common occurrence vs. just cancelling the service due to a train fault?
I wondered if it is a revenue service masquerading as a positioning move, but it doesn't appear to be – the 165 is also currently booked to do the return journey.
I don't envy the passengers or the staff operating this service. My recent experience on weekday non-peak departures from Exeter has shown these services to be well utilised.
Class172
Quizmaster
20 Mar 2011
West Country
It’s now showing on the departure boards at Taunton as running to Hungerford. Whether it runs fully to London is to be revealed—I suspect it will, but this will be a move to discourage passengers from overloading the train and encourage them to wait for the following service. By the time it reaches that far the following service 1A82 will have (at Westbury) or will soon (at Newbury) overtake it would be my guess.
800301
29 Dec 2022
Essex
Yeah all the way to Pad now, reported full and standing with Special Stop orders on services behind
Class172
Quizmaster
20 Mar 2011
West Country
I’m impressed it got as far as Reading with only one minute of delay. Whilst the B&H doesn’t have high line speeds, Turbos are not exactly the sprightliest off the mark.
REVUpminster
3 Jan 2021
Paignton
It's on it's way back as 1C85. Maybe it's got free water on board. I have seen the local 165, 166s, and 150s pick up bottled water at Paignton during hot weather.
Been overtaken at Taunton by 1C86
JN114
28 Jun 2005
Booked to work the return to Paddington too (possibly as far as Exeter). Ouch.
1A98 Paignton - Exeter, then swap for 1A37 Exeter - Bristol (with that IET covering remainder of 1A98); then swap again onto depot (with an IET continuing 1A37 to Paddington)
geoffk
4 Aug 2010
Does the new timetable require additional IETs? There's an extra 12.05 Padd to Plymouth, the 12.03 now calling at EXD only to Plymouth then stops to PNZ. The progress of the Turbo was being watched with interest down here in Devon, with bets on how far it would get.
30 Jul 2015
Probably OT because it is not a turbo, and following on from the exploits of 165108 yesterday, today 1C70 is allocated 158745 from Westbury and 1A81 to Exeter.
On turbo matters I assume 5Q81 is 166213 this evening and 5Q23 a.n.other going to Doncaster tomorrow
5Q81 1800 Doncaster Works Wagn Shops to St Philips Mrsh H S T D
5Q23 1413 St Philips Mrsh H S T D to Doncaster Works Wagn Shops
ls2270
24 Oct 2012
5Q81 is indeed 166213.
