Your right about the chiterns , they were bespoke, Irish rail mk 3 and 442 had plug doors so it’s not brain surgeryMy understanding is that the plug doors for Chiltern were complex, late and over budget. This was because there turned out to be little consistency in the body shape of the mark 3s and everything had to be done bespoke rather than using standard parts. In addition the operation of plug doors generally is less reliable and the maintenance more expensive because they have more moving parts.
The current delays seem to be more to do with getting the new setup to work with the HST braking systems rather than anything to do with the doors themselves. If that's the case they would likely have been encountered whether they'd gone with the new setup or the Chiltern-style plug doors.
They are a lot easier to fit when the vehicles are new than trying to convert 40 year old vehicles that have done millions of miles.Your right about the chiterns , they were bespoke, Irish rail mk 3 and 442 had plug doors so it’s not brain surgery
They do operate on a pole system yesIs there not also an issue with them being too narrow for wheelchair users to get past as a result of the pole on which the door pivots? I think the 442s were granted a derogation, but I'm not sure you'd be able to build new (or convert) something that wasn't compliant
I'd argue they should've been built with power doors. The technology existed at the time of going into production.£125K per coach (including all PRM work and CET tanks), though. As mentioned before, this conversion should have been implemented seven years ago (after the Chiltern method).
Well of course, hindsight is always 20-20... but can anyone find me an example of a "stop-gap" solution on the railway that remained as such?Although when you allow for the fact that they were only intended as a stopgap with a 15 year service life expectancy it was probably considered that the additional cost for fitting power doors would have pushed the construction costs way beyond the original budget, especially when you consider the size of the fleet.
Blimey half a million for a 4 coach, not so cheap even by railway standards, one wonders whether an alternative rolling stock solution could have been found for the GWR ones, it will be interesting to see what happens regarding the MML HST's given its going to be a million per set! and times running out to do them.
Then again, a mere drop in the ocean compared to a new build 4 Car DMU costing what £6-7m apiece?
But then a new DMU will likely have lower operating costs and last 30 years, while the HST might last 10 years but I suspect they will probably be replaced at some point by the winner of the next GWR franchise.
Will these Mark 3 coaches rebuilt with power doors have a pole in the doorway like a Class 442?
I could see the short sets soldiering on longer, maybe with replacement power cars.But then a new DMU will likely have lower operating costs and last 30 years, while the HST might last 10 years but I suspect they will probably be replaced at some point by the winner of the next GWR franchise.
No, the pole in the 442s is so that the doors can pivot out on it. The Mk3s currently being done all have sliding doors, so no need for a pole to pivot around.
The 442s interestingly have two types of power door - the Dutch style ones with the pole are at the vehicle ends, any that are not at the vehicle ends are conventional sliding:
Yeh i think originally these doors were locked to the public when the cab this end was the cab in use. This may have something to do with itThe 442s interestingly have two types of power door - the Dutch style ones with the pole are at the vehicle ends, any that are not at the vehicle ends are conventional sliding:
442 cab end door
