Utter genius - an imposed contract.
23% isn't likely to be on the table even from Labour.
Even assuming firstly that was done and secondly that your assertion that there are already sufficient hours contracted is actually true (and just about every industry insider seems to believe that is utter bunkum)
I didn't say it was.
Even if you added 2hrs to the rather light 35hr/wk, it can only be done by serious pruning of little used services on weekdays and moving the hours worked to where they are needed.
Many commentators try to pretend these services don't exist, but they aren't looking very hard.
then your wonderful contract would poison the well on goodwill for decades to come. Good luck with a permanent work to rule.....
There is no goodwill. That is why the past 2 years happened. Zero goodwill needs to be a planning assumption.
I forgot to say that the railway has traditionally, and probably rightly, prioritised work travel - mainly in the week - over leisure travel (mainly at the weekend) - hence when planned engineering work is generally done. You apparently want, for reasons you don't appear to care to explain, to change that. Don't exactly hold your breath!
It is quite simple really.
You run trains on Sundays with 300, 600 people each, that are currently being cancelled week after week, rather than trains with 50 or fewer, often running a few minutes apart, before 6am and after 10pm.
The majority of weekday trains are in the middle of the day, or the evening and are not taking people to or from work / school.
You say the railway priortises travel to work. The railway doesn't prioritise anything much, most of what the railway does is a simple accident of history that can't be justified, be that the fares or the timetable.
If travel to work demand, no matter how thin, is a somehow the priority, then the first train of the day from Leeds to Birmingham would be 5am not 6am, as it is from Manchester. The first train from Birmingham to Bristol Parkway would be over 2hr earlier than it is today, which it is already is if you happen to work in Cardiff.
And why doesn't every station 75 miles from London have overnight services to London on Monday nights, like Peterborough and Milton Keynes do?
Stansted and Heathrow Airport don't have overnight trains, but thousands of people start their shift before the first trains arrive.
