GWR Turbo cascade progress to Bristol region services
PHILIPE
14 Nov 2011
Caerphilly
166221 was the first Turbo to reach Brighton in passenger service today following their route clearance. Great Western are running their Brighton services between Brighton and Portsmouth Harbour due to the Landslip between Salisbury and Romsey today
moley
12 Jun 2011
I don’t get why these are not running to Southampton. Dumping passengers at Portsmouth with only a stopping service to Southampton to continue their travels is awful customer service.
Kite159
27 Jan 2014
West of Andover
Surely any passengers for Southampton would change at Havant for a Southern service to Southampton, rather than going to Portsmouth to pick up the stopper? Although I guess that depends on connections
py_megapixel
5 Nov 2018
Northern England
A couple of questions:
  • What are RHM mods? I've seen them mentioned a few times now.
  • Are the Turbos scheduled to get a new GWR interior? The current seat covers and interior paint work are looking very dated now.
  • What are RHM mods? I've seen them mentioned a few times now...
RHM is ride height modifications. They basically fitted shims between the bogies and the bodywork to help gauge clear them on more routes, ie ensure the units didn’t hit quite so many platform edges. Somewhere in the various threads in the forum the exact dimension gets stated, from memory it’s about 20-30 mm
30 Jul 2015
RHM = Ride Height Modification
Spacers are inserted on to the bogie mountings to raise the body of the unit by a small amount to increase platform clearances. This is required for any turbo that is working diagrams off Bristol.
All 166s have been modified and I believe all 165s bar
165102,103,109
165121,123,125,126,130,133,136
Modified units are identifiable by yellow triangles below the cab window,
TJDevon
29 Jan 2018
Exmouth
Would appreciate a couple of updates:
Is the one 166 (204?) still at Reading?
How many 165s have moved to Bristol? Presumably no more to move until the 769's are in operation?
FGW_DID
23 Jun 2011
81E
Yes, 204 is still at Reading.
There are still 26 165s at Reading (10x 2 car, 16x 3 car) although 165130 is over at SPM for C4 work.
30 Jul 2015
Is there likely to be a mini cascade of turbos (2?) back from Bristol to Reading to cope with the increased number of North Downs diagrams from the May timetable change?
There isn't going to be an increased number of North Downs diagrams from May. The service stays 2tph (but with a substantially worse timetable) until the 769s turn up.
The extra trains are now shown in RTT as 'unadvertised express'. That means the stopper runs at xx20 from Reading with a layover at Guildford and the semi fast at xx01. Quite why the trains run on the other side of the hour from the current timetable and break established travel patterns isn't obvious.
HamworthyGoods
15 Jan 2019
In reality a substantial part of the May T/T will be the emergency 1tph timetable anyway.
