Does the EMT shont cross to the down slow?Well that ECS can't run, not just because of the Lime Street bit but because an EMT shunt would be blocking it's path.
Excellent. Thank you for sharing this.
The first confirmation that W&B will run the service.
Looks like no stops between Lime St and South Parkway, which at least keeps journey times reasonable.
Oddly it's the first item of the new W&B franchise spec to break cover.
I guess it will be after the Lime St blockade when things start to happen on staff training.
Now we just need to know where the rolling stock is coming from...
A commuter service from North Wales, Chester, Helsby and Frodsham to Liverpool could be provided by:
adding two carriages to 1K05, the 06:46 Llandudno (LLD) to Crewe, splitting at Chester
and
joining two carriages to 1D31, the 16:50 Manchester Piccadilly to Llandudno at Chester at 18:00 arriving Llandudno an hour later.
Holidaymaker, daytripper, shopping, airport, business and sightseer services in both directions could be provided by similar processes throughout the day.
adding two carriages to 1K05, the 06:46 Llandudno (LLD) to Crewe, splitting at Chester and
This would be an ideal use of Class 769s, maybe an out-based maintenance agreement with Northern at Allerton depot?Could end up with 769s!
Looks like Alston may be looking to try new rolling stock.This would be an ideal use of Class 769s, maybe an out-based maintenance agreement with Northern at Allerton depot?
It still suffers from a number of low, round arch sandstone bridges, just like the Crewe line.What’s the consensus of electrifying Chester to Halton?? Then maybe Frodsham to Acton? Is it possible? Doesn’t seem to have the issues the Crewe - Chester line has and I’m sure there’s a strong case for it. Sutton tunnel is rather long but there seems to be ample space in there for wires.
Could it be for the Cosford Air Show? Looks like it would be the first passenger service in that direction for a long time.Here's a thing: a southbound train via the Halton Curve on Sunday June 10.
On RTT there is a West Coast Railways train from Liverpool South Parkway (LPY) to Cosford, running via the Halton Curve and Chester, Wrexham and Shrewsbury.
Would this be the inaugural southbound service?
It leaves LPY at 1018 (1Z78), and returns at 2256 (1Z80), but the return leg runs Shrewsbury-Chester-Crewe-LPY (ie not via Halton Curve).
Is this real?
http://www.realtimetrains.co.uk/train/U10638/2018/06/10/advanced
Certainly not Megabus prices...Wow mega prices!
I suppose that this and the Todmorden Curve, which I watched being built, are relatively cheap, in railway terms, and can achieve quite a lot of extra connectivity. Now how about the Burscough Curves (or one of them)?good news
Yes, transferred to Manchester ROC at the end of May after the last Bank Holiday blockade work.Now that the curve is and point work is complete is this being controlled from the ROC at Manchester now? Thanks in advance!
