Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 11,838
So how does/should a slightly higher vehicle get through?No. The road markings mean it’s a two way road for low vehicles.
Wait for a gap. Wait for an individual driver to notice soon enough to give him room.So how does/should a slightly higher vehicle get through?
So essentially the big van that stuffed into the overbridge (and the Waitrose van) should only have attempted to negotiate its way through the tunnel, if it had a clear run through the middle, where the tunnel clearance is highest?
Ta. Similar overbridge on the Liverpool -> Manchester railway line along Worsley Road, Winton, near Patricroft station.As well as the normal two way road markings there are a second set to guide high vehicles to the centre. High vehicles should wait for the gap.
He was talking about me...No, I moved in 2012!
Yes, correct - it's more normal than not for traffic to be queued back there, as far back as Longmead Road never mind the railway bridge...About 50 yards further to a give way at a mini roundabout, then another 100 yards to a fairly busy light controlled junction. Yes, traffic could easily be queued back.
The lorry in question was an articulated bulk tipper on a council contract related to Longmead tip; they are instructed to go this way and there are several such movements daily each way.It's a very busy road and its use by large lorries has increased hugely over the last decade or so.
The roundabout it has come from leads only to a car park on the right ( as seen from the way the lorry was travelling ) and a very small residential area on the left. There is minimal traffic from either side and what traffic there is can be seen from way back. Most people, unfortunately ( car drivers especially! ) do zoom straight across the roundabout - at least in the direction the lorry was taking; the other direction is usually a queue.There are roundabouts both sides of bridge, obviously if anything is turning right coming opposite way it has priority as already on the roundabout.
It makes you wonder how the truck managed to go so fast, unless he just motored through the roundabout without stopping
On that bridge, there are two height restrictions on the bridge itself - the sign in the lead up to it has the larger restriction alone, but the arch indicates the width of the two different headrooms available. (Plus the "HIGH VEHS" road paint road markings).
Here's the streetviews on approach :
I have advocated for many years that all rail-over-road bridges in the UK with height limits for road vehicles should be protected on each side by heavy steel gantries across the roadway, as happens in a number of European countries, including Belgium and - I think - the Netherlands. By doing so, overheight trucks, buses, etc. would demolish themselves on the gantry and leave the bridge undamaged.....thus allowing rail traffic to continue running without disruption.
AIUI the arch bridge sign height is not the peak, it’s the height of a default 3m wide section. The peak height would be useless to any usual shaped vehicle. My earlier post #11 also refers…Those road signs are accurate, but are a bit too easy to misread.
There's a lot of information in this sign. The first piece I'd notice is the number: 15' 6". If I'm in a 14' tall vehicle and not paying full attention I might think "that's fine, I'm less than that number so I'll fit under the bridge". Only if I look more closely do I see that arrow indicating that this is the height of the peak of the arch. At this point there isn't enough information to tell me if I'll need to use the middle of the road, or any instruction to do so (just a warning that vehicles coming in the other direction might use the middle of the road).
If I was redesigning this signage, I'd put 13" 0' inside the warning triangle, and have text below reading "Vehicles up to 15' 6" use middle of road". This ties the higher number to the need to move to the middle of the road, and means if you're not paying full attention you only read the lower number.
Of course a professional driver should know these road signs and always be paying attention, but what we should do at work isn't always what we do do at work.
No CCTV footage, particularly so at locations with multiple incidents ?The biggest problem with recovering costs from the offending road vehicle, is that in the majority of cases, the driver has driven away...
Back when Railtrack existed and the contractors that worked for it had some of their staff trained for ‘first response bridge bash’ there wasn’t even a mention of CCTV...No CCTV footage, particularly so at locations with multiple incidents ?
They do in other areas...And I haven’t heard of Network Rail using CCTV for this in my area.
